Question about Samsung SMH7178STD Microwave Oven
Removing an over the range Samsung smh4150 microwave from the wall.
The motor seized and was blowing the curcuit breaker.
when I opened the bottom to disconnect the motor , a motor wire shorted against the frame and now there is no power to the key pad and the lights are out.
I started to remove the oven from the wall to take it in for service,but it is not coming off easily.
I don't have the install instructions.
  • 2 more comments
  • gopherly Jan 03, 2009
    I am going to have to remove the unit from the wall to have it repaired.
    How do I remove it from the wall bracket?
    I have removed the unit from the wall.
    How do I remove or test the curcuitboards to find the blown component?
    I need to find out how to find the blown component.
    The oven has no power.
    I shorted one of the turntable motor wires.
  • gopherly Jan 14, 2009
    The transformer was shorted out.
    Thanks for the help.
    Brigadier General:
  • 8,619 Answers
Hi
Remove the screws from the back and check for any blown fuses , also for burned parts . Check if power cable coming from mains is not burned .
Thankyou
Posted on Jan 03, 2009
    Genius:
  • 1,036 Answers
If you have no power to the main boards, then the multi-tap transformer has probably broken down.
Test the continuity / Ohms of the input and outputs of this first to ensure you have a viable supply.
  • Richard Perkins
    Richard Perkins Jan 03, 2009
    These are available as a replacement item.
    Genius:
  • 1,199 Answers
The unit will have to be removed and the unit will have to be tested
    Genius:
  • 1,142 Answers
You need a service assistance
please call 1-800-SAMSUNG (1-800-726-7864), or go on-line to WWW.SAMSUNGSUPPORT.COM
  • Maanita Chadha
    Maanita Chadha Jan 03, 2009
    Step 1. Remove the Front Grill Screws
    Remove the two screws that secure the grill to the chassis.
    Step 2. Remove The Grill From The Chassis
    Remove the grill by sliding it to the left, then pulling out.
    Step 3. Remove/Install The Charcoal Filter
    You need to locate if any screw is securing the unit on the wall.
  • 15,935 Answers
Take the mounting screws out of the top. (usually in the upper cabinet)
Then slightly LIFT - as it is seated in a lip-mount bracket to the wall.
    Sergeant:
    Champion:
  • 239 Answers
Remove the two screws inside cabinet right above microwave let it drop and then lift the back easy out
    Genius:
  • 1,550 Answers
You can follow the instruction from manual to remove the oven completely .
First disconnect power to the oven. Remove the mounting screws securing the oven to the wall. Slide the complete oven out about 10 inches.
  • Samsung Master
  • 19,396 Answers
The frame carries ground, if a wire shorted to ground surely ine of the wires had melt, or there is a blown fuse, or something has blown on control board.
The whole wiring and boards must be tested using a multimeter.
Phillips whirlpool microwave turntable not turning
HELLO.
The turntable is the unit in the center of a microwave that you set your food on. It rotates during the microwave cycle, making sure all parts of a dish are properly heated. These are typically made of either hard glass or microwave-safe plastic.
Your microwave turntable may not turn due to any of these problems explained below.
(a)If your turntable is removable (as many are for cleaning purposes), it may have come loose from this turning mechanism.place the turntable properly on the turning mechanism.
(b)If your turntable was previously working and now does not any longer, check the settings on your microwave's LCD display to make sure you haven't accidentally turned off the turntable.
Most microwaves have different settings that the user can select with the press of a button, like a "Defrost" setting or a "Popcorn" setting. Certain microwaves may stop the turntable from turning during certain pre-programmed selection modes. Stop your microwave and don't use a pre-programmed mode. Instead, just specify the time using the number pads and start your microwave to see if your turntable begins to rotate again.
(c)The rotating mechanism on the inside of your microwave that rotates the turntable is actually connected to a small motor on the inside of your microwave's case. If this motor burns out or stops working, the mechanism will stop turning. This is something that needs to be replace.
follow these steps below to replace the faulty motor.
1. Open the microwave door, and carefully remove the turntable tray. Also, remove the frame that the turntable is positioned on. Both the turntable and the frame are not secured in the oven, so removing them is a quick process.
2 .Remove the bottom panel of the microwave. The Microwave Wizard website explains that the number of screws securing the panel varies depending on the manufacturer and specific microwave. Once the bottom panel is loosened, disconnect its wiring harness in order to completely remove the panel.
3. Locate the turntable motor. The Microwave Wizard website explains that the motor compartment should be positioned below the center of the microwave. Unscrew the motor, disconnect the wires, and remove it from the microwave.
4. Determine the specific part number for the turntable motor so that a correct replacement can be purchased or ordered. Position the new motor into the shaft in the bottom of the microwave. Screw the motor securely into place.
5. Test the microwave to make sure that the turntable motor is operating correctly. The Microwave Wizard website explains that the motor can make noises if it was not positioned evenly in the shaft. Reconnect all of the wires that were detached when removing the old motor.
