Question about Knox Video Technologies Mediaflex16RGBBALVGA Mediaflex Presentation Switcher MEDIAFLEX16RGBBALVGA
I have a Knox Video Chameleon 256 matrix switch with the keypad and the monitor says that the keypad is locked and now i can't change the inputs or outputs
With builtin keypad
Some keys wont work after my korg pa50sd is turned on
It's about hardwares.
If dead keys are the same notes(C2-C3-C4 or E2-E3-E5 etc),its electronic parts problem.
If dead keys are random(D1-F1-G3-B5 etc),chances are :
  • Rubber keypads is break. Below the keyboard. Replace it.
  • Dust can cause bad contact the carbon inside the rubber keypad. Clean it.
Jun 13, 2014 | Korg Pa50 Professional Arranger Keyboard...
Keys on yamaha digital piano are sounding more than one note at a time how can i fix this?
The keypads can develop dirt , failure of pads which can result in such malfunctioning. If you are able to open the piano then carefully remove the keypads , clean the surface and reset.
this must solve the issue unless the pads/springs/mechanism are having fault.
Jul 05, 2011 | Roland Hp337 Digital Piano
Led screen is blank
Check the battery condition. Not all parts of the electronics fail to work as batteries fail... it can appear that the batteries are OK but high drain things like LED screens will not work even though other parts are working.
Feb 16, 2011 | Ovation iDea Celebrity Guitar with Builtin...
Lowrey L65 restoration
Try going to the
organforum.com
Feb 17, 2010 | Music
Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Feb 12, 2010 | Yamaha Full-Size Keyboard
I have behringer xenyx802 Iam urgently looking to buy a wireless headphone and mic for my mixer and skype which I use for podcasting. The headet must be padded both ears and mic over mouth due to me being...
Here is a link to what your looking for,
http://pro-audio.musiciansfriend.com/product/Yamaha-CM500-Headset-with-BuiltIn-Microphone?sku=245012
I can't tell from the add but hopefully it comes with adapters for both plugs that will work on your mixer. It does have the one for the headphones but the one for the mic is not clear, they are not interchangeable.
You would obviously plug the headphones into the headphone jack. The knob labeled "Phones/Control Room" will control the volume without changing what's being broadcast. What you hear in you phones is exactly what you are broadcasting.
The microphone needs to go into either mono channel 1 or 2. The adapter for it needs to be a mono Tip/Sleeve adapter as the more common stereo Tip/Ring/Sleeve adapter may cause some problems. You can tell the difference by looking at how many sections are on the plug divided by a little black line. Two sections is mono, three is stereo.
Adjust you microphone level by setting the volume knob, the one on the very bottom, to the 12 o'clock position. Then turn the gain knob, the smaller plastic one on the very top, until the desired volume is reached. If you experience any clipping or distortion turn the gain knob down until it goes away. These are general settings, you may want to experiment until you get the best level without noise.
Nov 30, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Knox Video Technologies Mediaflex16RGBBALVGA Mediaflex Presentation Switcher MEDIAFLEX16RGBBALVGA Logo
85 people viewed this question
Top Knox Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Knox Music Expert? Answer questions, earn points and help others
