Question about Refrigerators
Hoover fridge freezer n1b . inside of fridge is iced up whats likely to be wrong
MODEL HNMF2605A-80 drain hole clear also tried turning off for a while to see if system would reset no joy
3 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Fridge Icing up on N1B Candy frost free fridge freezer
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Posted on Sep 02, 2009
Testimonial: "Really useful advise, with link to more help. Thank you"
heatman101
  • 43501 Answers
SOURCE: hoover fridge freezer hnmf2605a/80 fridge freezeing
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 21, 2011
Hoover fridge freezer hnmf2605a/80 fridge freezeing up all the time
heatman101
Aug 21, 2011 | Hoover Refrigerators
My whirlpool fridge/freezer model ET1FHTXM forms ice in the back of the freezer, and water drips down to the fridge. I can't figure out what is wrong. We do not have the water hose hooked up. Could...
Turn off or unplug the refrigerator.
Open the freezer.
Remove the food.
Remove the back panel inside the freezer.
Thaw the ice and clean out the defrost drain hole.
Re-assemble the freezer parts and turn it back on.
Jul 20, 2011 | Whirlpool ET1FHTXM Top Freezer...
HOOVER CLASS A FROSTFREE FREEZE HNMF 2805A L-80 FREEZER IS WORKING BUT FRIDGE INSIDE IS COVERED WITH SHEET OF ICE AND BLOCK OF ICE AT BACK FOOD AND LIQUIDS ARE FREEZING HAVE ALREADY TRIED TURNING DOWN...
I had same problem. Needed a new thermostat. Lasted about 18 months, then needed to replace fridge. Ice build up is between the inside and outside layers of the fridge as well. May just be more economical to replace. Cheers
Oct 26, 2010 | Hoover HCA331FFK
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
The hole at the back of fridge is not letting water go down so i have puddles of water running to front of fridge have tried cleaning out but just the same
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 14, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Sep 02, 2009 | Refrigerators
I have a GE TOP Freezer Model # TBX21JABLRBB
Turn off the fridge. Remove the rear freezer panel inside the freezer. Take a hair dryer and thaw the ice in the drain trough at the rear of the freezer. After it is clear, pour a 1/4 cup of bleach into the drain hole. Adjust the front leveling legs on the fridge to make the fridge tilt slightly to the rear.
Jul 06, 2009 | GE GTS20ICNCC / GTS20ICNWW Top Freezer...
Fridge won't get cold
You need to defrost it and remove rear panel in freezer compartment.After you defrost it pour hot water in the hole in the center rear area of freezer to make sure it is draining good.After that take down model# from the inside of fridge on the side .You will need a defrost timer You can use the model number and and your local parts depot will order it acourding to the model.80% of the time the fridge is iced up that is what is causing it;Hope i helped:) Let me know if there are anymore thing you want to know before you try
May 20, 2009 | Freezers
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
99 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
