Question about Linksys by Cisco Linksys E3200 Dual-Band N Router w/ USB Port
Can i use webcam on e3200 cisco usb port ? - Linksys by Cisco Linksys E3200 Dual-Band N Router w/ USB Port
  • 3,606 Answers
Hello i would say no.
Becauce need of driver.
But you can buy a IP camera ( i guess you need it for some kind of survailance ) it have its own ip address.
And you can access it from any computer.
Here is some info about that:
http://www.dlink.com/us/en/business-solutions/ip-surveillance/business-ip-cameras
Good luck
Posted on Nov 01, 2012
Cisco E3200 router configuration lost
The Cisco connect software came on the CD in the box with the router. If was used to configure the router when new. This can be used to fix the router now. I could guide you through a manual configuration but the software is a much faster easier method. I would recommend you try that route. Get the CD and run from there if you are worried about phishing.
Feb 12, 2014 | Linksys by Cisco Linksys E3200 Dual-Band N...
Easy setup key not working
if you don't have pdh or win ra program on your com you cant open them
Apr 02, 2013 | Linksys Cisco Valetplus M20 Wireless N...
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
Usb trouble
this port is use for update ios
Feb 19, 2010 | Linksys 8-Port (SD208) 8x10/100 Mbps...
I need to connect cisco 2800 router to my pc through hyperlink
I think you mean hyperterminal? you need a cisco serial cable (blue) and a serial port on your PC, maybe a USB to serial adapter if there isn't one. Set hyperterminal to use the COM port you have plugged in to, speed 9600 8 bit no parity. (8N1).
Without the serial cable you need to know the router IP and password.
Oct 31, 2009 | Cisco (UBR904) Router
When i open my pc webcamera software AMCAP i can't see anything except for the black window...
Make sure that the matching drivers for the operating system used are installed. Check if the webcam is connected on your PC's USB port. Also, try connecting the webcam on other USB ports on your PC. The problem is either on the USB port or the webcam unit itself. Please reply if this has helped you.
Oct 19, 2009 | A4tech PK-635 Webcam
Webcam isn't detected
reconnect webcam usb port, then restart your PC. then, attact usb port again, try to attach first at front usb port of your CPU, if stil doesnt work, attach your webcam at the back usb port of your CPU.
Hope it will work.
Thank you.
Jul 30, 2008 | Microsoft LifeCam VX-1000 Webcam
Webcam
For pluging the Webcam you need to have USB ports.
You need to install the latest service pack available for your OS
You had to install the USB 2.0 drivers for supporting the cam
Install the drivers of the Webcam
Restart the System
Now Plug the webcam usb connector to any port of the motherboard
Let me know if your problem is solved and rate me as FIXYA!
Apr 29, 2008 | Computers & Internet
Open Questions:
See all Linksys by Cisco Linksys E3200 Dual-Band N Router Questions
Linksys by Cisco Linksys E3200 Dual-Band N Router w/ USB Port Logo
126 people viewed this question
Top Linksys by Cisco Computers & Internet Experts
ka4iup
ka4iup
ed_coyle
ed_coyle
Are you a Linksys by Cisco Computer and Internet Expert? Answer questions, earn points and help others
