Question about Video Game Consoles & Games
Clutch won't start
    Problem Solver:
  • 5 Answers
Try lightly hitting it a few times then if that still didn't work you should blow into the open port 3 times very hard. Mine was not even turning on and i did what I said and now it works!
Posted on Oct 29, 2012
Vw super beetle won't start after sitting for a few days. After I arc the solenoid, it will work.
If you put battery voltage to the starter solenoid &
it works & the starter works,then the solenoid control
circuit has issues
Fuse,ignition switch,neutral safety switch,clutch sw
& such, depending on what the car has
You could try switching relays but doubt that is an issue
Mar 11, 2013 | Cars & Trucks
Im thinking about buying a 1997 vw golf gl, guys says he's replaced the clutch once and still has problems, also he says the car wont start without fixing the clutch first. could it also be an el
I have no idea why your even asking any questions
about that VW
Replaced the clutch & still has problems---so you want to
buy someone elses problems?
Car won't start-- so you can part with your money & get
a car that you can't even start?
Could be electrical or something?
Your going off what the owner said---Ya & why is he
selling it--because he can't afford to or figure out how to
keep it going?
I know money may be an issue but you don't buy a 16 year
old car regardless of condition ,not even if it was free ,I wouldn't
take it.
Do you know anything about VW's or have a college degree
in automotive technology?
Oct 04, 2012 | 1997 Volkswagen Golf
2000 jeep wrangler wont start
If it won't crank, check clutch safety switch and cables for the starter.
If it cranks but won't start, you'll need to find out if it is ignition or fuel to know where to look next.
Jun 26, 2012 | 1994 Jeep Wrangler
My car will not go into gear unless its started and already in gear. Ill pull it outta gear and won't go back in while running.
Your transaxle will have to come out & new parts installed,
like synchro rings
You should be able to push in the clutch & shift thru all
gears nice & smooth,with no engine running.
That said I wouldn't rule out clutch issues also,but not
for the shifting issues.
Jun 02, 2012 | 1990 Ford Probe
1993 nissan pick up won't start
Possibly a bad connection on the positive side coming from the battery or a weak ground. Check where the leads join the terminal clamps. Has the battery been verified as good? It doesn't take a lot of amps to run lights but it does to turn over the engine. Jump starting it does not require a fully charged battery.
May 01, 2017 | 1993 Nissan Pickup
Clutch won't release
Start with inspecting the clutch handle for any obstructions or rust.
Lubricate the clutch cable at the handle.
Follow the cable down and look for and pinching or damage.If you can follow the end of the cable to the actuall clutch mecaniism, inspect the area for clearance.
If you can disconnect the cable from the clutch mecanisim and test the clutch handle to see if the cable moves freely.
Manually try to engange an clucth with the engine off.
If it won't move, time to diassemble the clutch.
Apr 07, 2012 | 1996 Suzuki VS 1400 Intruder
Why does the 30 amp circuit breaker behind the battery box on my 1990 fatboy click once when i push the ignition button? The bike won't start.
Try to reset the circuit breaker. also check for an earth fault on the starter motor .If this is not a circuit breaker and is a relay, you should make sure everything is ready for a start, (ie : in neutral, sidestand up and clutch in and that the battery is charged.) the neutral light being "on" doesn't mean it is in neutral. I hope this helps.
Mar 08, 2012 | Motorcycles
Husqvarna Model 51 won't start. Was running fine and has never had a problem starting (owned since new, 14+ years). Chain slipped off. Fixed and then saw wouldn't start. Good bright spark &...
If you have a good spark, and there is fuel at the plug, the only things to stop it fireing up are a sheared flywheel key knocking the timeing out, or the engine has low compression due to wear or damaged piston and ring.
Sep 07, 2011 | Garden
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
