Question about Kenwood TK-3207G 16-Channel Walkie Talkie Black
How to field program
Cannot find any instructions on how to field program my radio. the manual that i have doesn't provide any detail information.
    Prodigy:
    An expert who has answered 500 questions.
  • 607 Answers
Hi will,
The answer is quite simple, and you've partially answered your own query, The reason your manual doesn't mention field programming, is because you can't, you need software to install on your PC and a programming cable set up from PC to your radio.
But, never fear, help is here: join yahoo group specific to your radio Make/ Model, the team there have lots of advice and info, plus you can down load manuals, schematics and (if available) software for your radio. All is free.
I hope you have the programming cable, if not visit the Kenwood website, and click on Parts & Accessories, If it's still available, and I believe they are, then you can purchase one there.
I hope this has been helpful.
Best regards,
Peter
Posted on Mar 07, 2013
My Eurosonic 7 day programmable timer doesn't activate. I've lost the instructions, are they available?
1) Eurosonic appears to analog timer:
http://waterheatertimer.org/How-to-set-timers.html
2) There is new series of digital timers from china, also sold as Eurosonic:
Copy following link for possible manual. Always reset digital timers before programming.
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
3) Add a comment March 2013 and describe timer in detail
Mar 10, 2013 | Hardware & Accessories
Where I can find last BIOS version for my P5VD2-NVM/S?
Click on Start and then Run.
In the text box in the Run window, type msinfo32 and click OK. This will open the System Information program.
When System Information first opens, it defaults to the System Summary, a short list with some of the most important information about your computer system listed.
On the right side of the program, locate the BIOS Version/Date entry.
This field contains the BIOS version that is currently running on your motherboard.
This field may also contain additional information such as the BIOS date, BIOS manufacturer, motherboard manufacturer and the motherboard model number.
Note: If the BIOS date is shown, it can be useful in determining the current BIOS version from a motherboard manufacturer's website if the version is not clear here.
Write down your existing BIOS settings so you can restore them after you've flashed the new BIOS firmware.
Determine the correct BIOS firmware that you need for your computer.
Check your computer manufacturer's website for this information.
If you have a custom-built system, check the motherboard manufacturer's website for the latest BIOS firmware.
Download the latest BIOS firmware specific to your computer.
Some manufacturers provide custom software that initiates the update through your operating system; others provide a third-party application that allows you to flash the BIOS through DOS.
Run the installer or executable file that you downloaded.
Alternately, if the BIOS firmware update is handled via your operating system, simply click "Update," "Write," "Confirm" or a similarly-named button.
If you are prompted for an installation CD, insert the media into your disc drive.
If the CD contains an "autoexec.bat" file, the BIOS will flash automatically when you restart the computer.
While the BIOS flashing procedure varies, nearly all manufacturers provide detailed instructions for completing the task.
Turn off your computer.
Wait about one minute and then reboot.
On some systems, the flash update will restart your computer automatically.
As your computer reboots, go immediately into the BIOS setup menu and look for an option to "Restore Defaults" or "Load Fail-Safe Defaults."
This will be on the main page or the last page of a tabbed menu.
Navigate using the arrow keys on your keyboard and follow all on-screen instructions.
When finished, save your new settings and then exit BIOS.
Your computer will load the operating system.
http://www.wimsbios.com/recommend/biosagent/ibelowmenu
hope this helps
Sep 18, 2012 | Computers & Internet
Yaesu ftm-10e squelch problem
The FTM-10E is the european version of the dual band amateur radio capable of transmitting in the amateur VHF & UHF (144Mhz & 440Mhz ) bands, that is equal to the FTM-10R sold in the US.
Many repeaters require a predetermined sub-audible tone or signal to be sent when transmitting. If several repeaters in the area operate on the same frequency, they would all transmit at the same time unless they all have different sub-audible tones. These tones allow the user to select which repeater on the same frequency will be used. The tones are either CTCSS or DCS type. CTCSS is "continuous tone coded squelch system" and DCS is "digital coded squelch". CTCSS is expressed as a frequency in Hertz and DCS is a code expressed as a number. CTCSS is more popular, since it has been around longer. When programming or tuning the radio, you will need to provide the repeater's output frequency (and the input frequency if the shift direction and amount isn't programmed - often a 600 hertz shift either up or down depending on isn't already programmed is a default value depending on the repeater output frequency) and whether or not the repeater requires a tone. If it does require a tone (most do), you will need to know the type (CTCSS or DCS) and the value (frequency for CTCSS or code number for DCS) in order for your transmitter to open the repeater and cause it to repeat your transmission AND open the squelch on the radio's receiver so that you can hear replies to your call and other conversations. Repeater directories (both printed and online) will provide all the information needed to access a public repeater, including geographical location, input & output frequencies, squelch type and values to name a few.
