Question about Proscan PS60690 60" Rear Projection Television
What's your problem?RCA PROSCAN PS52800 52-Inch Digital High-Resolution Projection TV Monitor/Receiver, no audio
No audio out and no volume from speaker
    Top Expert:
  • Proscan Master
  • 14,553 Answers
Audio circuit problem and likely parts are no longer available due to age of set----some shops may tackle this set for repair or not..........
Posted on Oct 30, 2012
jomaru
  • 337 Answers
SOURCE: The video works perfectly but there is no audio
The best part is that you like the picture and that makes it worth repairing,before you call for an estimate tap on the side of the set and/or the jack panel to see if the sound comes back if it does react you are looking for a loose conection and the repair should not be expensive but if it does not react you might be looking at the stereo amp board and that can be expensive depending in your location,If you are familiar with tv service you can go as far as removing the back cover and taping on the chassis or in the area were the internal speaker wires conect to the chassis or the amp board but if you are not too familiar be safe and call for assistance from a servicer.
Posted on Oct 04, 2006
  • 16 Answers
SOURCE: ProScan 60 inch TV Problem
Have you had any luck with a repair or adjustment?
Posted on Jan 25, 2008
SOURCE: ProScan Projection TV PS60690 shuts off
replace the small 5G5A125V fuse in the back where the power cord connects the to chip
Posted on Sep 02, 2008
SOURCE: Proscan Projection screen warped
Just had mine do this same thing today. Looks like its time for a flat screen. Sucks to spend the money though :(
Posted on Dec 22, 2009
SOURCE: New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Posted on Jul 01, 2010
How do I get the sound from my TV to play through this system?
Most audio receivers have types and several inputs available . The TV will likely have only two types. One will be the standard Red and White RCA connectors. Others may not have the RCA but a 2.5 mm headset connector. Some TV's will have an optical link connection. And a few will have a digital connection. The digital is a single RCA type connector but of a much better quality than the vintage.
The digital and optical; are the highest quality and would be the first choice for best audio/surround/Dolby. The RCA Red and White is next. The 2.5 mm headset is the least desirable.
Some receivers are programmable for the optical and digital inputs. You would need to reference the receiver manuals to determine the setup. The default setup will work but a little trial and error may be required to determine what input goes to what device. ie the DVD might be connected to the TV input (can be a little confusing)?
After connecting the best quality output of the TV into the receiver it is necessary to go into the TV setup menu to turn off the TV internal speakers and I would set the audio output to fixed. The variable output setting can be confusing where both the receiver and TV can set the volume.. The volume will now be set where the receiver can control the volume and not the TV,
Nov 21, 2015 | JVC 3 Top Receiver Reviews, Rx-1010vtn,...
Where can I get an owner's manual for a RCA ATSC11 digital tuner?
On the RCA ATSC11 you can see the menu if you switch to 480i resolution and connect a video cable to the monitor output. Otherwise the menu is visible only on the digital output.
Dec 23, 2011 | RCA ATSC11 DTV Receiver
I bought a Sharp Aquos HDTV. Am trying to use a digital co-ax cable to run tv thru my reciever. I get no sound. there is only 1 place on each device to hook up this cable. Any suggestions?
I dont wish to assume that when you say receiver, you mean sattelite or cable. Since you may be trying to hook this up to a surround sound reciever...
Let me also clarify, if this is the case, the receiver needs to be turned on AND the selection signal device set to TV or AUX wherever it is you've connected the TV.
Now by receiver, if you actually meant cable or sat box, then the Ext antena from that service connects to that units ANT IN.
Then from there on that unit ANT OUT to your TV SIGNAL IN.
If you want the external surround sound and have the connectors for this. Then you need to send them OUT to the Stereo/Surround receiver TV IN.
Now having said that and assuming that your TV does not have the Red and White Audio RCA connectors... Your Sat or Cable box does... You connect those to the surround sound Receiver Audio IN
Hopefully you'll find this useful.
If this has not answered the situation. Please feel free to come back and provide all components your working with. Surround reciever, Sat, cable, DVD, VCR whatever etc. etc... I'd be more than glad to help you through this
Good Luck
Respectfully
Jun 10, 2011 | Audio Players & Recorders
How to hook up to hd tv
Use the highest resolution connection your HD TV will allow. This will usually DR570's HDMI connector. Most all digital video devices have one or more. The DR570 has an HDMI OUT. Connect it to any HDMI IN connector on your TV. You will then need to set the TV's Input selection to the Input Number you connected the DR570 to. See your TV Remote or Manual.
