Question about Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower
Toro zero turn wont drive does it have a drive belt with hydro drive ?
I have had the mower for 5 years and was working fine then i was mowing and all of a sudden the drive stopped working , in didnt think that the hydrastatic drive had a drive belt i need to get repair books
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
barterjoe
  • 338 Answers
SOURCE: How to change the drive
The Toro 20016 mower is a front wheel drive mower and fairly simple to change the belt on. Start by disconnecting the spark plug to prevent start ups while working on the machine.
Remove the blade and adapter. The adapter includes the pulley for the belt.
two screws under the mower, with 3/8 heads hold the black cover over the belt. remove the cover and now you will see the transmission
The transmission, depending on the year of your machine will have a guard holding the belt on. Bend or remove the guard to remove the belt. Install you belt in reverse order.
You can get parts and special tools like the blade stop at a store like www.arcolawn.com
Posted on Mar 02, 2011
  • 4336 Answers
SOURCE: i have a 19 hp kohler courage on my toro zero turn
This sounds like the carb is plugged. Sometimes fuel thickens and makes globs...
If you verified the fuel flow to the inlet of the carb, then you need to take the carb off and open it up....
So, what needs to happen is you blow out all of the passageways with carb cleaner.
Any adjustable jets: make note of the position it is in, and FINGER TIGHT turn it clockwise until it closes (typically 1 to 1 1/2 turns) SOOOOO, you can set this jet back to the same positon....when finished blowing everything out, bottom the jet and back out the number of turns out, noted for that jet.
Open the float chamber, and clean as necessary, Inspect the float adjustment: invert the carb, and observe the angle of the float, relative to the carb body.... Usually almost parallel, but not necessarily.
Inspect the inlet valve, and clean those areas...
I usually use all new gaskets and valves, but if you are not a carb person, cleaning is effective and I think old gaskets may be okay, if not torn or damaged.
Posted on Mar 11, 2011
rycgl
  • 1545 Answers
SOURCE: I have a toro lx426
Check this link and click on manuals at the bottom of the page under the Menu "Customer Care."
http://www.toro.com/home/mowers/recycler/index.html
Hopefully the manual at the least will verify the belt routing (diagram).
Posted on Mar 17, 2011
barterjoe
  • 338 Answers
SOURCE: how to replace the drive belt of a t zero turn
Remove the idler spring under the machine and remove the deck belt and keeper.
the belt will come off easily after that. If you have questions see a dealer like www.arcolawn.com
Good luck
Joe
Posted on Apr 05, 2011
Toro zero turn wont go forward or reverse
zero turn has 2 hydrostatic transmissions. Check drive belt, pulley tensioners for clog.
Remove clog with stick instead of your fingers if in the way of mechanism, belt or pulley wheels.
Check to be sure belt is taught and pulleys move. wd-40 is ok .
Do not get wd-40 onto pulley guides, or pulleys but only to tensioner mechanism and springs.
Paper towels are good spray blockers, wrap belt in paper towels if wd-40, do not use white lithium spray but only small amounts of grease when perform full breakdown and assembly maintenance on deck and drive.
The hydrostatic pumps might be drain&fill possible if they each have a vent hole and a drain plug next to vent hole somewhere. Clean them up with carb cleaner or use starter fluid if really nasty build up. Then check for hex tool drain plug and vent hole or vent cap over hole. Do not use vent hole for topping off hydro's
Jul 11, 2014 | Garden
Will run but doesn't move
If it doesn't move at all; I would check the drive belt first, then the belt idler pulleys. Just make sure that no one has put the hydro units in bypass mode so they could move the mower without the engine running without your knowledge..
Feb 28, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
The hydro drive doesn't have much power
YES IVE SEEEN IT BEFOR SOUNDS LIKE THE BELT IS LOOSE
Jul 16, 2013 | Swisher Zt2560 Zero Turn Radius 60" Riding...
My toro zero turn radius mower will not go into gear
make sure you have hydro fluid in it and that you hydro is not locked out check release wires at back to make sure they didn't get moved and also make sure your belt didn't come off hydro pump
Nov 10, 2012 | Garden
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Was mowing and the mower wouldn't let me move forward backward left or right. I walked behind the mower and found a coil with a hook piece underneth. Bought a new coil but don't know where it goes....
sounds like the hydro release rod, at back bott of mower, what this does is releases the hydro so you can push the mower around, then you have to release this and then your hydro works
Aug 02, 2011 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Apr 03, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a cub cadet model 1420 with hydrostatic drive that will not go forward or reverse. The drive belt is moving and the hydrostatic unit was replaced 3 years ago. I still have to engage the lever to...
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Sep 28, 2010 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Toro 42 In Deck 19 Hp Kohler Courage Twin Cam Zero Turn Mower Logo
173 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
