Question about HP Pavilion dv9205ca Notebook
What is warr. on a compressor for a rudd
Comp. tripps cricuit braker
    Sergeant:
    Champion:
  • HP Expert
  • 427 Answers
Posted on Apr 18, 2013
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
I have a compresor 26 gal tank camphousefield you can turn on and it builds pressure to 125 and shuts off but when it kicks back on it wont come on and tryes to trip brakers i replaced the main switch...
If you already replaced the pressure switch, then the issue is with the motor. It sounds like the problem may be with either the capacitor, or with the motor fields. I'd suggest taking it to a service center and having them look for any metal debris within the motor fields, or checking the capacitor voltages.
Feb 13, 2013 | Campbell Hausfeld Air Tools & Compressors
Rudd air conditioner outside fan won't start
I just had the same problem. I replaced the motor with no luck. It turned out to be a bad capacitor. If it is a dual capacitor, three prongs on top, it also starts the compressor. It is recommended to replace the capacitor anytime you replace a motor. I would try replacing the capacitor first. It is a lot cheaper that a new motor. If that does not fix the problem then you can get a motor. No harm, no foul. The slow start of the motor is a common symptom of a bad capacitor. The motor is not getting enough voltage. The capacitor increases the voltage like a transformer. It will boost it to almost 400 volts, depending on your unit.
Jun 21, 2012 | Heating & Cooling
Why does my compressor trip the breaker after filling with air
1 of 2 things #1 the pressure releive valve that lets the pressure of the pump when it kicks off is stuck closed so what is happening is when the compressor kicks back on its under a load and trips braker. #2 your braker is to small for the compressor.
Jan 11, 2012 | Craftsman Air Tools & Compressors
I have a kenmore a/c it blows cold air but it keeps blowing the circut braker It just started doing that about a week ago never did that before
Something has change huh? Is this the only appliance on this circut? If so then I would be looking as a couple of things. But let me ask you this first. when you turn the unit on does it blow the breaker when the compressor comes on? How long does it run before it tripps the breaker? are the indoor fan and out door fan operating the way they have in the past ? meaning does it sound the same as it had? It may well be something minor/ Let me know Jon
Aug 07, 2011 | Heating & Cooling
My AC compressor became weak ,is it true that it cannot be repaired if the AC system is serviced &must buy new one?
what do u mean by serviced ? most of the time you would not get that part "repaired " unless the prob is in the clutch , best to find a reman . and be sure to change dryer and orphis tube (most wil not warr the comp without changing these as well
Apr 28, 2010 | 1996 Mercury Grand Marquis
How do reverse polarity on rudd ac compressor
Is this a 3 phase compressor? If it is it will have markings L1 - L2 - L3 and it will not have a run capacitor, then just reverse any two compressor wires. If it's single phase then you can't without Burning up the start windings, it will be marked C - S - R and have a run capacitor, these markings are on the Compressor.
Jun 22, 2009 | Heating & Cooling
Replaced my 5-year old 3-ton 12 SEER Goodman outside condensing unit with an older 3-ton RUDD condensing unit because of lack of funds. Now the compressor has gone out on the RUDD. Is it better to replace...
at 5 yr on goodman unit rhe comp should of been under warrenty if theat is what was bad with it on the rudd that was a 3.5 ton out door unit are you sure the pump is bad pulling locked rotar amps or shorted to ground check the wires on the comp to make sure not burnt check the capicitor as far as replacement i always lean twoards new unit unless not going to live there long due to comp is 1 yr and labor around 850 +325 for pump i would go with another used unit over comp replacement 13 seer goodman w 99yr pump and latley have 5 yr free labor and I normally dont recommend a brand of unit on this site go to a hvac store and ask who may have a used unit I have had some still w warrenty before that came from remodel jobs in up scale areas! if helpfull rate me good luck
May 12, 2009 | Ruud UAKA042 Air Conditioner
Fridge/freezer not very cold and cylinder is very hot? amana arb220zcw
souns as if youre having an issue with your compressor("cylinder?") black football sized motor behind unit???5 yr manufactures warr if so, cross your fingers, out of warr that repair could cost 4-6 hundred dollars
Nov 20, 2008 | Amana ARB220RCW Bottom Freezer...
HP Pavilion dv9205ca Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
