Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Fuel leak with briggs & stratton 5000 Watt portable generator
Gas is leaking from the generator when we put gas in the tank and don't run it. is this because the fuel shut off valve wasn't turned to "Off"? Will it leak gas when this happens?
CarlGehrke
  • 169 Answers
SOURCE: stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
Posted on Mar 15, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: Briggs and Stratton pressure washer fuel leak
You've hit the nail on the head.The float,needle and seat are stuck wide open.Once the carburetor bowl is full of fuel the float rises up on top which pushes the needle back into the seat shutting of the flow of fuel.As the engine consumes that fuel the float drops and opens the needle and seat filling the bowl and shutting off the fuel again.Things that cause this process to not work are:forgetting to empty or run out the fuel before storing it for the winter.Sediment buildup in the bowl.Mineral deposits in the needle and seat.
Not emptying out the carb can leave water in the bowl which freezes,crushing the float.It also promotes sediment buildup and mineral deposits.The float when crushed or cracked will not float,nor shut off fuel.Sediment takes away capacity of fuel in the bowl,very necessary for wide open throttle.Mineral deposits build up to the point that the needle and seat can't make a good seal so fuel will continue into the carburetor.
Enough information yet?
To repair,take the nut off the bottom of the carburetor bowl.There are the float and needle and seat assemblies.All three need to be replaced,$10 max.After you get the parts replace one piece at a time so you can see how they go together.Next replace the spark plug, engine oil and air cleaner.They are fuel fouled and even if you could get the engine started will only add more damage to your engine.BEFORE you put the new plug in cycle the engine by pulling the starting cord a few times to get rid of the excess fuel.When there's now more fuel in the cylinder replace the plug,filter and oil.
That's it!Take your time and you can do it just fine.Re-post if you have any more troubles.
Posted on Jan 13, 2010
cmcduncand
  • 714 Answers
SOURCE: My propane generator engine has apark and gas
For a quick test.
Check engine oil.
Remove wire from low oil sensor and see if it starts every time.
If that works change oil and replace low oil sensor.
Hope this tip helps to solve your problem.
r/
David
Posted on Jan 23, 2010
  • 905 Answers
SOURCE: I have a generator that does not produce any
As long as you have continuity through the stator and rotor windings, and no continuity from the windings to the core, you should be good.
If the brush block was replaced due to it being defective, take a look at the diode and capacitor regulator as well. Using a multimeter, the diode should indicate continuity in one direction, infinite resistance in the other. If you get this, then replace the capacitor. If not, then replace the diode, and likely the capacitor as well.
Posted on Jun 12, 2010
rycgl
  • 1545 Answers
SOURCE: My briggs & Stratton star but they don not
Remove the brass bolt holding the carburetor bowl on and clean it real well. It has some very small holes in it that carry gas up to the carb and may be partially or completely clogged, causing your problem. All holes must be clear.
Posted on Jun 13, 2010
Fix a leaking petcock shut off valve
You have no product shown
You will have to remove the shut off
valve & replace a gasket or reseal it into
the tank
Nov 06, 2014 | Cars & Trucks
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Model o3o319 portable generator not getting gas or air has spark
your filter inside tank may be clogged take aome air and blow in the out let of gas to see if it maybe dirty. check the fuel line itself maybe weak inside and collaisping and not allowing fuel.
May 10, 2014 | Briggs & Stratton Briggs and Stratton...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Honda generator leaking gas from carborator
that is your fuel drain screw so if you get any water in your carb you can drain it and it was loose thats why gas drained out of it
Dec 16, 2012 | Briggs & Stratton Measuring Tools &...
Trouble shooting a 456 code on a 2002 subaru legacy
Evaporative emission control system malfunction
Usually this P0456 code is caused by an incorrect or faulty gas cap. Filling the fuel tank with the engine running could conceivable cause this code as well or if the cap wasn't properly tightened. Any of the following could also be the cause:
  • A small leak in any of the EVAP hoses or fuel tank hoses
  • A small leak in the purge valve or vent valve
  • The EVAP Canister may be leaking
Oct 17, 2012 | Cars & Trucks
How to fix obd 2 PO456 on jeep grand cherokee laredo 2002
Oct 09, 2012 | 2003 Jeep Grand Cherokee
Generator is leaking fuel
On most Coleman generators, there is a rubber seal that literally evaporates if left in time. Most people don't even see it because it has gone. You must check if any seals are missing. Make sure that the gas regulator is screwed as tight as it can go because if it isn't, it will leak like a sib. Last problem could be the open and shut valve is stuck which is another thing that happens when it sits over time without using it. You need to start it up and hold the choke and that will stop the leak and let it run for a couple of minutes and let go of the choke. It should open and close the valve with no problems after that.
Aug 27, 2011 | Coleman Powermate Premium Plus 6250W...
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Generator is leaking gasoline out through the carburator when not running. Also, fuel shutoff valve at bottom of gas tank will not shut off completely. What are probable causes and price to fix ??
Most often fuel leaking out the carb is caused by a needle and seat problem in the carburetor / the float level shaft screw may have come loose due to the vibration of the engine ,this will cause a leak issue with the needle and seat as well. To complete the repair the carb will have to be removed and cleaned. Replace the needle and seat if necessary an then replace the carb.
May 30, 2011 | Coleman Powermate Powermate 5000W...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
97 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
