Question about SanDisk Sansa c140 MP3 Player
Help me fix my Sansa c140
Hello, The sansa c140 1gb mp3 device displays a message "no space for DB please delete more than 4.0MB" when I start it. I tried to format using WinXP but it couldnt be formatted. I tried the firmware updater from sandisk website. That dint work too. I cannot copy files into the drive from my pc in MSC mode either. There are some space left but I cant add new mp3 files. I tried to delete the files which does delete but when I reconnect the files are still there. I tried to restore factory settings. None of the methods work. Please help me fix my device. I love it because it have very good sound quality. Please help me, Thankyou in advance.
  • debo jyoti Jun 02, 2007
    thanks a lot aykuttt.
I had exactly the same problem and than i wrote the guys on www.sandisk.com they had my device replaced.
Posted on May 23, 2007
Sansa clip says i must free 4mb then switches off
You should format the device using windows media player or the device itself..that should fix the problem you are having..remember formatting will delete all the date you have on the device..
I hope that helps
Please rate accordingly
Thank you
Computerrep
Sep 19, 2008 | SanDisk Sansa Clip MP3 Player
Sansa m230
whenever i turn on my sansa m230 mp3 player, it displays the message, "not enough space for music DB, please free 8mb." And so i plug it into my friends computer and when i open the music folder on the device, its empty, even though it says that there is quite a bit of space used up. Do you have any answers?.
Sep 07, 2008 | SanDisk Sansa m230 MP3 Player
Sansa c140
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
Jul 03, 2008 | SanDisk Sansa c140 MP3 Player
SANSA c140 not sychronizing
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 05, 2008 | SanDisk Sansa c140 MP3 Player
MP3 player says Need to delete tracks
All you need to do is delete a few of your songs off, 2 or 3 should be enough.
Feb 21, 2008 | SanDisk Sansa c140 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
The sansa c140 1gb mp3 device displays a message "no space for DB please delete more than 4.0MB" when I start it. I tried to format using WinXP but it couldnt be formatted. I tried the firmware updater...
If you are trying to format the device thru Windows Media Player, try just thru My Computer. My Computer>Device Name, right click and select format. Otherwise you may need to change the mode on the device. Settings>Mode or USB. Please add to the question, if you need more help. Best of Luck.
Sep 29, 2007 | SanDisk Sansa c140 MP3 Player
NoSpaceForDB Please Delete MoreThan4.0MB
you just have tu format it from "mi computer" and problem solved...
Sep 21, 2007 | SanDisk Sansa c140 MP3 Player
Please Help: Im Desperate!
hmm... try hooking it up to the pc, go to my computer find the mp3 click explore go to music and select it all and delete it then try again it might help
Mar 20, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
192 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
