Question about Frigidaire Affinity ATF7000EG
Washer is stuck on delay start.
My washer is stuck on delay start and wont work. i pressed cancel and unplugged it. no luck, can anyone help?
  • Anonymous Mar 13, 2009
    No matter what button I press, it just advanced the amount of time for delayed start. Help please!
  • 1294 Answers
SOURCE: blinking lights and failure to start
Suggestion: 1 Press and hold down 'spin' & 'dry' buttons to unlock controls. 2 Have u overloaded the machine with clothes? Reduce load. 3 Try 'spin' only after putting the clothes. Then put off machine & continue with main cycle. Three suggestions here........ What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
Posted on Apr 16, 2007
Benimur
  • 6966 Answers
SOURCE: WASHER WON'T START
For some unknown reason(s) the Live Session/Chat window closed. I hope that the two buttons resolve the issue, otherwise, pls click on "Ask Me" for a follow-up solution.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 05, 2008
joboo1
  • 257 Answers
SOURCE: washing machine won't start. when hit start 0' displayed
Hi, Unplug the unit from AC power for 30 seconds to 1 minute, This should reset it back to the defaults. Good Luck!
Posted on Feb 08, 2009
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
SOURCE: Frigidaire F/L Washer - Delay Start will not reset?
I had this EXACT problem this morning and ended up calling the Sears Home Central Team out (I have an extended maintenance agreement). This is an error code that CAN BE RESET by the end user (you and me!) and doesn't need a repairmain. Here's what you do:
PRESS AND HOLD the START and CANCEL BUTTONS.
The four lights above the START button will begin to flash.
Continuing holding the START and CANCEL button and "spin" your wash selector knob to "SPIN".
Release the START and CANCEL buttons and Press the START button.
This will RESET the error codes within the system and allow you to "cancel out" of the DELAY START.
IF the error codes are "bad ones", then the system will stay locked and you'll need to call a repairman; however, this "fix" should work for MOST of the routine system error codes.
Worked on mine and we're a happy washing family once again!!
Posted on Aug 26, 2009
How do I turn off delay start on my Frigidaireaffinity double loader
Good Afternoon Norma Eggenberg, thanks for your post!
I understand that you would like to turn off the delay start on your Frigidaire Affinity washer. Typically, to remove any type of feature you should be able to press the cancel button and it should revert back to the original settings. If this does not help correct the issue I would recommend resetting your washer. To perform a reset you would need to disconnect power by either unplugging the power cord or flipping the household circuit breaker off for ten minutes. I hope this is helpful. -Matt
Nov 08, 2014 | Frigidaire Washing Machines
How to cancel delay start
Press the Delay Start button several times until the displayed delay start time is cleared or reads "00". Unplug the machine or flip the circuit breaker to the OFF position for at least half an hour or so to forcibly reset the control if pressing the Delay Start button does not alter or clear the displayed delay start time.
Nov 09, 2010 | Frigidaire ATF6000ES Front Load Washer
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
The 8-hour delay will not reset
You can try this is you want. I can't promice you yhat it will work but it might be worth a try. Make sure the washer is on Press and hold the "SPIN SPEED" and the "SOIL LEVEL" buttons together, continue holding the buttons until a signal sounds then release them. This should reset your washer to the default factory settings.Hope it works for you. And you might also try unplugging it and see if it will reset it. GOOD LUCK !!
Feb 17, 2010 | Frigidaire FTF2140FS Front Load Washer /...
Kenmore HE3 stuck in delay cycle and won't unlock or cancel
YOu more than likely have suds in your washer, or an extremely unbalanced load. push the pause cancel button twice, that should unlock the washer. open the washer, and look inside. Is there a lot of suds, or towels that are tangled up? If so, add some fabric softener to the wash tub and do a rinse drain spin (for suds) for the extremely unbalanced load, take the towels (or what ever load you are doing) and put about 1/2 of them in. I have the same washer and have experienced this "problem" once or twice in 7 years. And those were the two culprits. Hope that helps
Jul 30, 2009 | Kenmore Elite 45986 Front Load Washer
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine won't start. when hit start 0' displayed
Feb 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
I need to cancel a washing cycle in the middle of the cycle.
usually pressing PAUSE/CANCEL twice cancels the cycle and shuts it off allowing you to then re-start the cycle. If not try unplugging it and see if it resets to allow you to start cycle again.
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Nov 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error message wont go away
unplug machine from mains for 5 mins then try it. close IRE
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF7000EG Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
