Question about Asko 1385 Dishwasher
How to remove kick plate - Asko 1385 Dishwasher
Is the filter behind the kick plate on the Kitchen Aid Superba made in 1998?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
May 23, 2014 | KitchenAid Superba Architect KSCS25INSS...
Service manual
Remove the three screws at the very bottom of the unit, pull the kick plate off. Tech sheet should be glued on the side of the unit in a plastic bag. Could also be glued on the back of the kick plate you removed.
Nov 10, 2013 | Whirlpool GHW9400 Duet Washer
How to replace the kick of a dishwasher
there should be a screw on either side of the kick plated. unscrew and remove the two pieces that make up the kick plate
Apr 06, 2013 | Frigidaire FDB700BFC Built-in Dishwasher
Where is the kick plate and how do I remove it?
The kick plate is the piece at the bottom front of the washer. The kick plate is often attached by friction fastener and is removed by prying it off
Dec 20, 2012 | Whirlpool Duet GHW9150P Front Load Washer
F02 error on whirlpool front load washer. How do you open the kick panel?
Depending upon what model you have, most kick plates are removed by taking the 3 or 4 (1/4 inch or torque) screws out located underneath the kick plate. Note that not all front load washers have a kick plate so be sure that there is a prominent gap between the upper most region and the small lower region being the kick plate.
Apr 22, 2012 | Whirlpool Duet GHW9150P Front Load Washer
How do you remove the front kick panel
Here are the steps.Hope this helps.
Insert a putty knife between the top of the kick plate and bottom of the front panel near the center of the washer, if you have an older model top load washer. Move the putty knife blade in and out in that area until you feel an obstruction. The obstruction is the kick plate retaining clip
Press the putty knife blade over the spring clip until you feel the clip disengage. Let go of the putty knife and grab both ends of the kick plate with your hands. Pull the kick plate away from the washer
ift the front of the washer with help from a friend, if you have a front load model Whirlpool. Slide a block of wood under the front of each side and gently lower the washer Remove the three hex head screws on the bottom edge of the washer kick plate with a Phillips-head screwdriver or nut driver. Pull the kick plate away from the washer.
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
Service engine light coming on ...running rough and cant find diagnostic port
Sit in the driver's seat. Put your right hand on your right knee. Put your right hand on the dash/kick plate surrounding the steering column...run your hand down to the bottom of the kick plate. Reach up and under at that point...it's right there. You don't have to remove the kick plate to use the OBD port, but it helps you find it easier.
Apr 22, 2011 | 2001 Suzuki Grand Vitara
I keep getting a dL and then a code F on my washer
LD = Long Drain ErrorRemove the 3 screws on the bottom kick plate, remove the kick plate. You will see the pump filter on the bottom right had side. Open the filter and remove any debris.
Feb 03, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Do I need to clean the filter behind the lower front panel? I removed the panel but nothing in the owners manual that describes it. I heard that you need to do this every year or so for general...
Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. The kick plate is the lower outside cover of the washing machine.
Place a small bucket under the white hose. Remove the cap on the white hose by untwisting it. Allow any remaining water in the hose to drain into the small bucket. There shouldn't be much water, but there can be some.
Look inside the white hose. Remove any visible obstructions or lint.
Look inside the hose cap. This is where the lint filter is. Remove any visible lint with your fingers. Rinse the hose cap under warm water to remove any remaining lint.
Twist the cap back onto the white hose. Put the kick plate back in place. Screw back on.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore dryer how to remove kick plate
if this is a 4-6 year old dryer then the kick plate is held in place with 2 spring clips one on each side a putty knife will disengage the clips,, tip once you get one of the sides loose, put a wedge of paper into the crack on the side and move to the other side to work on the ohter clip
Apr 10, 2008 | Dryers
Asko 1385 Dishwasher Logo
67 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
