Question about Dell Inspiron 5150 Notebook
Dell Inspiron 5150 will not turn on or charge.
  • ramon_fierro Jan 05, 2009
    C'Mon man. I'm looking for solid help, not just a general link.....
  • irish2009 Jan 09, 2009
    ac adapter and battery - push pwr btn battery led flashes pattern 5 times: yel-yel-yel-yel-grn
    battery only - push pwr and pattern a little different, but still not start
    ac adapter only - rush pwr and single flash of pwr led (grn) and bat led (yel), no start
    ac adapter looks good, center pin seems fine, get 19.5 volts from OD contact to ID contact
    opened case, adapter jack looks good, did not see any burned components
  • 3940 Answers
SOURCE: hi there, need help with
If you can see faint images on the LCD and you can connect an exrternal monitor and get a normal display, the issue is a failed LCD backlight
Posted on Jan 19, 2009
ComputerGirl
  • 85 Answers
SOURCE: Dell Inspiron 5150 power jack is bad
Replace the computer if you have to, replacing the jack would damage everything in the small computer, and oddly you have the same laptop as the one im using to type this
uh oh im rambling
well replace the adaptrer jack,motherboard
-CG
Posted on Jan 22, 2009
  • 16 Answers
SOURCE: Dell Inspiron 5150 Will not turn on......
First off start with cheap, Replace the external powersupply, (the ac power cables and company)
Second, Replace the battery. However if it dosn't show the lights atall when it's plugged in it must not be the battery. Because even without the battery a light should come on saying the laptop is plugged in.
Finnaly what I think the problem probably consists of:
You most-likely need to get your computer repaired by someone, There's mostlikely a fault in the internal power supply. that charges the battery. I'm guessing maybe a little fuse or something popped and you need it replaced. But best get a professional to do it instead of someone who knows nothing.
Posted on Apr 29, 2009
freetek
  • 5568 Answers
SOURCE: I need the schematic diagram of the dell inspiron
There is no such thing as a schematic for motherboards; if there was one that wasn't proprietary, it would be about the size of your living room, there are literally millions of components involved.
The best you are likely to find is a block diagram of the board with a few discrete components shown such as capacitors a a backup battery.
The board layouts are generally available from the board mfr.s and your motherboard probably was not designed or made by Dell.
If the board is in a working unit, you can download Belarc Advisor (free) which will give you excruciating details about your system, including the board mfr. and model number:
Belarc Advisor
If the board isn't functional, Dell might tell you who made the board or there may be a manual available for the system that contains this info.
Posted on Oct 07, 2009
  • 14 Answers
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
Posted on Oct 28, 2009
DELL INSPIRON WILL NOT ACCEPT WINDOWS 7 i GET ERROR n0_MORE_IRP_STACK_LOCATIONS
Was the hard drive contain any previous operating system? If it was, then you need to chose "Delete the volume" and "Format", and let's see the result after you reinstall the Windows 7.
Mar 04, 2014 | Dell Inspiron 5150 Notebook
Blank screen on start up. No dell logo. Only
have u tried resetting it (u may loose it all)
Apr 14, 2010 | Dell Inspiron 5150 Notebook
How do I remove a dvd rom in inspiron 5150 ?
Turn it over and you'll see screw that hold the DVD in. Use a pin to open the DVD rom and pull gently after removing the screw.
Aug 03, 2009 | Dell Inspiron 5150 Notebook
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Jan 03, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 no power, no lights
it could be that the ports where you plug in the charger is damaged. if you have an identical or a known good battery that is charged, try to install that and check if it works. you need a motherboard replacement if the system works with a charged battery.
Sep 24, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 5150 contact problem
Without looking at your laptop, it is hard to tell.It could be a bad solder joint or loose part inside.
Here is the manual for your 5150:
http://support.dell.com/support/edocs/systems/ins5100/en/sm/index.htm
You can look at the place where you apply pressure, and should be able to tell what the problem is.
Jan 04, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Notebook Logo
236 people viewed this question
Alun Cox
