Question about Imperial ICVD-2-HH Turbo-Flow Gas Double Oven
Where can I purchase a flame switch for an Imperial oven Model#09572J
  • 24 Answers
You probably can't any longer as they contained mercury. Whilst this never was a problem, I believe California outlawed all devices for commercial cooking that contained mercury and manufacturers had to stop fitting them. My understanding is that they are not even allowed to hold stock. GOOD NEWS! there is a modification kit that can be retro fitted that turns the unit into an automatic pilot system. It contains a grey control box and some wiring. The original flame switch and spark box are removed and this new box initiates the pilot valve/ignition. I don't have part numbers and you will need to be a really good engineer to fit this mod' kit, but it does work and is pretty reliable, just make sure it doesn't get mounted where it will get too hot.
Posted on Nov 25, 2014
2 Suggested Answers
SOURCE: what causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Posted on Jun 06, 2012
Imperial single older convection ICV pilot lights, have flame, but wont light / heat oven. replaced thermostat, didnt help problem, now what?
I suspect the thermo coupler if there is one. I had to replace ours. I took it out and took it to a repair man and he sold me one just like it. Works good now. Make sure the parts are clean where the gas comes out as well The burner as well.
Oct 20, 2016 | Imperial Ovens
Oven lights for about five to ten seconds and outs again when starting up but never remains lighting
Sounds like an issue with the flame sensing electrodes. Depends on when this oven was made as they used 3 different ignition systems over the last 10 years. This is definitely a job for a qualified gas engineer, not a DIY fix...sorry.
Oct 25, 2013 | Imperial ICVD-1-H Turbo-Flow Gas Single...
What causes the flame switch to cut out ion an Imperial ICVD convection oven
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
I have a imperial convection oven that I just purschase and operated fore 4 days, and the fan stoped working any idei what would cause this?
You don't say what model. Some Imperial ovens have a cool-down switch that lets the fan run with the doors open but not in cook mode. That is a starting point.
Mar 27, 2012 | Imperial Ovens
No ignition
EL HORNO NO SE APAGA EN LA TEMPERATURA SELECCIONADA Y CALIENTA DEMASIADO
May 20, 2010 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Pilot spark but no flame
make sure area where spark had to touch is perfectly clean
Feb 04, 2010 | Imperial Ovens
ICV-1
If you could narrow down the buzzing noise, where and when, it may be significant.
As far as the unit losing its flame, I believe this unit uses a "flame switch" to prove there is a pilot flame. (Part# 1133) So first visually verify the flame quality and the position of the bulb for the flame switch. And assuming that's fine, you need to check the electrical switch portion of the part. It is in the control cabinet towards the bottom. Just two wires.
Usually this problem is a switch failure, rather than a lose connection, or a poor pilot flame. Good luck
May 10, 2008 | Imperial ICVD-1-H Turbo-Flow Gas Single...
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Oct 31, 2017 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Imperial ICVD-2-HH Turbo-Flow Gas Double Oven Logo
126 people viewed this question
Top Imperial Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
John Rodgers
John Rodgers
Are you an Imperial Oven Expert? Answer questions, earn points and help others
