Question about Craftsman 5600 watt Generator
Whats the best oil for a craftsman 5600 gas generator
The best oil
2 Suggested Answers
freetek
  • 5568 Answers
SOURCE: just up graded from a homelite 4400 to a craftsman
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Posted on Oct 03, 2010
White smoke
You are getting oil into the cylinders. Possibly bad seals on the valves or bad rings on the pistons.
Apr 01, 2014 | Craftsman 5600 watt Generator
Governor not working
make sure oil level is correct and viscosity. check governor arm for binding if loose and floppy internal mechanical damage. If you have the electronic governor actuator on your model then need to check for battery voltage on it, if present actuator bad, if not control board
Sep 10, 2013 | Craftsman 5600 watt Generator
All the fuel leak into the oil pan
my wacker 5600 generator leaked gas into oil. What would cause that
Feb 08, 2013 | Wacker GP5600 watt Portable Generator
Craftsman 5600 watt generator won't stay on and white smoke pours out when started.
try running it with nothing hooked up if it runs fine, then the power draw is to much for it that would cause it to hunt !!!
Jan 30, 2013 | Craftsman 5600 watt Generator
My craftsman 5700 generator has gas inthe oil...why?
your float is stuck and wont shut of the needle and seat so it floods make sure you shut fuel of when not running and check your needle and seat and see if it shuts of the fuel from the tank
Oct 29, 2012 | Craftsman 5600 watt Generator
Generator keeps stopping
ck the oil if its low it will not stay ruunning
Oct 27, 2012 | Craftsman 5600 watt Generator
Gen power shut down every 10 to 15 min
try and run it with the gas cap loose the vent could be plugged up if it stays running but pops the circuit breaker the your over loading the system
Sep 03, 2012 | Craftsman 5600 watt Generator
Preventive maintenance craftsman 5600 generator
there should be a little bowl on the bottom of the carb if so take the bowl off and a gas can & funnel it should drain everything out the reason for draining all the gas out is if you don't most of the time it will start coroding the parts & when you go to use it again it wont run because the float is stuck or corosion in carb hope that helps e-mail me let me know thanks wade
Sep 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 5600 watt Generator Logo
48 people viewed this question
Top Craftsman Electrical Supplies Experts
wadingriver
wadingriver
ray gallant
Steve Pack
Steve Pack
Are you a Craftsman Electrical Supply Expert? Answer questions, earn points and help others