If you do not have the correct CTCSS or DCS set, you will see the signal meter on the radio indicate traffic - but you will not hear anything because the radio is squelched. Check the manual page 40 for information on how to program the squelch, and page 42 describes the "shift" I mentioned above. Page 64 & 65 details the theory of squelch via CTCSS and DCS and will help you understand it better.
Basically, you have a "standard" squelch - the knob on the radio and a second squelch that is either CTCSS or DCS. Both types must be set to hear anything. Not having the CTCSS or DCS set will prevent your signal from being repeated by the repeater.
If you have more question, please add them in a comment. I hope this helps & good luck!
Jun 17, 2012 | Yaesu FTM-10R VHF/UHF Mobile Dual-Band...
Lost the code list for my rcu404N universal remote an trying o program a rca television
Jawanna,
With the information you've provided, I found the following link to the manufacturer's website for the remote. The codes are listed below for a standard RCA television. http://voxrightnow.custhelp.com/app/answers/detail/a_id/8059/~/information,-user-manual,-code-list-and-support-for-the-rcu404n-remote-control RCA .............1547, 1447, 0047, 0090, 0679, 1047, 1147, 1247, 1347, 1781, 1948,1953, 1958, 2002, 2187, 2247 I've included the step by step instructions provided by the manufacturer for programming your remote to operate your TV. If you need other devices programmed, check the link to download the original instructions on your universal remote. Hope this helps.
Feb 22, 2012 | RCA Universal Remote Control
Information on sony walkman radio, model SRF-HM55. Instruction manual.
I'm glad to provide the Manual of the Radio. Please click here to download the same.
Please let me know if you require any additional help.
Thanks for using FixYa.
Oct 23, 2011 | Sony Walkman SRF-HM55 AM/FM Radio
Need radio code for a 2003 Honda serial numbers areU1110 L9512
The battery was disconnected from my vehicle and now my radio display is flashing "CODE" and the radio doesn't work. Where can I find my radio code? If an audio unit with theft protection is disconnected from electrical power, you must enter a unique code into the unit or it will not work. This code and the audio unit's serial number are listed on the anti-theft ID card that comes with the vehicle. If this card is lost, you must obtain the audio unit serial number in order to get the radio code. Once you have the audio unit serial number, you can go to the Radio & Navigation System Micro-site to retrieve your radio code. Some newer vehicles allow you to retrieve the audio unit serial number electronically from the radio. Refer to your owner's manual for the specific procedure. Most older vehicles (model year 2003 and older) require a visit to the dealer in order to retrieve the audio unit serial number. If dealer assistance is required to retrieve your serial number, the dealer will be able to provide the radio code as well. They do charge a fortune for this service BUT>>>>.... this website is so much cheaper to obtain along with detailed instructions http://www.radio-code.com/?gclid=CMr1lJPqn6kCFU5qKgodUDlDxA
Jun 05, 2011 | Honda Accord Cars & Trucks
Yamaha Rx-V367 Subwoofer not working, I have new Polk Audio PS10 hooked up with Y-Adayer and Subwoofer Cable to Subwoofer Jack on backn of receiver. No sound in Radio mode which other 4 speakers work, in...
Have you looked at the manual?
The NEW thing doesn't work.
Does the subwoofer work for setup? That would certify the hardware and speaker definitions are ok.
The PC has the responsibility for defining and sending out something between headphone and full-blown 7.1 though the HDMI. Check your PC sound controls and the "Information on HDMI" section of the manual.
For the radio mode, probably the only analog stereo source you have, read up on the STRAIGHT decoding mode and Sound Field programs.
May 08, 2011 | Yamaha RXV367 Receiver
Easy way to program my bc355c scanner
The BC355C is a factory pre-programmed scanner, and it cannot be programmed in the usual manner (entering and saving a frequency via the keyboard). You can, however, transfer any displayed frequency in the SEARCH or SCAN modes to the scanner's PRIVATE banks, saving it for later scans. Detailed instructions for doing this can be found on pages 49 through 56 of the factory manual. If you don't have the manual, you can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC355Com.pdf
Bill B.
Listening in since the 60's
Apr 10, 2011 | Radio Communications
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
How to program diginal trucking on a radio shack pro 197 diginal scanner
Digital trunking systems require detailed programming steps, and those steps vary according to the type of system you need to program. The manual for your scanner provides step-by-step instructions for each system type, and I recommend that you familiarize yourself with its contents. If you don't have the manual, you can download and print it here:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000197_PM_EN.pdf
If the information in the manual seems overwhelming, you might want to join a user group (check Yahoo Groups and RadioReference.com) or consider using available programming software programs.
For a comprehensive database of active frequencies and systems in your area, and a lot of other useful scanning info, visit:
Bill B
Mar 05, 2010 | Radio Communications
Kenwood TK-3207G 16-Channel Walkie Talkie Black Logo
111 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
