Question about Dell Vostro 200 PC Desktop
It won't allow me to install my Nancy Drew Game?
It won't realize the game CD when I place it inside; I have to go straight to adding programs and attempt to do so. The moment I click add a new program, it begins to run slower and then when it identifies the file, it says to select the installation file or program- But one is already there typed in automatically as a default so I use that.. But then it completely freezes afterwards! The strange thing, is that it works perfectly fine with all my other games, it even notices them and installs without having to go to the Adding or Removing programs. Is the problem the computer, me or the cd? And what can I do to fix this? Any tips or tricks would be greatly appreciated.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
You need to completely uninstall the software and try to reinstall. If the clean install does not work than most likely your system doesn't meet the necessary requirements or the software is not compatible with your system.
Posted on Oct 29, 2012
techniwiz
  • 275 Answers
SOURCE: I can not get my cd drive to work.!
all you need to do is go to the device manager
uninstall the cd/dvd drive
uninstall the ide secondary as well as primary channel and make sure you unistall the secondary channel first coz normally the primary channel is ur harddrive and if u uninstall the primary first the system will hang you will have to shut the system down forcefully
than restart the system and the system will detect everything again and issue should be resolved
if no than go to the support.dell.com ... click on drivers and downloads....select the option enter ur tag... thats the service tag which is located on the back of the system its a seven digit alpha numeric code located on the white lable with barcodes ...and than select ur os by default the operating system which will be selected would be the one you got with the system... click on cd/dvd ...download the firmware which is applicable ...
you will find the model of the drive in the device manager in the cd/dvd option and after downloading it install it and than restart the system and this should resolved it ...
if that doesnt help it means the lens of the drive are weak u will have to get a new one
so if the system is under warrantty get a replacement from dell
technical number is 18006249896
Posted on Nov 19, 2008
Geekman
  • 32281 Answers
SOURCE: Dell Dimension 2400 - Adding second HD
I presume that the hard drives are ATA drives, and if the WD and Maxtor are installed on the same IDE cable then the boot drive, the WD HD needs to have the jumper set to Master or Master with Slave drive, and the Maxtor needs the jumper set to Slave drive.
If the computer on boot up doesn't recognise the boot drive the move the jumper to the CSL setting.
If the Maxtor is on the second IDE cable it does not matter if the jumper to either Master or Slave provided you do not have anything else connected to this cable. If you have a CD or DVD connected to the second IDE cable as well as the Maxtor HD then you need to check the devices on this cable (ie. the jumpers) are not set the same on both devices.
On boot up go into the BIOS and check that the master and slave devices are set to Auto (detect).
You should after booting up now see both hard drives and any CD/DVD.
The data on the Maxtor drive would include your original Windows and programs and data, you would need to remove these redundant files and programs to recover disk space.
If you can see on boot up all the hard drives and CD/DVD (as master and slave drives) but if you do not see the Maxtor drive from My Computer, then you need to delete the partition on the Maxtor drive, create a new partition, and format the drive, in this case you will not recover any of your original data.
To do this, you need to go to the Control Panel, Then Administrative Tools, then Computer Management then Disk Management. Right Click on Disk 1 (it should show a 80 Gb hard drive), delete the partition, then it would show this as an unallocated drive.
Right Click on this drive again and create a primary partition, follow the instructions and format the drive in NTFS file format.
Posted on Nov 29, 2008
Ticodude
  • 53 Answers
SOURCE: Roxio Media Manager continues to try to install
After reading your problem I came across some interesting references about roxio and agent.exe.
Seems agent.exe is used by many programs to update themselves over the internet, and it was giving a lot of people headaches by using 70% or more of their CPU, like yourself.
So, I wanted to send you a few quick thoughts on how to hopefully fix your situation.
First, there were complaints about stuff trying to install itself on and on, and it was because there were command lines in the STARTUP MENU calling upon them to install every time windows starts.
So to try to fix this if its happening in your case........
Go to start>run>and type in msconfig and click ok.
Now click startup and uncheck these items.
issch
ISUSPM
'ISUSPM Start Up'
'ISUSSCheduler'
Adobe Reader Speed Launcher
Quick Time Task
Igfxtray
HotKeysCmds
MSMSGS
WMPNFCSG
COMMUNICATOR
PERSISTENCE (igfxpers)
DLA
Then click apply, then ok and restart your computer.
When windows starts, you will see a window saying that changes were made to the configuration utility. When you see it, click on the little white box saying not to show this any more.
And if you really miss not having something you unchecked, you can always go back there and recheck it!
Maybe now you will have the chance to purge all things Roxio from your system.
Best of luck!!
Posted on Jan 02, 2009
  • 408 Answers
SOURCE: I have a Dell Dimension 4550 running windows XP
sounds like you have issues with your hard drive.  go to start>run.
type this in without the " "
"cmd", hit ok.  a black screen pops up.  type "cd.." and hit enter.  type in "cd.." and hit enter again.  type "chkdsk c: /f /r".  It will say the drive can not be checked, it is in use.  hit "y" to schedule a check at boot up.  type"exit" and reboot your computer.  let me know if this helps.
