Question about Dell Dimension 2400 PC Desktop
Computer hangs at the Dee Logo
Dimension 2400, diagnostic light A & D green C & D Yellow
    President:
  • 623 Answers
Look at the description for the diagnostic lights on a Dell 2400 here under "A possible expansion card failure has occurred."
If you have recently installed any card (wireless, sound, etc.), then this would be my first suspect.
Posted on Jan 03, 2009
On powerup of Dell Dimension 5100 running Windows XP the computer hangs with diagnostic lights 1, 2 and 3 a steady green and 4 off. The onscreen message is: 300XT BIOS P.N 113-A33437-102 which appears on a...
try this:
Power the PC off, open the case cover, remove/reseat the video card in the slot.
* Power the PC off
* Disconnect the PC power cord from the rear of the PC
* Remove the computer cover
* Move the RTCRST (Clear CMOS) jumper from pins 1/2 and place it on pins 2/3
* Press the PC power button
* Move the jumper back to pins 1/2
* Remove/reseat the video card in the slot
* Replace the power cord and cover and then power the PC on
Hope it helps
Nov 05, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
The power light on my dell dimension 2400 is orange (it is not blinking). The loading light next to it is green. the computer is on but it will not do anything.It wont show the dell logo or anything. What...
You May hev one of two problems, either you towers power suply is broken, or on of the system fans are not working.
Check the power supply fan on boot. If its working check the CPU fan
Regards
Feb 21, 2010 | Dell Dimension 2400 PC Desktop
Unable to reboot system after upgrades
1. Check your RAM speed
2. Install the old RAm and see if the problem persists
Jun 24, 2009 | Dell Dimension 2400 PC Desktop
Error after memory upgrade
the frequency of 256mb ram is nt equivalent to one gb ram
Jun 20, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 won't turn off but goes off/on
The diagnostic code that you have specified is a memory related issue please try reseating the memory or swapping with a known good compatible memory stick in adverse case it can be the motherboard as you have specified that A & C take turn being yellow and green.
for more instructions please click here to got to a wizard which guides you through the step by step troubleshooting
Feb 19, 2009 | Dell Dimension 2400 PC Desktop
The screen on my dell 2400 desktop flash but won't come on
Remove the video card from the computer and connect the monitor to the integrated vga port, check if that helps, or else look at the back of the tower or on the front you would find four diagnostic lights, post the status ot them
Feb 05, 2009 | Dell Dimension 2400 PC Desktop
LED trouble lights
the led lights you see is actually a diagnostic light which has an equivalent meaning there should be actually 4 led lights you see is it a yellow green green green pattern and this is at the back of your computer? if that is the case it could be an indication that there is a device inside your computer that is malfunctioning. you will have to strip down your computer. remove all that is connected to the motherboard (hard drive, cdrom, memory, expansion card if any) disconnect the mouse, keyboard and monitor as well. should you hear a beep or the light changed at the back it means your motherboard is good and the absence of memory is being reported by the beeping sound. try to connect the device one by one
now if you are referring to the light at the dell logo infront it is just a monitoring light to indicate if your computer is turned on and the right side light is whether your hard disk is doing an activity
Jul 09, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
306 people viewed this question
Alun Cox
