How to fix date in 5123 EQS-500
Hi, I am having some problem in 5123 eqs 500. I read the manual my home zone is set to Dhaka. In section "To change the current date settings" setting the year in 10 (ten digits) then 2 (one digits) then put month in Oct & date 30 is given. after pressing A and exiting that it shows me the current DAY is "Friday" but it should be "TUESDAY" how to solve this problem? it will be a great help if someone give the solution.
  •  Debashish Debnath Picklu
    is there any way to reset my watch! thn I will try to configure it again!!! Previously it was configured correctly. When I traveled to India & tried to setting the time I misplaced the original settings which was correct! :(
marsrover
  • 682 Answers
SOURCE: pioneer spec 1 and spec 2 hook up with RG 2 processor and audiosource eq 1
preamp out---------to equalizer in-------------equalizer out----to amplifier in-----------amplifier out----------to loudspeakers.
Posted on Jul 23, 2008
welcomejee
  • 10594 Answers
SOURCE: manual for dbx eq system set-up
Check out 12 Series User Manual might help you.
Posted on Oct 09, 2008
arthurroger
  • 170 Answers
SOURCE: Peavey Bass Amp TKO115s
Start with a clean setting - zero cut and zero gain on the Eq. Play a song close to the amp, and then move away, playing the same notes. Do you still get the distortion? Change lower the input gain and repeat the test. Lower the output gain and repeat. Are any outboard distortion pedals in the mix, such as overdrive? Eliminate them. Run straight through from your axe to the amp. Check for any distortion settings. Set everything including reverb to zero. When the distortion disappears, this is your base setting.
Change only ONE parameter at a time. When the distortion comes back, you have found your problem.+
Posted on Dec 03, 2008
gokomets
  • 120 Answers
SOURCE: I am looking to set up my Kef 107 /2 with Kube EQ
Most eq's connect throught the tape monitor jacks "in/out" and you select tape 1 or 2 when using the eq.
Posted on Apr 16, 2010
oldgoldguy
  • 69 Answers
SOURCE: how do i change my casio eqs 500 date and time
back of watch is a set of numbers in a rectangle, look up manuals in casio website
Posted on Mar 26, 2012
HOW TO SET TIME AND DATE ON LG FLIP PHONE 441g
Check your manual for guidance. How can anyone help without the model number? Duh!
Sep 19, 2017 | LG Cell Phones
2 hours back?
Severe shocks,drops or strong magnetic fields have as result the wrong indication of watch hands.Try to reset your watch by the hands "0 set" procedure following manual instructions.
Mar 18, 2013 | Casio Watch Edifice Eqs-500c-1a1er Man...
How do i change my casio eqs 500 date and time
Mar 25, 2012 | Casio Watches
I have a Fisher stereo.The amp is a ca871 the eq is a ca871 the casset deck is a crw870. How do I connect these components up.
The amp has tape rc out and pb. The eq has line in, line out, tape rec out, tape pb. The casset deck has line in,line out.
Ok, hook the amps RC OUT to the eq's LINE IN.
amps RC Pb to the eq's LINE OUT.
The tape's LINE OUT to the eqs TAPE PB
the tapes LINE IN to the EQs TAPE REC OUT.
on the eq, there should be a button to toggle between tape and source.
let me know if that works.
Jul 01, 2011 | Audio Players & Recorders
Hi, My Casio Edifice EQS-500C watch doesn't beep when I press "mode" button anymore. I did something wrong I guess when I was setting the time.
Hi as far as I know this watch model only beeps when you are configuring time and when you want to go back to time mode from any other one (chrono, world time or alarm mode) by pressing left lower buttom for a few seconds. It only beeps if you have set the alarm. It does not have light either. Hope this clarify.
Rafael
Dec 08, 2010 | Casio Watches
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
I am trying to work 2 equilizers together in my stereo set
My big Q is - 'Why are you wanting to use two EQs in the first place, when one will suffice. But that is not for me to ponder over. :)
How are you trying to hookup the EQs? I have my eq connected between my preamp and amplifier. The other common method is to insert the eq in the tape loop between cassette and amplifier/preamp. Then select the tape loop to put the eq in the signal loop. You then connect your tape player through the tape monitor jacks on the back of the EQ and select this option in otder to play tapes.
If you have two tape inputs, then you can insert one eq into tape 1, and the other eq into tape 2 and choose accordingly. Bear in mind that you dont have to use the tape in order to use either EQ in your system. Just make sure you are using one EQ or the other. If you attempt to use both, then you run into potential signal 'corruption' (i.e. loss of datta or signal pumping, depending on the frequencies enhanced/attentuated).
Dec 18, 2008 | Audio Players & Recorders
Mackee PPM808M 1200 How to set the equalizer
Each channel strip has its own 3 band EQ with knobs that effect the hi, mid, and low.
The mid is centered at 2.5kHz and gives you 12dB of boost or cut in either direction, the high gives you 15dB of boost or cut from 12kHz and up, while the low gives you 15dB of boost or cut at 80kHz and below. At their mid positions these knobs are flat (no cut or boost).
The PPM808M also has two 9 band graphic EQs in the Master Output Section on the front panel, Monitor EQ and Main EQ. These two EQs are the last thing in the chain before the signal leaves the mixer on either of these line outs (monitor line out, or mixer line out).
The 'Monitor EQ' effects output to the monitor speakers on stage (and power amplifier if the 'Power Amp Routing' switch is pushed in).
The 'Main EQ' effects the signal to the main speakers (or the mixer line out).
Each of these 'Master Output' EQs has a Rumble Reduction button which when pressed in engages a low-cut filter which rolls off frequencies below 75Hz and is designed to prevent 'stage rumble' from things like footsteps on the stage being picked up by stage mics. These filters are separate from the graphic EQs and the Main Rumble Reduction switch effects only mono channels 1-6 (not stereo channels 7&8). It also has no effect on the EFX to MAIN or the TAPE IN. The Monitor Rumble Reduction switch however does effect the EFX to MON signal.
Dec 31, 2007 | Audio Players & Recorders
47 people viewed this question
 Grubhead
Grubhead
