Question about Miele CVA4070 Coffee Maker
When the brew unit open to put the waste into the container, this part of the unit stay open
When the brew unit let down the coffee ground into the container, this part of the unit stays open and I can not use the machine and I can not take out the brew unit from the machine. The failure number is 73. I used already the menu service, but the brew is ok, the thing open is the problem, could you help me?
  • 38 Answers
OK I had this precise problem .. initially I got F73 occasionally and then increasingly more frequently over about a 2 week period. When the error comes up the first problem is that you cannot remove the Brew Unit. The Correct procedure is to enter Service Mode and then you have the option of resetting the position of the Brew Unit. For instructions on this consult the Service Manual which is available online for free ... just search for 'CVA4070 Technical Information'.
Now in terms of what can cause this (as the manual does not explain the reason for the fault in my case) ... at first I thought it was the Brew Unit getting sticky and thus too hard for the motor to return the unit to its home position. The motor is actually very strong due to internal gearing and this is unlikely to be the problem unless it's very stiff. In my case it turned out to be one of the two reed switches on the back of the motor drive was very slightly worn (it wears out because it drags on a cam) and this prevented the motor drive from stopping at precisely the right position during the sequence. This then resulted in the machine getting confused about what state the brew unit is in and so it says F73 . The two reed switches that control the Motor drive are accessible from rear of machine by removing the black cover of the motor drive. I can't recall which one was at fault for me .. but if you operate the machine with the motor drive cover off ... and then reproduce F73 ... you can actually see that it has not stopped in the right place on the reed switch and then you can work out which reed switch is causing the problem (also refer to manual which has a good explanation of states). There are two other read switches in the machine of the same type and these are not critical in terms of the wear issue so you can swap these over for the brew unit ones. Alternately you can buy new ones. It's a simple job just to replace them and the Miele service person would probably do it in 10 minutes. Now problem is fixed.
Now if you're doing this yourself ... you should also do some servicing at the same time;
1. Apply grease to the cam that controls the reed switches (this will prevent wear of the reed switch buttons).
2. On the back of the Brew Unit at the top .. there is lever that has ridges on it that activates one of the other reed switches (grinding amount compensation). Apply grease to this. (This can also stop an annoying clicking sound each time you brew coffee).
3. Apply grease to O-ring on the spout of the coffee on inside of door
4. Clean back of machine with vacuum cleaner and then with warm water .. it get fairly dirty. You can take pieces off to clean more thoroughly
5. If your technically skilled .. remove the Brew Unit Drive .. disassemble, clean & re-grease. After 5 years or so its gets dry and you do not want to have to replace this unit. WARNING: Note position of cogs and the cam before you disassemble (ie take pictures) and make sure you put it back in the same way. I did not do this and I broke the plastic cam .. which is designed as a weak link so that metal gears inside motor and brew unit drive are damaged.
Finally ... coffee machines are high maintenance and even Miele ones break-down. Miele spare part prices are very high but what I like about this machine is that it is designed to be serviced.
Posted on Dec 18, 2012
SOURCE: Miele CVA 4075 brew unit locked
Turn your machine off. Close the door. Depress <clear>, holding it down, press <on/off> then let go of both. Then press <clear> 3 times. On 3rd time, hold it until Service menu appears. Select <brew unit> then press left arrow to turn from <off> to <on>. Then press right arrow by <select> This will turn your brew unit drive to the correct position and you should be able to get your brew unit in/out and your waste container back in. Make sure to turn your machine off/on again to get out of Service Menu. I have a picture of how the wire needs to be inserted to get that back on. It's definitely not intuitive, but send another note with your email address and I can send the pics.
Posted on Jun 03, 2010
SOURCE: miele coffee maker cva 4070
OK. Here's the deal. I struggled with this CVA 4070 (F 73) problem also recently, and even posted a questions in the cyber world about it. I jiggled, re-cleaned the machine, re-read the Miele manual, and scoured the internet for schematic drawings of this brewing unit's insides. No luck. Finally after finding out I'd have to pay $199 just for a service clown to walk in my front door, I said NYET!!!  I must solve by myself. If I can take apart & fix my Dyson, etc, etc, I WILL DO THIS TOO!!  (MUST HAVE COFFEE>>>)
Pull out the brewer, turn it a quarter-turn to your right, and look at the spot where that small black plastic piece -- shaped like a block "M" or block "W" -- should be situated. Pull it out, if it isn't out already. Don't worry about yanking it out or harming these parts, said the Miele troubleshooter guy in New Jersey on the phone. They're "made from the same plastic used in football helmets."  Okey-dokey.
This approx. 1.5" wide, blocky plastic piece is part of the "slide" that takes the brewed coffee grounds into the waste container. When positioned correctly, it looks like a block "W,"  with the "wings" ointing up, and slides in just under a brown 1.5" flat piece. A small, down-facing tab on the brown piece clicks into the "W" piece and holds it in place. The "W" should feel fairly solid, although it is not rigidly in place, as the entire mechanism is a movable system to deposit the grounds in the waste receptacle.
Put everything back inside your CVA 4070 "love" machine, hit "on," and wait for it to go through its warm-up.  No F73 message?  Yeah!  Mission Accomplished. You, like I, have fixed your Miele, saved your family relationships, and saved yourself a bundle from unnecessary service calls.
