Question about 1995-1997 Chevy Suburban Ignition Starter Alarm switch
When i put it into park it dont ingage and i hve to start in n
  • Chevrolet Master
  • 1,051 Answers
Check the neutral switch on the steering column. Sounds like the neutral switch is bad. It is located on the steering column inside and by the floor mat. There is usually two screws that mount it and a wire harness to unplug. Just be sure and don't move the gear selector while changing the switch.
Posted on Dec 05, 2015
Transmition does not ingage when cold after a few min its ok
The trans fluid cooler(s) are draining back into the pan when the truck is parked. Depending on the year of your truck and which engine you have, there may be an updated cooler line with an improved check valve but on the older diesels (2 gen) we remove them anyway. After you start the engine, shift the trans into neutral and let it build pressure before you put it in drive (or anything else). It won't build pressure in park and if you put it in gear before there is pressure, it will wear the clutch material.
Mar 02, 2014 | 1996 Dodge Ram 3500 Club Cab
Starter stays engaged park or nuetral
Powssible that there is always power to the inhibitor switch. It is the switch that only allows current to flow thru it when in park or neutral. Could be power is always present at the switch when it is in park or neutral. Check the ignition switch first and see if it is powering the start circuit all the time.
Dec 05, 2013 | 2006 Chevrolet Cobalt
My suzuki forenza wont go into park. it will shift in everything else but when i shift into park i got the P with a strike through it on the dashboard
sounds like it maybe your linkage have you ever had any work done on your ****** just a small adjustment can cause a lot of problems also there is a sensor that tells your car wether the brake is ingaged or not when putting it into park sometimes those sensors go bad
Dec 07, 2012 | 2007 Suzuki Forenza Sedan
My 87 jeep starter stays ingaged when I try to start it
needs shimmed or the bendix is bad in the starter and not allowing to release. most likely just needs shimmed if it's a new starter, however you can get a bad starter (new or rebuilt)
Aug 28, 2012 | 1987 Jeep Cherokee
Caen turns on but when put in park it does not ingage
Check the transmission fluid level. In park car idle at operating temperature.The level should be in it marking.If the level is correct,then you are dealing with a internal transmission failure not putting out enough pressure
Mar 15, 2012 | 2003 Mitsubishi Galant
A light came on in the gauge cluster that looks like an explaination mark. i dont have a manuel for the truck so i dont know what it means. thank you. its for a 2007 Nissan Frontier SE Crew Cab
it's the park brake light. it comes on telling you when the park brake is ingaged. there is a wire on the park brake thats of a low gauge it may have broke or the brake is slightly on
Sep 10, 2010 | 2007 Nissan Frontier SE Crew Cab
High range 4x4 works. light comes on. but the low range does not ingage nor does the light
dunno if this is your solution but your bronco only will go in low range if it is in nuetral. not park but nuetral only start your bronco put it in 4 high first then once it goes into 4 high make sure in nuetral then put in 4 low.
Mar 15, 2010 | 1994 Ford Bronco
Car starts i can put it in drive fell the tranny ingage but wheels wont move even when in nutraul but if i rock car back and forth i hear a click and it drives but if i park then put gear shift in park...
Hi,check your transmision fluit level.I think the level is low .start the car ( car on level surface) put it in drive,parking brake set and check your trans fluit level.
good luck!!!!!
Feb 24, 2010 | 1996 Oldsmobile Cutlass Ciera
Key stocked in the ignation switch
You need to put the speed back to Park. It also happen to me once.
Best.
Mar 15, 2009 | 1997 Plymouth Voyager
1995-1997 Chevy Suburban Ignition Starter Alarm switch Logo
24 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
