Question about Sony Cyber-shot DSC-W55 Digital Camera
My camera has never been dropped why isn't my flash working?
  • jlapread Jan 04, 2009
    it didn't work but thanks anyway
    Scholar:
  • 51 Answers
Hi jlapread
If your camera is giving you a `E91` error on screen it could be a faulty flash module and need replacing at a Sony Service Center. Contact your dealer for info.
But, before you do that try steps 1 and 2 below.
Here is some things you can try:
1. If it is only a setting you can select the `green` camera for auto shooting and then press the `UP arrow key until the flash sign is shown on the screen. The screen will also say `Flash On`. Take a picture to see if it works.
If not proceed to `2` below.
2. Press the `Menu` button.
First select the `Green` camera on the selection knob.
Scroll with the right arrow to the little toolbox picture.
Once in the setup menu scroll down to the toolbox picture with a 1 under neath.
Press the right arrow arrow and then scroll to the `Intialize` option.
Press the right button and select `OK`.
Press the middle button on the arrow selector.
Camera now wants to know if you are sure, select ok.
You will now have to enter the date again and setup any `Program` settings you might want on the camera.
Now take the camera into a dark room - as it is now on `Flash Auto` and test to see if the flash works.
If none of these helped you, you can take the camera to a repair agent and get it fixed. I have replaced numerous of the flash modules at approximately a quarter of the cost of the camera.
Hope this information helps you.
Good luck
Posted on Jan 04, 2009
  • D&L Services Jan 06, 2009
    Sorry to hear that. :(
    You`ll have to take it in for repairs then.
    Kind regards
My nokia x6 camera flash isn't working anymore, i restore factory settings then the flash of the camera isn't working... plz help
This can be a hardware issue, failure of the circuit, the flash unit or the LED. In this case it is best to take opinion and support from Nokia care unless you are fully equipped to open and check and evenso the spare could be another issue.get estimate and proceed
Jun 28, 2012 | Nokia X6 16GB Cell Phone
Flash for mamiya 7
As with most cameras, the flash for a Mamiya is universal. Any flash with a hot foot connection will fit onto the camera, and function on the camera's shoe mount. You may alternatively use any flash which has a PC sync cord to plug into the PC sync socket on your camera, it just depends on whether you want to use a camera phycially mounted on your camera, or an off-camera flash.
The flash shoe on the Mamiya 7 isn't an "intelligent" type, meaning it only has the standard single contact and doesn't communicate any exposure or other information between camera and flash, so even the cheapest off the shelf shoe-mount flash will work just as well as the most expensive. Even specialized dedicated Nikon, Canon, and other brand "dedicated" flashes with multiple contact pins will also work, only the functionality of the information communicated through those other pins will be lost.
Sep 16, 2011 | Mamiya 7 II Medium Format Camera
When I am trying to take a picture and press the button to so, I see an "err" and a battery (the batteries are new) message that will not allow me to do so. I have tried taking the battery out...
On these cameras, if you're using ANY of the auto modes (P, A, S on the dial), the lense must be set to the lowest aperture setting (the highest number). Check to make sure this is the case. If it isn't, that's most likely your issue.
If you're using a non-CPU lense, this camera can only be used on M(anual) mode on your dial. If you haven't changed lenses this isn't likely an issue. If however you're using a new (to you) lense, this is a possibility.
According to the manual, the only other possibility is that your attached flash isn't set to the proper setting when using "P" mode. In this mode, the attached flash MUST be a Nikon dedicated flash unit set to TTL mode, otherwise fEE flashes with a little lightning bolt symbol. If you're not using a flash specifically designed for this model, remove it and try again. If you are, cycle the mode button on the flash until it reads "TTL" on the flash's LCD panel.
The manual makes no mention of fEE (error) and the battery indicator blinking, so these are the only things I can suggest with the information given.
Aug 19, 2011 | Nikon N75 35mm SLR Camera
My flash isn't working, I read the manual and did everything it said. Still nothing. Any suggestions? I'm new to any camera other that a point-and-shoot.
"My flash isn't working, I read the manual and did everything it said."
Hmmmmm .....
What does the screen show?
Is the camera on AUTO?
Last resort I guess is to go where you got the camera and ask them.
Jun 16, 2011 | Fuji FinePix S2 Pro Digital Camera
Flash isn't working
check the settings on flashmode if its ON
flash bulb might be busted and need a replacement.
Jun 08, 2011 | Nikon COOLPIX S570 Digital Camera
I cannot get the flash to work?
Most of the time, cameras have a small button located on the top, or near the other buttons that enables the flash. If there isn't one, try looking in the options for a flash setting and enabling it.
May 04, 2011 | Praktica SlimPix Digital Camera
Flash wont work
You need to take it in for repair...some cameras can be dropped with minimal damage but not yours.
Oct 08, 2009 | Nikon COOLPIX S200 Digital Camera
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
37 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
