Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Power steering fluid coming up steer colume and leaking out on a ford 2000 tractor
  • 45 Answers
Remove steering wheel, throttle cable and cowl . unbolt the top portion (4 bolts)of steering housing to expose shaft (DO NOT REMOVE THE STEERING BLOCK IT'S THE PIECE WHERE THE P/S LINES CONNECT) .Buy a top portion steering kit with seal and o rings replace them and button it up, Test for any leaks, if good you can replace the cowlect. It is a easy fix, the hard part is removing the steering wheeland cowl.
Posted on Nov 04, 2012
Steering colum leaks fluid f910
Seal is leaking on power steering hand pump at bottom of steering column
Jun 04, 2017 | John Deere Garden
I have a 2000 ford windstar. its leaking fluid like crazy. It goes thru a quart a day. To me its coming out the passenger side underneath. I was thinking it was the boot on the rack an pinion. what could...
I am deducing that you mean steering fluid. If it is a power steering model I would suspect a split hydraulic hose with that fast a leak.
Incidentally the 2000 Windstar has had a lot of recalls, including the steering linkage, so I'd have that looked at as well.
http://repairpal.com/ford-windstar-2000/recalls
Feb 03, 2015 | Ford Cars & Trucks
4600 ford tractor losing power steering fluid but have no leaks.
The fluid has to go somewhere is it leaking into a conjoining piece like the transmission...?
Nov 03, 2013 | Ford Tractor Grill 2600 3600 4600 5600...
Chevy Impala leaking steering fluid and steering wheel stiff.
ck. p.s hoses 4 leakage fill pump have someone turn wheel back & forth look 4 leak
Nov 06, 2012 | 2000 Chevrolet Impala
2000 Ford Focus losing power steering fluid.
It could be leaking inside the dust boot on the steering rack. if thats it ...it will eventually start leaking from the boots after they fill up. You could have a small leak from one of the lines. Good Luck
Nov 05, 2012 | 2000 Ford Focus
Steering fluid leak; oil covering steering gear box
if the leak is coming from the steering box there are usually only 3 places it can come from;most common place is the pitman shaft seal,which can be replaced.this is were the pitman arm of the steering connects to the steering box.another place is the steering box input shaft seal,this is were the steering colume connects to the steering box,which can be replace.the last place is the power steering hoses were they connect to the steering box.there are seals that seal the lines when screwed into the box which can also be replaced.so first you need to see exactly were the leak is coming from.rare occasions the steering box is porous which means the box will need replacing.a car of this age should have shown up long ago.you will have to clean the box off at the car wash then run the car and turn the steering wheel all the way to one side,this will build up pressure in the system to show up the leak quicker.
Apr 04, 2012 | 2000 Jeep Wrangler
I have a 2000 Ford Focus with fluid leaking, pink in appearance with water not from cooling system?
im quite sure this will be the power steering fluid leaking, IF the coolant level is staying full. check level of steering fluid its a reddish colour but can become pink when leaking and mixed with water etc. hope this helps
Jul 17, 2010 | 2000 Ford Focus
Need an digram of 2000 ford focus power steering pump
Item Part Number Description 1 - Steering wheel 2 - Steering column 3 - Boot 4 - Tie-rod 5 - Tie-rod end 6 - Steering gear 7 - Steering gear to fluid cooler hose 8 - Fluid cooler 9 - Power steering pressure (PSP) switch 10 - Power steering pump 11 - Fluid supply hose 12 - Fluid reservoir 13 - Pump to steering gear pressure line 14 - Steering gear pinion extension
Jul 30, 2009 | 2000 Ford Focus
I have a 2000 ford explorer xl, making whining noise when turning wheels. What could be the problem?
tazvtaz: If you only hear this noise when turning, I would start with the power steering assembly. 1.Check to verify if you have the proper level of power steering fluid first, if not add fluid as required. 2.Chekc for leaks around the power steering assembly, power steering hoses and replace or repair as required. 3.If the problem still exists, then your power steering motor may be on it's way out. You can verify if the noise is coming from the power steering assembly by having an assistant starting the car (in park)and turning the steering wheel, while you observe the operation of the power steering motor and determine if this is where the source of noise your are hearing is coming from. If you have found this information helpful, please vote for this reply, thank you.
Jun 08, 2009 | 1998 Ford Explorer
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
846 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
