Question about Microwave Ovens
User guide for murphy richards micro wave p80d20p-yu/h
2 Suggested Answers
  • 6771 Answers
SOURCE: my morphy richards p80d20p-yu microwave runs normal but won't heat food
The problem is caused by a bad magnetron, inverter board, "7 years old or less" and possibily the keypad control board.
Posted on May 02, 2012
Can you remove the microwave separately without removing the complete oven/microwave unit? KEMS307DWH4 KitchenAid Wall Oven/Microwave combo unit
Hello Richard;
My name is Peter. I am a retired field service technician.
Your microwave is in a separate housing than your oven. You need to remove the border stripping holding the micro wave in the wall, then lift up in the front and pull out.
Go into the following website, put in your model number which is on a label after you open the microwave door.
You did not tell me what the problem is. Please advise so I can help you further.
Mar 26, 2016 | Microwave Ovens
My murphy richards microwave door release button has snapped can this be repaired & how do i do it ?
change the front panel door casing or the entire body shell, to be on the safe side.
Dec 27, 2012 | Microwave Ovens
My morphy richards p80d20p-yu microwave runs normal but won't heat food
May 02, 2012 | Microwave Ovens
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
My Galaxy over-the-range micro #80009401 has a 4"
That sheet is called the Wave Guide Cover and must be replaced. It is made of Mica and protectes the magnetron and aerial.
Feb 03, 2011 | Kenmore Microwave Ovens
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Sparks and strange noise when microwave is turned on even when empty inside. i have a ge jvm1850smss over the oven microwave.
YOU SHOULD NOT RUN MICRO WITHOUT ANY THING IN IT / THIS WILL OVER LOAD THE MAG TUBE . AND SOME TIMES FRY IT .. The sparking and arcing is probably a bad wave guide . this is sometimes caused by food splater / it gets in the cracks and corners and then cooks till it truns to carbon which conduts the micro's and thus arching .. clean it good and touch up any burns in the metal and repl wave guide cover. mm hope this will help .. mm
Dec 20, 2009 | GE Spacemaker Over-the-Range Microwave
Need to replace handle on micro wave can not
I HAVE A GE PROFILE SPACESAVER 2.0 OVER THE RANGE MICRO WAVE, CRACKED HANDLE, WOULD LIKE TO KNOW HOW TO REMOVE HANDLE AND INSTALL NEW ONE.
Dec 18, 2009 | Jenn-Air M439 Microwave Oven
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
DOOR REPLACEMENT
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 14, 2009 | Frigidaire FMV156EM Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
