Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Replace inverter board on a KDL-NX810 - Sony BRAVIA KDL-40S2010 40 in. LCD Television
2 Suggested Answers
JOHNSONELECT
  • 113 Answers
SOURCE: KDL-40v3000 flashes for 2 seconds then goes black
have you check the voltage from the power supply thats goes to invertor maybe its low the power supply would be bad
Posted on Aug 27, 2009
Hi I have a Sony Bravia model# KDL-32BX330 don't turn on..No light. I need to know what is wrong with it...thanks
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 21, 2017 | Sony BRAVIA KDL-32BX330 32" 720p HDTV with...
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
How do I brighten a Bravia KDL-42V4100
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 08, 2016 | Sony Bravia KDL-42V4100 42 in. LCD TV
Sony bravia kdl-46Xbr4 right side of screen is darker until the tv warms up flickers like a floresent bulb and is a brownish color
Oct 01, 2016 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Horizontal lines on screen of sony tv
Back - light problem. Damaged CCFL lamp/s. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Feb 03, 2016 | Sony BRAVIA KDL-46EX720 46" 3D LED-LCD TV...
Ho do I check and replace inverter board for sony tv kdl-60ex720?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 19, 2015 | Sony Bravia Kdl-60ex720 60" 3d 1080p...
I have a Sony Bravia KDL-46w4100. It has started to dark screen on start up. It sounds like this is a common problem for Sony tvs. Does anyone know the fix?
Nov 22, 2014 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Kdl-26b4050 blank screen no picture
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sep 29, 2014 | Sony BRAVIA KDL-26B4050 26 in. LCD TV
Four blinking red lights.
you can have the inverter board replaced...instead of the entire panel.
KDL 40S2010: inverter part # 178950032, you will also need 2 spacers..part # 289765511
you're looking @ 200-300$ for the inverter and 5-10$ a piece for the spacers.
KDL-46V2500: inverter part # A1251295B
you're looking @ around 500-600 $ for the part
Aug 18, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
