Battery charge light flashing
Should the battery light be flashing during charge or steady on
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
What is the device? A blinking light while charging can mean its trickle charging. Does the device hold a charge?
Posted on Oct 29, 2012
  • Robert Stanfield
    Robert Stanfield Oct 29, 2012
    It's an Insignia IS-PD101351 portable dvd player. Thanks for your help. No the battery is apparently not holding a charge after 8 hours. I probably answered my own question. The manual seems to indicate is should be a steady red, not flashiing
Just bought a Ruobi drill with 18V Lithium Batteries. Been chatging for over an hour. Still not charged. Just the bottom Green light stays on. Is this normal? How long does it take?
The Ryobi charger will flash green as it charges and then remain steady or slowly flashing green when fully charged. Flashing red means testing and if it remains steady or slowly flashing red it is defective.
Apr 11, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
Battery light on my hp probook 6550b flashes when i try to charge it but it will not turn on!!! How do i fiix it?
flashing battery light is normal when the battery is empty ,and the orange led should become steady when you insert charger then it should turn to blue and after the battery is fully charged the led is turned off, i think the problem is that no charging happens check your adapter and the DC input
Feb 09, 2012 | HEWLETT-PACKARD HP ProBook 6550b Notebook
How do I know when an EN-EL! for the Nikon Coolpix 5000 is fully charged? what do the following conditions indicate? 1. Charger red light flashing 2. charger red light steady 3. charger red light...
Charger flashing red indicates the battery is still not full and is in the process of recharging.
Red light steady indicates your battery is fully charged and ready to operate with your Coolpix 5000.
When red light is off it indicates there is no battery inserted or the charger is not pluged in.
Mar 26, 2011 | Nikon EN-EL1 Battery + Charger...
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Problem with extended battery
LED indicator for your laptop model
Steady Blue = Battery charged and AC adapter plugged in
Amber = Battery charging and AC adapter plugged in
Slow Amber Flash = <10% battery life
Fast amber flash = 3% remaining TPC will automatically go into hibernate
Slow flashing amber Adapter plugged in = Overheat condition
Do you have a multimeter to test the battery that you are using? check the output current of the battery.
May 29, 2009 | Motion Computing MOTION LE1600 Notebook
Battery light flashes when hitting bumps
Hello There
You need to tighten the connectors on the batter. It's a loose connection problem.
Many Thanks
Mar 15, 2009 | 1998 Dodge Neon
What is the button and set of 5 lights on a dell c610 battery for
The LEDs on the battery indicate the charge remaining. Press the button and you should get 5 LEDs with a full charge. The LEDs stay on in a steady state as long as you hold trhe button
The LEDs can also indicate an internal failure of the battery (Usually 1 3 and 5 will flash) if the LEDs flash, the battery is either critically low or failing. If charging it doesn't change the LED flashing them the battery will need to be replaced
Jan 27, 2009 | Dell Latitude D600 Notebook
P30 not Charging
Remove the battery and see if the power light still flashes or stays on steady. Your battery could be dead and may need to be replaced. How many charge cycles has it been through, and/or how old is it?
Feb 24, 2008 | Toshiba Satellite P30-S701TD Notebook
235 people viewed this question
 Grubhead
Grubhead
