Question about Sewing Machines
I have a Kenmore Sewing Machine (model 158.17741) that has pattern cams. The problem is that I can not remove the metal cam.
I would like to use some of the 30+ (plastic) pattern cams but can't because I can't remove the metal cam. I have the original instructions/owners manual but it does not provide information on performing this task. Please help. Thanks.
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
louislevel_2
  • 374 Answers
SOURCE: how to use white cams
hi! there,
white cam plate are mounted on top side of your machine there
is shaft for mounting on figure the plate cover opening for cam,then adjust the dial for the neccessary cam designed.32e83f9.jpg
you have to replace the presser foot on figures.5af54f1.jpg this presser foot is more convenient to use on designed cam
the stitch adjustment should # 8 to # 12 just select w/c more convenient to yuo,dial tension set to # 3 to # 6.
have a nice day,don't forget to rate me,thank's
Posted on Apr 26, 2009
SOURCE: Kenmore sewing macine cams #1 (26841) and #2 (26842)
I have the set and will be posting on Ebay this week
Posted on Jul 13, 2009
Zenqi
  • 208 Answers
SOURCE: Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Posted on Jan 24, 2010
I have a sears kenmore sewing machine model 148-13100 where is oil needed?
If it is an older mechanical machine, 1-2 drops oil (ONLY fresh, good quality sewing machine oil) applied every place where metal rubs against metal. AVOID belts, plastic gears, CAMS. Slowly hand-rotate or wiggle the handwheel, watch where metal parts move against each other and apply a couple drops. Be sure to get the top mechanism, the side mechanism where the needlebar is located, and under the sewing surface, ie the feed dogs area. Also, move levers and dials and apply a couple drops where metal rubs metal.
Jan 05, 2017 | Kenmore Sewing Machines
Can't get seam former out
To remove the seam former (stitch pattern cam).
- Move your stitch selection dial so the white dot on the dial lines up with the red dot on the body of the machine. Then you pull the cam out.
It can be difficult to remove if the cam has been sitting in the machne for a long time.
Mar 13, 2014 | Husqvarna Viking 1
Can't get seamformer out
Mar 13, 2014 | Husqvarna Sewing Machines
My sears sewing machine cams wont work it just sews a straight stitch or zig zag. I wonder if there is suppose to be a spring to hold it closer so that it follows the pattern on the cam.
Yes there are springs and many other parts that need to make the stitch patterns. I suggest you take it to a qualified sewing machine repair shop. Often the pattern selector can be cracked, a linkage can be stuck or a dozen other problems will cause this.
Oct 12, 2013 | Kenmore Sewing Machines
Jan 24, 2010 | Sewing Machines
Bernina 707 Cam removal
take off the black metal bit that is above the pattern cam (4 screws). beneath you see 2 small screws, inside the metal frame, on each side of pattern cam. Take them out. Spin the pattern cam until you see one screw in the cam itself. Take that out too. Now you can push the splint out which holds the cam.
Apr 16, 2008 | Sewing Machines
Sewing Machines Logo
155 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