Posted on Mar 07, 2009
stabelabel
  • 51 Answers
SOURCE: Game Engine Direct Sound Create 8 failed
ether that's your game engine drive software or software for your game sound drive package. it's asking to install? to use that software? it's using that software? you can go to options check selection if it an option select it if available to use it may even have some of it's own options loaded in the game options.
check it out.
please take if this help or give more input for feed back.
good luck
Posted on Mar 21, 2009
My Nancy Drew computer game won't work
Hi longview924,
Unfortunately there is no way to make that game run on your mac. Your mac uses the older powerPC architecture (all G3, G4 and G5 macintosh machines use this architecture) but the game requires that you have a mac using the newer intel architecture.
I found the details of the system requirements here:
http://www.buzz99.com/1167/nancy-drew-trail-of-the-twister-system-requirements/
Intel and PowerPC processors are very different in how they work (Intel chips are CISC chips and powerPC chips are RISC chips), which is why there is no way around it. This is also the reason why apple dropped support for the powerPC architecture in mac OS 10.6 upwards.
Without meaning to sound harsh, it may be time to consider an upgrade - macs are very expensive but the intel macbooks are leaps and bounds faster than the powerPC range :)
Jul 03, 2012 | Video Game Consoles & Games
Hi, The game, Nancy Drew: Danger by design, doesn't work in my laptop. Every time I try to play the game, the screen freezes but I can hear the music at the back ground. All the other Nancy drew games...
The first thing you should try, is to update both JAVA and Flash. If it uses those, that is likely the issue.
Here are the links:
http://www.java.com/en/download/inc/windows_upgrade_xpi.jsp
http://get.adobe.com/flashplayer/
Be sure to uncheck the boxes that install toolbars. Also, it wouldn't hurt to make sure that Windows is up to date. Click the Start button, click All Programs, and then click Windows Update.
Jul 11, 2011 | Her Interactive Nancy Drew: Danger by...
I have windows 7. When i try to play Nancy Drew: Danger by design a box pops up requesting i insert disc 1. There is only one disc! It seems to work ok on windows xp. Ca you suggest anything to make it...
From the Nancy Drew web site:
Windows Vista/7 Support Installing older games (#1-13) with Windows Vista/7.
While our older games are not completely Windows Vista/7 compliant (notably games #1-13), there is a workaround which has been successful for most players. Please take the following steps to manually install.
If you had previously installed, uninstall the game and then delete all remaining game file folders from your computer, including emptying them out of your Recycle Bin. These files may be in one of the following locations:
C:\Nancy Drew\
C:\Program Files\Nancy Drew\
In your Documents folder: C:\Users\Username\Documents\
Once this is done, make sure you're logged on as an Administrator for your computer and manually install by taking the following steps:
1. Go to your "Documents" folder and create a new folder. Rename the folder with the title of the game.
2. Insert game Disk 1 in your disk drive and open "Computer" from the "Start" menu.
3. Double-click on your CD-Rom/DVD drive, look for a Setup or Setup Launcher Installshield file. Double-click this file to start the installation process.
4. When install asks what directory you want your game to install to, click "Browse".
5. Navigate to the game folder you created by selecting "C:" drive, then "Users" (or User name), then "Documents", then select the game folder.
6. Continue forward with the installation process, when asked if you want to install DirectX, check "No, I will install myself".
7. Upon completion, uncheck the "Play Now" box, click finish and exit setup.
For game titles #1-5, follow these three additional steps:
1. Right-click the game icon that is now on your desktop, select "Properties".
2. Under "Properties", click on the "Compatibility" tab.
3. Check the "Run in Compatibility Mode" box and then select "Windows 98/Me" from the drop-down menu.
You should now be able to open and play the game. If you installed an older version of DirectX with the game, please go to Microsoft's Download Center to download and install the latest version of DirectX for your version of Windows.
Aug 03, 2010 | Computers & Internet
My Nancy Drew 'Secrets can Kill' game wont up load when ever i put it in. I go to my computers 'Run' but i don't know what to type in!! a little help please :(
Hi!
Go to "My Computer" icon that is on your desktop, double click on that, and you should see the icon of your game under the correct CD Rom letter.
Double click, and it should start.
Good Luck!
Nov 15, 2009 | Her Interactive Nancy Drew Secrets Can...
Nancy Drew game wont work.GRrr...
Hi, when i play some of the Nancy drew games the arrow or magnifying glass is very jerky to where I can really paly the game. Any ideas?
Sep 01, 2009 | Microsoft Age of Mythology: The Titans for...
Im trying to play nancy drew secrets can kill, and its all instulled. however when i click on the shortcut to play the game i get a black screen with a box in the middle that says ''nancy drew is unable to...
if you desperately want to play nancy drews that have that problem, there is a way but this way youl have no sound but the game will still play.
Go into the directory where you installed the game and then o into the game.ini file. it should open in a notepad.
go to sound system is active=1.
change the 1 into a 0. then enjoy. the game may have no sound but its still the game ayyy
nd dont try and change the volume or else the game shut down.
Aug 31, 2009 | Her Interactive Nancy Drew Secrets Can...
Incorrect path to INI file
install the game and when it gets to the install on C:\nancy drew click browse and choose program files then install there the game will then run but requires the cd to be in the drive
Jan 01, 2009 | Her Interactive Nancy Drew: The Secret of...
File problem
I Pulled it out of My ****.. Silly Me.. It's A good thing too because i probably would have been old and gray before i would have gotten any help with your website.. Keep on Truckin.. ASP
Dec 28, 2008 | Her Interactive Nancy Drew: The Secret of...
Dell Vostro 200 PC Desktop Logo
42 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
