I need to know how to check the bulb in my Sony KDF-50WE655 DLP TV
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The lamp cannot be tested except to see if it comes on and stays on in the set when it is turned on---2,000 hour life is normal.
If a fault with the lamp itself the set should have the lamp light blinking or change color.
Some of these lamps will get rather dim just before they fail.
Posted on Oct 30, 2012
  • 395 Answers
SOURCE: Samsung DLP Tv
it's about 3000 to 5000 hrs. on the bulb this translates to about 3 to 5 yrs. of normal use. it can, however, be greatly reduced by the number of on/off conditions. lamps need to cool down that is why the fans run longer after shut down.
obviously if the TV doesn't turn on that can be lamp. weak or dim picture is another sign.
Posted on Jan 22, 2008
mistersony
  • 320 Answers
SOURCE: Sony KDF-50WE655 Was fine the picture went dim
Replace the lamp.Use an original Sony lamp. Next would be the lamp power supply and last, the optical block
Posted on Oct 18, 2008
  • 80 Answers
SOURCE: sony grand wega kdf 50we655 blue dots everywhere
The optical block is defective. Sony sometimes warranties these even after the 1yr warranty has expired. Contact Sony support and have you full model and serial number handy.
Posted on May 21, 2009
  • 80 Answers
SOURCE: help with my sony tv
The thermal fuse is located close to the front of the set just to the right of center, looking from the rear of the TV. Mounted near the lamp. Part# 191002393. Once you have the new part, it should not be difficult to find it in the set.
welcomejee
  • 10594 Answers
SOURCE: My parents have a Sony KDF-E42A10 42" LCD TV.
Yes, if lamp has not been replaced in last 2-3 years then it is lamp problem. If tv does not shut down and its standby light does not blink in red then lamp is cause of problem, replace it to fix tv issue.
Posted on Sep 26, 2010
I HAVE REPLACED MY BULB OM MY KDF-50W655 AND MY TV IS WORKING AGAIN, BUT I HAVE TRYED TO RESET THE TIMMER TO THE BULB THRU NMY CONTROL....BUT CAN'T SEEM TO MAKE IT WORK...
I have installed the new lamp and the the led power light comes on green and than turns flashing red. What is the next step in this repair?
Mar 21, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
I turned the tv on. The green power/stand by
Question shows its Sony KDF-50WE655 dlp tv that has lamp inside and it seems its time to replace lamp.
Did you replaced lamp in tv recently?
If not, replace it. Lamp replacement procedure would be written in user manual and please buy Sony original lamp for better result.
Thanks.
Mar 04, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
My LCD projection HD TV model KDF-50WE655 has an
Is your TV LCD or DLP? Encompass Parts shows your model to have Lamp with part number for lamp as A-1606-034-B which then means DLP ,which then it means you may have your light engine going bad which is called optics unit Block part number is
A-1084-660-A They do have them in stock Call 1-800-638-3328 or visit their website www.Encompass Parts.
Nov 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-50WE655 Screen has a blueish white area down left side
Your light engine is going bad
sony has an extended warranty for Sony Grand Wega 50" Televisions
contact sony and they will fix it
Apr 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Jan 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Kdf-50we655 dim picture and turns off and then back on
Symptoms shows that Tv requires new Lamp.
Lamp replacement procedure is written in user manual. Let me know if you need further info about Lamp purchase or need user manual.
Please buy original Sony lamp for replacement.
Jan 16, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony kdf 50we655
heat and dust are two major problems with this type of set.These set can get very dusty inside the optics and cause this type of discoloration .Heat can cause deteriation on optics and or optics cabinet parts .It is possible to clean the optics block for dust issues only but unless you know what your doing and know what areas not to touch inside optics block .Otherwise the block would have to be replaced..
Nov 12, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
