Question about Summit Appliances Division SWC1530 Compact Wine Cooler Commercial
Swc1530 Circuit board
My black and red wires for my nds speaker circuit boards was severed. Can they still be used or do I need a new circuit board?
If the board (PCB) is not damaged you can re-solder the wires back. If the PCB is damaged you should be able to get new ones by looking up the make and model of the device and look for the specific part.
Aug 07, 2015 | Nintendo DS Video Game Consoles & Games
Tip
How to choose a good PCB (Printed Circuit Board) manufacturer ?
RayMing - Your trusted partner
RayMing - In Asia alone, there are so many thousands of options when you want to select a printed circuit board manufacturer or fabricator, but which one is the best? RayMing has been in Printed Circuit Board industry and confident we offer the best combination of price, quality, on time delivery and customerservice to the customer. That is the reason we think that as a customer of Printed Circuit Board product, you should ask about PCB manufacturers to help youcompare and choose the best printed circuit board manufacturer for your company.
First factor: When selecting a quick turn PCB manufacturer or supplier, you need to look at how long they have been in business and how stable in term offinancial stability of the company. The printed circuit board industry is highly competitive especially in Asia and many PCB manufacturers come and goespecially in Taiwan and China. This causes your commodity manager or purchaser continue searching for Printed Circuit Board supplier which will costs youboth time and money when come to selecting a Printed Circuit Board company.
Second factor: Does your Printed Circuit Board supplier just take your order or do they offer value added services to ensure highest quality,
manufacturability, and performance accuracy of your circuit boards?A good quick turn Printed Circuit Board shop will offer extra value added services to go above and beyond their competitors. The obvious services like
additional cost savings proposal, extra reliability design, manufacturing assistance through the project, timely communications to ensure no surprises and noimpact in term of on-time delivery.
Third factor: Is your supplier follows new regulations and standards associated with RoHS compliance and lead free finishes?
While most other Printed Circuit Board companies were trying very hard to makes changes to meet RoHS compliance for circuit boards, you need to ask specificquestions and look detail into various industry standards that the Printed Circuit Board supplier has met. In Asia, ISO standard might be a good gauge. Anautomotive certification of a Printed Circuit Shop houses might be an additional value add to their capabilities standard that you can consider in your PCBsurvey list. refer
Quick Turn PCB for more information for quick turn pcb.
www.raypcb.com
on Jul 22, 2010 | Computers & Internet
I just replaced my circulation pump on my hot tub and now all I get is a clicking sound when I power up the tub the display works fine
That clicking sound you are hearing is probably coming from the relay on the circuit board.
The issue may not be with the circ pump but rather the circuit board.
Most of the time a customer will replace the circuit board because it has gone out but the circuit board will go out most of the time because one of the pumps or heater causes the relay on the board to go out hence once the put the new circuit board in the pump or heater now doesn't work. This is because that item was having a problem and caused the circuit board to go out.
Rod
US Parts Center
Mar 11, 2014 | Pool & Spa
How do I remove circuit board assembly
If you need help that how remove circuit board assembly you can find your answer at http://www.dferrantielectronics.co.uk
Jan 09, 2014 | Samsung Assembly Printed Circuit Board...
What is a pcb printed circuit board and where are they located on a th-50px80u plasma tv
A PCB Printed circuit board is every single board in your TV. That is what PCB stands for Printed Circuit Board.
Jul 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
Our washer keeps stopping and flashing F11 and will not finish load
The F11 code is saying that there is a problem with the motor or motor control board, both at the bottom of the machine. Most often the problem is not there but rather in the communications between the CCU circuit board and the motor or motor control board. The CCU circuit board (inside back, top of machine, plastic case) has what's called cold solder joints where the relays (5 of them) and the spade connectors are supposed to be firmly soldered to the circuit board. Whirlpool had a quality control problem with these circuit boards but won't recall them. The cure is to remove the CCU circuit board in the plastic case (it's easier that way) then remove the circuit board and touch-up those cold solder connections I mentioned. If your not up on soldering techniques, you can remove the CCU case, with the circuit board inside, and take it along with this response, to a good appliance repair shop and they should be able to help you out. Good luck.
Feb 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When i turn my polaroid pla 4248 on the light goes from red to blue and i get sound but no picture
The problem here is either a combination of what they call the X-sus printed circuit board and the Y-sus printed circuit board or a case of either one or the other, i reccomend that if you have a muti meter and the unit is well out of warranty, open the back of it, and test the voltages, which should be marked on the printed circuit boards where the plugs plug in from , or too , the main printed circuit board.
You will be able to find the Y-sus and the X-sus printed circuit board fairly easily as they should be marled with a part number and description, eg, Y-sus, etc, if not, they are the large printed circuit boards on the left and right side of the main printed circuit board.
If you find the voltages are different to that show on the circuit board by a large amount, chances are that printed circuit board is faulty.
I hope this offers some assistance. Good luck.
Apr 17, 2010 | Polaroid PLA-4248 42 in. Plasma HDTV
How do I remove the keys from a Roland KR 4700 piano? We can't figure it out. Please help! I can't afford to get a repairman. I need to replace the contact strip. It's happened before.
If these are semi weighted keys here is a cut and paste from a manual:
19. Disassembling the Keyboard Assembly
* After inserting a round stick (Rod: TX000670)
between the frame and the keys, remove the
circuit boards. (Fig. 23)
19-1 GHD EBUS L, MK SUB Circuit Board
(Time required: about 12 minutes)
Remove the seven (7) screws marked [260A]. The
GHD EBUS L and MK SUB circuit boards can then
be removed. (Fig. 24, Photo 5)
19-2 GHD M Circuit Board
Remove the five (5) screws marked [260B] and the
screw marked [262]. The GHD M circuit board can
then be removed. (Fig. 24)
19-3 GHD H Circuit Board
Remove the four (4) screws marked [260C] and the
screw marked [262]. The GHD H circuit board can
* Keys can be removed without removing the
circuit boards.
* After removing the GHD EBUS L, GHD M and
GHD H circuit boards, and the rubber contacts
can then be removed.
19-4 Rubber contact
Remove the GHD circuit board for the involved key.
The rubber contacts can then be removed.
The rod is inserted above the weighted hammer and the bottom of the keys from one end. It appears to be about 1/4 inch diameter dowel and will run the full length of the keyboard. You might use 3 foot ones from each end.
Screws are removed and the boards removed without taking the individual keys out.
Mar 17, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
My fredge rm 2652 not working
Between 1993-1996 dometic used a yellow epoxy filled circuit board that went bad pretty quickly if you have the yellow filled circuit board rather than the green one it is most likely the circuit board
Jan 09, 2009 | Dometic RM2652 Refrigerator
Panasonic pt-53wx42f RF circuit board
Can you be more specific on what your needing, as there isnt a board called RF circuit board. Do you mean the signal board? Can you post a picture of what board youre needing?
Aug 05, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Summit Appliances Division SWC1530 Compact Wine Cooler Commercial Logo
23 people viewed this question
Top Summit Appliances Division Refrigerators Experts
ray gallant
reliableservice
Brett Duxbury
Brett Duxbury
Are you a Summit Appliances Division Refrigerator Expert? Answer questions, earn points and help others