6. Reinstall the microwave's bottom panel parts, and secure all of the screws in place. Reposition the turntable frame in the bottom of the microwave and place the turntable on top of it. Test the microwave in order to make sure that everything is working correctly.
Thanks.
Oct 01, 2011 | Microwave Ovens
The circuit breaker continues to blow off. I believe this occurs when the heating element is activated. I have replaced the heating element. The problem persists. The isolator bushings seemed to be OK....
Hi.SHORT CIRCUIT MIGHT HAPPEN I THE HEATER.IC'S MIGHT HAVE BEEN DAMAGE.or short circuited.you may try to check it using a multitetster.Set it to ohms .and check continuity of the circuit.If pointer goes rapidly more than its maximum then there is short circuit in the heater.hope this helps..
Jun 18, 2011 | Kenmore Microwave Ovens
The blow or fan stop working and the circuit breaker kicks off
It sounds like your exhaust blower has a shorted wire to it or the motor itself is bad. If you have a basic knowlege of electricity, some hand tools and lots of patience you can take the unit down off the wall, remove all the access screws and locate the blower (usually on the top back). Follow the wires from that to the control, look for breaks or tears in the wire, if none found then the blower motor will need replaced.
Apr 18, 2010 | Microwave Ovens
How do I remove the waffle grate plates from my Waring Waffle Pro? Can't find my manual.--Frank Davis
Here is how you need to replace or bring out the plates.
Make sure you are unplugged from the wall before doing anything or you will get shocked. You do not need to take the bottom cover off the base. You do not need to take the top plate apart (they super glued one screw in the top plate (lid), you'll strip out the screw head trying to remove it anyhow). All you need to open is the bottom plate, it has 4 screws in it you will see when you open the lid, these screws are not super glued and will come out. 2 on each side in the back, 2 in the center of the front, long screws go in the back, short in the front.
There are 2 white wires, 1 black wire, 1 green wire that run up the neck of the waffle maker to heat the top and bottom heating elements. The 2 white wires are neutral, the green wire is a ground, the black wire is power.
This black wire runs from the electronic control board in the base of the unit, up the neck in the rear, through a thermal fuse, to the bottom element then jumps up to the top element. All you need to take apart is the bottom plate, the part you pour the batter into. It has 4 screws you will see when you open the top plate up, take those out and you are going to find the black wire is covered by a white rubber like tube about 3 inches long. In the center of this rubber insulation there is a metal clip with a single screw. Take that screw out, pull off the metal clip and slide (don't cut) the rubber like insulation back.
You will find the black wire is crimped onto a silver metal bullet looking component. This component is called a "thermal fuse", its designed to fail at 240 degrees C. Its obviously a design flaw and the thermal fuse is under rated for the actual heat within the device. Its also a one shot fuse, so when it blows it kills power on the black wire from going to the top and bottom plates, thus no heat. It is not resettable.
I didn't even cut mine out (Waring is very skimpy with their wire, they don't leave you even a hint of extra wire to work with). I just tightly twisted the bare metal wire on each side of this component like a bread tie leaving the blown fuse in place. Then be sure to slide the rubber like insulation back over all of the bare metal so it is covering the black wire on both sides. If you don't it will short out and blow your house circuit breaker when you turn it on.
This thermal fuse was probably a requirement of the UL Listing. Its over kill, everything in there is metal so if it over heats in that area there is nothing flammable to burn. If a run away temperature occurs the wire itself will melt, short out and trip your house breaker. There are stacks of these units brand new with this same problem anyone reading this is having, the thermal fuse is under rated, the fix is simple
Thank you for contacting Fixya.com
Nov 22, 2009 | Microwave Ovens
Opening the door blows the fuse
more than likely you door safety switch has a short and every time you pull the door open the connections arc and trip the breaker or blows the fuse.
Aug 24, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
May 21, 2009 | Emerson Black Microwave Oven
JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
May 09, 2008 | Jenn-Air JMC7000 Microwave Oven
No power from Whirlpool.
IF YOU HAVE THE MICRWAVE PLUGGED IN AND THE CIRCUIT BREAKER TRIPS IMMEDIATELY WHEN SET,
CHECK THE DOOR HOOKS THAT TRIP THE DOOR SWITCHES. BOTH SHOULD BE SPRING LOADED. THERE SHOULD BE TWO HOOKS ON THE DOOR. IF O.K., CHECK THE DOOR SWITCHES. THERE ARE AT LEAST THREE. IF ONE OF THEM IS SHORTED CLOSED,
THE MONITOR SWITCH WILL CAUSE A DEAD SHORT ACROSS THE FUSE. THE FUSE MAY BE HOLDING BETTER THAN YOUR CIRCUIT BREAKER.
Mar 21, 2008 | Whirlpool MH1150XMQ Microwave Oven
Microwave Ovens Logo
407 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
