Question about Microsoft Windows XP Home Edition SP3
How do you connect up two PCs to Share Documents?
    Sergeant:
  • 238 Answers
If they have NIC ports, get a crossover cable or a switch and a router. If they both have internet access, try dropbox (http://www.dropbox.com). You can also get a USB data transfer cable that will work. Another option is to use wi-fi or bluetooth for the connection.
Posted on Oct 31, 2012
2 Suggested Answers
  • 11 Answers
SOURCE: Internet connection sharing
To share an internet connection, you need to have two network connections, one for the internet connection, and another for your network.
If your DSL has a USB connection, plug it into one of your computers and then then go through the network setup wizard, from there it will walk you through sharing an internet connection.
If all the computers have wireless, you can set up an adhoc network, and share the connection that way.
Honestly, the easiest method would be to go out and buy a router.
Posted on Aug 25, 2008
Make my Lexmark x5340 be wireless'
Is this a wireless printer? Is it being used for a large office or a small home type office? If you are using it for a home office and have multiple pcs, then you can setup a homegroup. A homegroup is like building your own personal small network. You will be able to share and print documents between your computers. Once you setup the homegroup, on one computer, then you will have to add the other computers to the group using the access code that the first computer will provide. Be sure to enable printer and file sharing when setting-up the homegroup. Once setup, you will be able to print your documents from any connected printer on your network. It's not wireless but it might help to solve a print sharing problem. Good luck. How To Set Up Homegroup Sharing Plus Printer Sharing
Dec 22, 2014 | Lexmark X5340 AllInOne InkJet Printer
I am using netgear N150 WNR1000v2 wireless router with cablenet connection. The settings work fine with Internet connection on all my PCs but unfortunately I am unable to connect all the PCs on the local...
For all the PC to connect to each other, they must all be on the same network name and each computer must share set up folder/s or drive/s with Network sharing.
Jun 11, 2011 | Computers & Internet
I'm connecting 2 PCs to 1 printer .... using "Manual Share Switch #MT-1A2B-C" device. It seems an extremely uncomplicated connection to me. However, neither of the computers recognize a...
Hello.
Try connecting one of the PCs to the switch to see if it prints. If still no printing, then the share switch is probably faulty.
Hope this helps.
Jan 13, 2011 | Computers & Internet
I have one computer connect to a cable modem ..I think. can I run another computer of the same box
Yes you can this connection is called Parallel Connection using the Router You can also share the documents and etc my enabling the sharing option in Control panel you have give same Both Should be Same work Group to share Documents
Aug 11, 2010 | Telebit Refurbished OPEN BOX EXTERNAL...
I have problem of local printer is connected to domain i cant shared this usb printer on other connceted same domain pcs Basically i have one usb printer and have 20 pcs all are in domain so i want to...
Well you install the printer on the PC required, then in the setup SHARE the printer. You must then install a printer in each one of the "Clients" when asked what sort, use NETWORKED printer and navigate to where ya Printer is on the network using the "Browse" and choose it, then ya good to go.
I have found a more detailed link for your Convience http://uis.georgetown.edu/software/documentation/winxp/winxp.network.printer.html
Jan 21, 2010 | Office Equipment & Supplies
I already have 2 PCs that are both internet sharing using a non-router 5-port hub (one with WinXPPro that's connected directly to the internet, and another with Win98SE that's connected using a proxy). Now...
You can't share your connection on the PS2 to other devices. Connecting the PS2 into your hub should share the connection to all three devices as normal.
Jul 13, 2009 | Sony PlayStation 2 (PS2) Console
Connecting internet to ps3 using sprint air card
Do an ICS (Internet Connection Sharing) between your PCs. With Windows, its under the Network Connections Icon on the Control Panel. It'll show your different ports, to different devices (ie. cables to other PCs, or internet) Give them IPs by right clicking their icon, select properties, then find TCP/IP and select properties again and making your own IP numbers. Then find your internet connection one, right click, select properties, then a VZaccess screen will appear, select advanced and the properties screen like the others will appear. Then click advanced and select the ICS option and which connections you want to share.
Jan 17, 2009 | NetGear WGR614 Wireless Router
Not sure if you help with software problems but its worth a try. I recently updated from office 1997 to office 2003 student/teacher edition. I need to do extensive edit to many old Word documents by...
If you are a Word 2003 user, but some of your colleagues are still using Word 2002 or even Word 97, you can share your documents with them as long as you save them in the standard Word document format. By having Word 2003 save your documents in this format, you can disable features not supported by the earlier versions and allow users to open your documents on their PCs.
If you don't want to do this every time you save a document, you can have Word automatically save your new documents in the correct format. Follow these steps:
  1. Go to Tools | Options.
  2. Click the Save tab.
  3. Under Default Format, click the drop-down arrow in the Save Word Files As box and select Word 97-2003 Document(*.doc).
  4. Click OK.
When you save your Word 2003 document, you will get a dialog box warning that some of the features that you used may not be available in the earlier versions. Click Yes to save it in the standard format that you'll share with the other users.
Nov 28, 2008 | Computers & Internet
Aug 24, 2008 | Microsoft Windows XP Professional With...
Connections
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Microsoft Windows XP Home Edition SP3 Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
