Question about Paradyne (6218-A1-200) Wireless Router (6218A1200)
Paradyne 6218-A1 configuration Manual - Paradyne (6218-A1-200) Wireless Router (6218A1200)
SOURCE: paradyne 6218 how to reset
The user name : password is normally admin : admin
To reset the router try holding the reset button on the back of the box for about 10 sec. (make sure the power is on while doing this)
Posted on Feb 01, 2008
  • 19 Answers
SOURCE: cannot access the menu to 6218-A1-302 because of wrong update
Hi there, there are so many possibilities to your problem, however the first thing I would do is check underneath your router for the Ip address, if it is not there, then you can check your booklet that came with the router (assuming that you still have it of course)!!
Once you have this, you may then reconfigure / restore the router or alternatively (and firstly), I would check the network key and the type of encryption. The chances are that when you updated the firmware, that the key was also changed! Obviously make sure that the network key you are entering into your computer matches the one within the router for wireless applications, I hope this helps you, Chris
Posted on Nov 09, 2008
tech curly
  • 298 Answers
SOURCE: HOW TO CONFIGURE MODEM OF PARADYNE(ADSL 2+)
Basically if your Internet service is DSL or cable it's just a plug and play. Just plug the computer to the modem once the Internet access has been activated by your ISP and your computer should automatically get connection from the modem.
Posted on Aug 19, 2009
  • 377 Answers
SOURCE: Will a Paradyne 6218 be compatible with Windows
read user manual you will get the information about the topic
thanks
Posted on Nov 10, 2010
  • 11800 Answers
SOURCE: The combined Paradyne router and
You buy a new one, you install it in the place of the other and you configure it following the manual - you will need the connection data from your ISP (username and password - they are in the contract).
If you no longer have it you can download it from here
http://www.zhone.com/support/manuals/docs/62/6218-A2-ZB23-10.pdf
Posted on Feb 16, 2011
Paradyne 6218
The router must provide new internal IP's. Make sure it is set to DHCP. IPs are never shared.
Mar 29, 2013 | Paradyne (6218-A1-200) Wireless Router...
Will a Paradyne 6218 be compatible with Windows 2000
thanks
Nov 10, 2010 | Paradyne (6218-A1-200) Wireless Router...
My paradyne has no IP ADDRESS, HOW DO I PROGRAM THE IP ADDRESS INTO WINDOWS 7
start menu
-search programs and files
-run
-cmd - enter
-ipconfig (press enter)
-you'll see defult gateway, thats the ipaddress of you paradyne.
Apr 25, 2010 | Paradyne (6218-A1-200) Wireless Router...
I want to change mtu value for paradyne
You can edit it through GUI or command line. Be careful as to what you set it to as MTU settings can really affect your traffic flow. Read the manual for help
Apr 08, 2010 | Paradyne (6218-A1-200) Wireless Router...
Paradyne 6218 12 200. With dynamic IP address, this modem/router will assign addresses to both fixed all 4 ports, and wireless laptops. How do we program it to do the same when ISP has assigned a static IP...
If desired change the IP address or Gateway will please right click the name (My Network Places), then right click (Local Area Connection), (Properties), have at the bottom to select, high light the name (Internet Protocol (TCP / IP), Lift Click the Properties, to trim after you customize IP add and modify the following required.Good Luck
Jul 23, 2009 | Paradyne (6218-A1-200) Wireless Router...
I need the configuration settings
you will need to read the user manual, it explains how to connect to the configuration pages etc.
May 20, 2009 | Paradyne (6218-A1-200) Wireless Router...
Cannot access the menu to 6218-A1-302 because of wrong update
Nov 09, 2008 | Paradyne (6218-A1-200) Wireless Router...
Paradyne 6218 how to reset
Oct 15, 2007 | Paradyne (6218-A1-200) Wireless Router...
Paradyne problem 6218
If the address you mention is correct, try reseting the router first, (normally a little hole at back), then typing in again, although most routers have a 192.168.x.x reference and not 198.168.x.x as you mention.
Oct 15, 2006 | Paradyne (6218-A1-200) Wireless Router...
Paradyne (6218-A1-200) Wireless Router (6218A1200) Logo
79 people viewed this question
Top Paradyne Computers & Internet Experts
Alan Rothery
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
