Question about ASUS AC Adapter- Universal Notebook AC Power Adapter (NBACA407D2) Power Supply
My ac adapter heats up & gets extremely warm.
I own an Acer laptop.
    Scholar:
  • 96 Answers
As long as it doesnt burn your hand or start smoking ...don't worry about it. All laptop "bricks" get hot .... no cooling inside there ...
Posted on Jan 03, 2009
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
My Acer aspire 5750z wont turn on. I have plugged the AC adaptor in and all I get is a nlue light a the from of the laptop. If I take the battery out adn then plug in the adaptor, I don't get an
I have several starting problems with my Acer Aspire. To start with,my On Switch doesnt work so I removed the strip cover and use a matchstick (the non-red end) to push the round black dot in a small square at the extreme top right- hand corner above the keypad. Sometimes it's my adapter lead which works with other laptops so I figure it must be the laptop connection. I keep wiggling the adapter lead close to the laptop connection and push it in hard. My lead is the rotating kind so I try very hard not to move it once connected. Also because I"ve removed the start cover. I have to softly clean the connectors at the top lefthand side and the right.
Hope one of these things help you and you don't have all three problems as I do.
Jan 04, 2013 | Acer Aspire 5920-6727 Notebook
My Acer Travelmate 7530 does not want to start up. Switch on button lights up green
Here below is possible cause and troubleshooting steps of laptop that can power on, hope it may help:Possible cause:
AC adapter failure.
Power jack failure.
Motherboard failure.
Possible troubleshooting steps and repair solution:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
If you are sure that your laptop charger is malfuction, just get a new adapter from chargerbuy.com:
http://www.chargerbuy.com/replacement-acer-travelmate-7530g-ac-adapter-19v-90watt.html
Oct 28, 2012 | Acer TravelMate 7530 Laptop Charger...
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
I have an acer 5520 laptop,it has started shutting of without any warning even though plugged in and fully charged
Causes:
1. Overheat
Most cases this is caused by a over heat where the system fan gets blocked or there is not enought air flow, this can damage the system cpu.
Other known causes
AC/ adapter needs to be replaced some case were found that the ac adapter would be the cause as well it would be something to have checked out.
Now if the system shuts off without the ac adapter and its running on the battery as well you might want to look at the overheat issue.
thanks for using fixya please do be considerate and post you ratings and feedback for your answer today.
Aug 31, 2010 | Acer Aspire 5520-5908 Notebook
..switch-on problem
remove the battery , take all the external device out , disconnect the ac adapter , then press and hold down the power button for 1 min then plug the battery and power adapter try to turn on the system if it does not turn on check with a different power outlet , check whether the ac adapter is warming up .if its not warming up that means its the ac adapter problem
Jul 04, 2010 | Acer Aspire 5050-3242 Notebook
Acer laptop Aspire 7000 does not power on
If the laptop does not power up (not a slight sign of power flowing through it) even if the AC adapter is plugged into it, here are the possibilities:
1. You AC adapter might be broken and need to be replaced. Some AC adapters have a light on it to signify that there's power flowing from the power outlet to the power cable.
2. If your AC adapter is working fine, maybe your power supply is broken. If your laptop is with in warranty, have Acer replace it. If not, find a repair center who does.
Apr 10, 2009 | Acer Computers & Internet
Shuts Down
is the bottom of the laptop extremely warm ?
the fan and heatsink may need cleaning as it could be shutting down due to heat (thermal) issues.
Robert
Sep 08, 2008 | Acer Aspire 3000 Notebook
DV1000T chip PC87541V-VPC is extremly oveheating and freeze keybord
I do repair laptop for 5 yrs and I have a lot of problem with acer motherboard overheating with this chips 87541V like aspire 5580, aspire 3680 and other model...
Im sorry to those who buy ACER good luck... Acer laptop is good within one year before warranty expire.
Feb 26, 2008 | HP Pavilion Dv1000t (ED338AV) PC Notebook
Computers & Internet Logo
426 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