The DR570 has three types of output connection options, in order of quality; HDMI, Component(Red/Blu/Grn RCA jacks), S-Video (circular connector), and composite (Red/Wht/Yel, where Yel is video and Red/Wht are left/right stereo audio). Red/Wht RCA Audio jack connections are required to be made on all Output types excepting HDMI.
Note, to get your Digital channels, you will need to toggle the DR570's DTV/TV button. DTV is Digital TV channels. TV is analog channels, the DR570 found on your Cable or Antenna RF input coax, after you have done the Setup/General/Channels/Scan (extended). Scan only finds analog channels. Extended Scan scans for both Analog and Digital channels found active on your Cable/Antenna RF connection.
Note also, the DR570 is not technically and HD receiver. The term High Defintion (HD) is reserved to mean 1080i or p resolution, the highest available. The DR570 is an Extended Definition (ED) 720i or p receiver. It up-converts its ED to fit an a 16:9 HD TV screen. You will hardly notice the difference on your TV, but it is the difference between watching a DVD Movie on a standard DVD player, like this one, as opposed to a full HD player like a Blue Ray.
Feb 01, 2011 | Toshiba DR570 DVD Recorder
My TV has audio (left & right) & video jacks (red,white &yellow) can I connect my Kenwood KR-V5580 to it for stereo sound If so what do I connect it to video 1 or 2, phone,etc
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Apr 29, 2010 | Kenwood KR-V5580
Is there a way to hook up a HDMI connector to my WS-48413
Yes, there are several ways to hook up your HDMI to your TV but first, we need to understand that HDMI carries both audio and video signals though a single cable in digital form.
I am assuming you want to connect a device such as a digital cable box, Blu Ray or HD DVD player with an HDMI output to your TV. Since your TV has both digital (DVI) and analog (S-Video, component, etc) inputs, my suggestion would be to get and HDMI to DVI adapter (about $20 at buy.com) for your video and for your audio, use any RCA audio cable (I use the one from the Dollar Store). This would give you the best video resolution from your source device.
My next suggested solution would be to get an HDMI to component video + audio cable (< $10 at eBay for a 6' length) for a single-cable fix. Again component video carries analog signals so the DVI could be a better viewing experience but because the cost of the cables are minimal, I would try both solutions to see which fix would give you the better picture.
Note that since the audio is being run though RCA connectors in both instances, the digital Dolby, 5.1 or 7.1 surround sound tracks in high definition sources will not be reproduced if you connect your TV's audio-out to your audio receiver. To get the best audio, I would connect the HDMI device's digital out (optical, coaxial, etc) directly to the receiver.
Hope that helps. Have fun!
Aug 23, 2009 | Televison & Video
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
Volume making humming noise when on
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Jul 04, 2009 | Proscan 32LB30H LCD TV
Tv below listed on ebay i'm interested in buying not sure if worth or what repair would be?
Depends on how much do they want for set repair cost verys anywhere from 250 up to 375.00.Set might only need to realine convergence on customer level.
Sep 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Open Questions:
Proscan PS60690 1st turns off then on by itself. Then 3 on-off cy I've had this exact problem twice. The 1st time I replaced the RCA part number 205064, which I believe is called the HV splitter. I used a generic non RCA part. The TV worked great for several months but went out again and it has been broken for 2 years. I finally ordered the new true RCA part number 205064 HV splitter. The TV, again seemed to be fixed, and what I a beautiful picture it had through our cable box. But, no happy ending at this point. It worked for a couple of days and then turned off and back on while my wife was watching it a few minutyes ago. It cycled off then back on twice in a 3 minute period so with the picture showing and tv still on she went ahead and turned it off. This is how the problem began several years ago the 1st time it went out. I don't want to turn it back on anymore in case the brand new HV Splitter is still OK. Does anyone know what other parts may be going out, causing the HV splitters to go bad and start shorting out. I know the HV spitters have been an ongoing problem with these sets, but since I just put a brand new RCA one in only 2 days ago I'm wondering if something else goes out first and causes the splitter to go bad after a period of time. I would appreciate any help. I can't afford a new set right now and the picture looks so great on this set using a cable box I feel it's definately worth fixing. ps Could missing o-rings cause this? I've never seen the o-rings. Even the first time I replaced the HV Splitter. Thanks
Feb 28, 2017 | Proscan PS60690 60" Rear Projection...
Televison & Video Logo
70 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