Posted on Apr 09, 2009
SOURCE: I have a Miele Coffee
The brew unit has lose parts on left-hand-side, wiggle them up and down. Put the waste unit back, switch off the machine and then turn it on (pull the cord). It worked for me!!!
Posted on Mar 15, 2011
  • 128 Answers
SOURCE: I have a cva coffee machine it seems like the brew
F73 is a bad brew unit. The cva 4070,4075,4060, and 4066 are designed to use espresso beans.
If you use an oily bean such as Starbuck's french roast, it will clog the filter in the top of the brew unit. If you catch it in time, you can just replace the brew unit. If you run the machine with a clogged filter long enough, you have to replace the brew unit and gearbox together.
Sometimes if you work with the tech support department, they will send you a brew unit to install yourself. If you live in an area that has Miele factory support, you may just want to get a service call. It is very important to rinse the brew unit every 24 hours, and to use the cleaning tablets in the trap door( not the descaling tablets) if not, the coffee oils build up and turn into a tar that will clog the brew unit. They run about 300 dollars so they are worth doing the maintenence on.
Posted on Nov 21, 2010
  • 2069 Answers
SOURCE: I own a Meile CVA 4070 coffee system. The Brew
In order to reset the brew unit drive so you can get the brew unit out, turn the coffee machine off. Then press , holding it down, press then let go of both immediately. Then press 3 times. On the 3rd time, hold until the Service Menu appears. Then go into and press the left arrow button to turn the digital display from to . Now press the right arrow button next to . You'll hear the brew unit drive turn. This reset it and now you should be able to pull out your unit or put it back in - whichever the problem is.
Posted on Oct 29, 2010
Waste unit is stuck and I can not remove it
The standard instructions are ... remove the waste container, water container & ground coffee container. On the front of the Brew Unit is a vertical black lever with a grey press button at bottom. Press this button and turn the lever clockwise. Then press the release catch that holds the brew unit as base and pull the brew unit. If Brew Unit is still stuck then its likely that the Unit State is not in the 'home position' and if this has occurred then its likely that that an error code would be showing. Regards
Dec 27, 2015 | Miele CVA4070 Coffee Maker
I cannot get my Miele CVA470 waste container back in after I put the brew unit in. The slide that has the W piece is blocking the waste unit's entry.
It is because the brew unit is not in the "rest" position. Somebody plaid with it or there is a malfunction with the brew unit so it is not in the initial position. Post a picture of the brew unit in place (without the waste container) and I will make my best to help you.
Nov 16, 2014 | Miele CVA4070 Coffee Maker
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
Miele coffee maker water not coming through to brew unit
try cleaning the nozzles using fine wires or tobacco pipe cleaner kit. it look like you have a blockage on your tubing leading to nozzles.
Nov 06, 2013 | Miele Coffee Makers & Espresso Machines
The coffee grinder makes a sound and it grinds but the ground coffee is dumped directly in dreg container instead of going through water and turn into coffee
Hi
There is a small knob in the bean hopper. It is all the way to the plus(+). Turn it back towards the minus(-) 1 mark. Then try again. It could also be the grinder is separated and is putting to large of a grind into the brew unit. When you have dry grounds dumped into the dredge drawer, it is because the brew unit can't compress it. If it is done too many times it will break the brew drive.
Apr 19, 2011 | Saeco Incanto Classic Espresso Machine
Apr 13, 2010 | Miele CVA4070 Coffee Maker
Water in the waste unit, coffee comes not strong enough, as use to, although the settings are for strongest possible and the coffee grinder is set to medium. My unit is 4075 but I think it is just the...
Your chute between the grinder and the brew unit is "glued" with coffee. Take out the the brew unit, clean it under water. Take a vaccum cleaner and put the pipe into the hole where the coffee falls into the brew unit. Move the bean container "hard" in and out ( knocking inside the maschin to loose the blockage). Switch in the main menue all to factory defaults. Put the grinder "level" into the middle again. start a brew unit cleaning process. After that you coffee must be ok again. Do not use oily beans or coated beans. the block the chute.
Mr. Cool
Sep 30, 2008 | Miele CVA4070 Coffee Maker
Brewing system jammed - Delonghi Magnifical 3200
Ran into this same problem this week - brew /infuser unit is stuck at the bottom of the machine and it doesn't seem to want to move. Cannont replace the drip tray/grounds catching container. After speaking with Sam a wonderful customer service rep at DeLonghi (866-528-8323) I learned the following that saved me from having to send the machine in for repair which could take 2-3 weeks.
  1. Make sure that the machine is unplugged before attempting this repair process.
  2. Open the front door of the machine so that you can see the brew unit.
  3. Take the grounds catching container only (without the drip tray) and put it into position where it would normally be seated.
  4. Carefully try closing the front door.
  5. If the door will not close with the container in position, carefully reach under the door and apply gentle pressure to lift up on the container so that the door can then close.
  6. Plug your brewing machine in. It should power on and then make an internal adjustment which will raise the brew/infuser unit up enough to then be able to once again replace the drip tray and grounds container back into position.
  7. If it does not raise high enough, try unplugging the machine again, wait about 5 seconds and then repeat the same process just described.
  8. Once you are able to replace the tray and container, power the machine on.
  9. Have a cup ready to place under the dispenser as it will release water and coffee as it preps itself for operation again.
Hope this helps those of you who are experiencing this same scenario.
Successful in Seattle
Dec 27, 2007 | Coffee Makers & Espresso Machines
Miele CVA4070 Coffee Maker Logo
477 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
