Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Reddy heater 50,000 shuts off after 10 sec - Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
3 Suggested Answers
  • 17 Answers
SOURCE: Reddy Heater 60,000 Model R60 only runs with top off.
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
Posted on Oct 15, 2009
jcameo7270
  • 675 Answers
SOURCE: my kerosene 50,000 btu reddy heater fires up for
There is a sensor inside that tells the heater that the flame is lit...if it doesn't "see" the flame it will shut down...this may be caused by the filter in the rear being clogged and it is not allowing the pump to produce enough pressure to ensure a good flame or the pump inside may have sucked up some debris and is now not producing the proper pressure required. Another possibility is that there may be enough dust on the sensor itself to cause it to not "see" the flame...if you take the cover off you can find this sensor...it will have 2 wires coming off of it and it looks like a photocell...it should be located just in front of the jet where the fuel comes out...a word of caution...the ignitor(and the spark plug looking thing) have very high voltage on them(around 5000Volts) so I would avoid touching these parts while in operation.
Posted on Dec 08, 2010
I have a Reddy Heater Pro110. It runs for 3 or 4 sec then shuts off. What can I do to fix it?
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
0\0\0\0\0\0\0\0\0\0\0\0\0\
Dec 23, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-50,000 won't fire, fan comes on for few seconds than shuts off
Here is a tip that I wrote that tells you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Sep 17, 2010 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have a 50,000 BTU, 0987539 that smells like it
make shure that you are using the proper grade of fuel and that therebis nothing blocking he airflow past the fan.
Jan 17, 2010 | Reddy R115DT Oil Filled Utility Heater
Reddy heater
Sounds like you need to adjust the airflow so that it is getting enough air to burn.
Jan 10, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Dec 21, 2009 | Heating & Cooling
Trys to start. Motor turns slowly (revolution in 2-3 seconds).
Either:
  1. the reset (safety control) is bad
  2. the photocell is defective
  3. both of the above
To test the photocell http://reddyparts.com/photocell_test_sp.htm
Nov 29, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
116 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Outback Jack
Outback Jack
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
