Question about HP LaserJet 4345mfp Printer
Hp 4345mfp internal disk error
Internal disk not found - error message
marlen56
  • 110 Answers
SOURCE: Internal DRS error 1500:c0:3001
found this solution, maybe it also helps to solve your error.
Try and change OCR language
he was scanning documents with danish language to PDF and OCR language set to English. Received the same error, changing OCR language to danish solved his problem.
If not
go to HP support webpage:
http://www.hp.com/cgi-bin/hpsupport/index.pl
choose support and tr.. information option
enter your product name
and check if there is a fix published.
Success!
Posted on Aug 28, 2009
  • 59 Answers
SOURCE: When I try to scan a doc, i get an error message
>what operating system do you have on your pc?
>go to this link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1128296&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
.select your correct operating system, it will open a new window which says select software and drivers
>go to update tab and download and install critical update to correct pc to printer communication issue
>this update should resolved internal errors
Posted on Sep 29, 2009
  • 9 Answers
SOURCE: HP LaserJet 4345mfp won't scan, but it wil fax.
This may be related to 3 problems . 1st as with all 49.xxx errors update your firmware first. 2nd it may be related to a memory problem internal to the printer. Last it may be a problem with the email server you are sending to. To troubleshoot update firmware, then remove network cable and try to scan docs is as if you were going to email. If problem does not show check email gate way. If problem does shw up replacing your memory may be the next step.
Posted on Nov 11, 2009
SOURCE: top cover paper jam in laserjet 4345mfp
this problem can be a machanic one. most probably one sensor is blocked by a foreign matter causing it to read a paper jam. you will need to remove the toner and locate all paper path sensors. check wheter they are not blocked by paper clips or staples.
Posted on Feb 25, 2010
SOURCE: When sending document to my
When sending document to my HP LaserJet P1505, the engine scanner error message
Posted on Apr 25, 2011
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
Get message internal hard disk drive not
This may mean that your computer is trying to boot from a non-bootable drive. Try hitting f12 when you restart the computer and select which drive would have your OS on it. You want to change the boot sequence to diskette drive as your 1st choice. The order should be Diskette Drive, Internal HDD, USB storage Device, CD/DVD drive.
Apr 08, 2014 | DELL Inspiron 15 3520 Cnfg 2 Lptp 3Yr 2nd...
Internal Battery Error
Time to replace your laptop's main battery.
Dec 17, 2013 | HP Pavilion Computers & Internet
Engine scanner error (internal hardware laser scanner error) error message laser scanner
This means that the laser unit inside your printer has failed. It costs around 100 dollars for the part and it needs to be installed by a trained technician. Best idea is to buy another printer. Sorry.
Sep 29, 2013 | HP Laserjet P1505 Printer, Remanufactured,...
Error 41.3 on a 4345mfp
41.3 UNEXPECTED SIZE IN TRA 2
Dec 08, 2011 | HP LaserJet 4345mfp Printer
How to erase the hard drive on 4345mfp or how to remove it from the printer
For information about the HP Secure Disk Erase feature, see the HP support flyer or go to
http://www.hp.com/go/webjetadmin/.
Jun 21, 2011 | HP LaserJet M4345 MultiFunction Printer
I have a hp4345mfp on the display it is showing a error internal disk not found we do not have a hard drive can we turn off the hard drive thank you my email is
All HP MFP's have an internal harddrive and will only function as printers if that drive fails. You need to replace the harddrive. It is mounted on the formatterwhich is accessed on the back. First remove the sliding panel and then open the metal door. These are right where the fax and data cables plug in. You can replace the drive with almost any 2.5" IDE harddrive that you can find. The standard model will be either a 20, 30 or 40 gig, I have installed up to 160 gig drives with no problem. Do not order a drive from HP as they will charge several hundred dollars for a drive you should be able to get at any computer shop for less than $75.00. Be cautious removing the drive from the plastic mounts as they are easy to break.
May 17, 2011 | HP LaserJet 4345mfp Printer
As soon as I turn on my laptop a message says that the internal hard disk drive was not found and that I should reseat the drive.
Yes that is the first thing your should try.
When the computer cannot detect the hard disk or a boot disk then you get this error message. Please click on this link to determine the fault and solution to this problem :-
http://www.fixya.com/support/r6244569-no_bootable_device
Oct 18, 2010 | Dell Inspiron 1525 Notebook
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
HP LaserJet 4345mfp won't scan, but it wil fax. Error code "49.FF09 Service Error" keeps coming up
Ensure that you have the error message correctly written down, then go to the HP Web Site and ask them about this error, specifically in conjunction with that specific printer or all-in-one device. HP can help you find out why you are having problems.
Nov 07, 2009 | HP LaserJet 4345mfp Printer
HP LaserJet 4345mfp Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
