Question about RCA 32" LED HDTV LED32B30RQ - ON Corp US, Inc
The tv menu screen keeps popping on and off when watching TV. Sometimes the sound volume control screen will appear but you cannot control the volume. The set is only 4 months old.
    Top Expert:
  • RCA Master
  • 14,553 Answers
It should be under warranty still but if not and menu comes up on its own I would suspect a problem with the keyboard where the buttons are---they may look and feel fine but they usually are the cause of this kind of problem----In several cases I have had to remove individual micro switches under the buttons to confirm or deny this---if for example menu is disabled by removal of that switch (not the plastic button but the switch under it) then the set can be operated with the remote-----I would see about getting it fixed/replaced even if just out of warranty.
Posted on Oct 30, 2012
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Posted on Jan 29, 2009
  • 442 Answers
SOURCE: There is a only a vague picture on the screen.
As a preliminary step, try unplugging the power cable and then push the power button continuously for 10 seconds (this should drain the flea power from the capacitors inside your monitor). Now plug the power cable back and turn on the TV to check.
This can happen when the back light / the back light circuitry is not working which actually lights the LCD panel in the monitor. Please check for the warranty for this product if so immediately contact RCA tech support. If the monitor is out of warranty then its time you approached a local TV / Monitor repair technician.
Posted on Dec 22, 2010
  • 1706 Answers
SOURCE: The Tv Menu keeps popping
Hi, Try pulling the plug for 1 hour this will reset some things to default.. If this does not fix, go see a repairman.
Posted on Jul 19, 2011
Why does TV not come on After previously watching it. It appears that after a long delay that I found sometimes the TV will come on can you advise me of the fault and what's required to remedy it.
It sounds like your tele maybe in store demo mode..To remedy this press the side button for volume up & whilst the volume up is displayed on the screen press & hold menu...On screen should be either Store/Shop mode Or Home/Standard mode select your preference & it should be ok.Good luck.
Aug 16, 2016 | Samsung LN32A330 32 in. LCD TV
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
Apr 04, 2011 | Televison & Video
Menu screen appears constantly, volume decreases by itself
Hi, common issue with rca sets, you need to replace the tact switches on the front control board. If your not good at soldering / un-soldering you may be able to still purchase the whole control board, call a local tv shop with the complete model # and chassis # of your set and they can give you price & availability, video-tek
Jun 02, 2009 | RCA HD52W59 HDTV Projection Television
Menus pops up
The menu button on the TV itself is bad and must be replaced ( or removed ). Alternatively the whole front button assembly can be disconnected. Just follow the wire back to the main chassis and unplug it.
Apr 09, 2009 | RCA P61927 61" Rear Projection Television
RCA HDTV MENU AND VOLUME CONTROL POPS ON AND OFF SCREEN.
My TV was doing the same thing. Someone told me to disconnect the front menu buttons and this worked for me. The board goes haywire. You have to take off the front black panel on the bottom first then the grey front panel where the controls are. Once you do this you will see where there is a plug from tv to the panel where the control buttons are. Just disconnect. You will only be able to use your remote for TV. Its a cheap and easy fix. Just lots of screws to get the panels off and on. Good luck!
Apr 09, 2009 | RCA HD52W58 52" TV
My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Feb 24, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
Menu, volume and channel emblems will not show up
take your set to a tech the tv system control circuit might have damage, that circuit controls OSD,channel memory. it is an ic that controls that circuit along with other components.good luck.
Mar 26, 2007 | Toshiba 43H70 43" Rear Projection...
RCA 32" LED HDTV LED32B30RQ - ON Corp US, Inc Logo
96 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
