Question about Bosch Washing Machines
Bosch soccer edition error F61 coming
Hi we have bosch soccer edition washing machine model :WAE24467ME erroe code F61 coming and only Drain pump working and after 1 mint off
  • Bosch Master
  • 744 Answers
Bosch soccer edition washing machine model :WAE24467ME This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Posted on Aug 05, 2013
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
localwonder
  • 6784 Answers
SOURCE: My Bosch Axxis WFL pump drain blocked. I had a
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Posted on Feb 25, 2009
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
SOURCE: error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Posted on Mar 10, 2010
SOURCE: Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Posted on Sep 21, 2010
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
What does the fault code E18 mean?
Check drain pump filter
Check drain pump for blockage or restriction
Check outlet hose for blockage or obstruction
Check drain pump operation
Check drain pump wiring
Sep 09, 2014 | Bosch Exxcel 8 WAQ28461GB White 598 mm...
What does E18 fault code mean on a Bosch exxcel 8 washing machine mean?
Sep 09, 2014 | Bosch Washing Machines
Bosch Exxcel 1400 washing machine problem
Bosch Exxcel 1400 washing machine This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Oct 20, 2012 | Bosch Washing Machines
Bosch washing machine error code F61 was does it mean
An F61 error code on your Frigidaire washer indicates a failure of the drain pump relay. Depending upon the model, your washer may be under warranty for up to 6-15 years above , so check your warranty's status before attempting any repairs yourself.
To solve the error code problem apply the below step one after the othe
  • A power outage can cause error codes to display on the screen, even if there's no problem. Hold down the "Cancel" button for three seconds, or unplug the machine briefly to see if the code goes away. If it returns, the problem is real.
  • The pump can also be the problem
  • Unplug the machine and remove the service panel. Locate the pump on the floor of the machine, to the left of the tub, towards the front. Inspect the wiring for burns, breaks or loose connections, and replace as necessary. Use only appliance-grade wire.
  • TO REPLACE THE CONTROL PANEL.
  • If the wiring is fine, the problem is a severed relay on the control panel. Unfortunately, this cannot be repaired and must be replaced. Remove the control panel from the upper portion of the back of the machine, and replace with an identical part from Frigidaire. Generic parts can cause additional damage
  • Hope this help?
    Thanks.
    Nov 19, 2010 | Washing Machines
    What does the erro code f-02 mean
    “F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
    1. Check the drain hose to make sure it is not kinked or clogged.
    2. Check the electrical connections to the pump and ensure the pump is running.
    3. Remove the drain pump filter and check for foreign objects and/or debris.
    Thank you !!
    Jun 20, 2010 | Hotpoint Ultima WF860 Front Load Washer
    Error code E:13 on my 500 plus series washer
    The E13 error code on your Bosch washer refer to a drainage problem or the pump time might have been exceeded
    Either it might be due to a clogged pump, improper detergent being used, ( must use "HE" detergent ) hence suds not allowing a proper drain cycle. You should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. First run the short wash or refresh cycle without detergent and hopefully your lines will clear.
    Thank you !!
    May 25, 2010 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
    I have a WAS24460UC Bosch washer. It won't drain. The pump runs, sounds like it has an air pocket or like the pump is running backwards? I have had a F34 and an F18 erro code.
    Check the drain line for kinks or obstructions. You can take a flashlight, remove the hoses from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
    Sep 10, 2009 | Bosch WAS24460UC Front Load Washer
    Washing Machines Logo
    865 people viewed this question
    Top Bosch Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
