Question about Eureka Vacuums
Eureka Dream Machine Plus needs Belt change
Brushes won't turn
5 Suggested Answers
SOURCE: belt change for eureka capture
Lie the vacuum down so it's completely flat, the back of it facing up. On the bottom of it, on the grey plastic, there are instructions. They say, to access the belt, remove the screws numbered 1, 2, 3 & 4. Then look at the four corners of the bottom of the vacuum and you'll see these numbers. You may need a flashlight to actually see the screws because a couple of them are pretty deep inside the plastic. Loosen them with a long shafted, Phillips screwdriver. Stand the vacuum back up and the screws should just fall out. Then you can easily pop off the cover to change the belt.
Posted on Feb 07, 2009
  • 21 Answers
SOURCE: change vacuum belt
This unit is not designed for the consumer to change the belt. Eureka recommends you to take it to a service station to have this done
Posted on Jul 19, 2009
Vac Belts
  • 701 Answers
SOURCE: changing belt for a eureka power plus 4703D
I have listed below a link to the owners manual which has instructions on how to change the belt and a link to the belts you need. Hope it helps!
Eureka 4703D Owner's Guide
Eureka 4703D Replacement Belts
Posted on Nov 03, 2009
  • 377 Answers
SOURCE: How do I change the belt on my eureka whirlwind
If you go to this URL you can see videos on read articles on changing the belt. Please make sure it is the correct model number:
http://www.ereplacementparts.com/eureka-3277avz-upright-vacuum-parts-c-108750_108773_109147.html
If this solution is of help to you, I would appreciate a Thumbs Up rating from you. Thank you. Paul
Posted on Oct 05, 2010
Eureka maxima vacuum smokes and smells like rubber burning..whats wrong with it..the brush turns but seems like its blowing outwards too
when you get a burning rubber smell, the drive belt is usually slipping on the motor due to friction on the brushes. Remove the belt and free all the tangled hair to allow the brushes to rotate very easily and then put a new belt on.
Jun 03, 2015 | Eureka Vacuums
Eureka Optima 431x Belt replacement
Not sure if this is any good but here is a link to a youtube video showing how to remove the cover and change the brush and belt.
https://www.youtube.com/watch?v=JxoHDvr1ZJI
Apr 07, 2013 | Eureka 431A Optima Bagless Upright Vacuum
My vacum roller brush dosenot work
The most common failure there is the drive belt from the motor to the brushes has failed. Consult your local vacuum store for a replacement. Normally they are fairly easy to change. Check and see if the brush is free wheeling or needs a push to get it to turn. If the belt is broken or worn out the brushes will turn freely.
Mar 30, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Brushes do not spin when it is on low carpet you have to have the knob on high carpet for it to work.
That means that the belt is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet. The lower the setting the more resistance. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Nov 19, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Changing belt for a eureka power plus 4703D
Nov 03, 2009 | Vacuums
I have to check the belt in the ereka powerline plus. how do I do that?
Below I have listed a link that will open the owners manual that has step by step instructions on how to change the belt. Also I have listed links for the replacement belt you need. Eureka recommends replacing your belt at least every 12 months.Hope this helps you.
Eureka Powerline LiteSpeed Owner's manual
Eureka Powerline LiteSpeed Replacement Belts
Oct 29, 2009 | Eureka Powerline LiteSpeed 5845 Upright...
Brushes stopped spinning
I would guess the beater bar is still jambed or the belt burned in two.
Apr 25, 2009 | Eureka 2903A Maxima Bagged Upright Vacuum
Eureka The Boss Smart Vac, beater bar stops turning when you use it on carpet
It is a simple fix that you need. Your belt needs to be replaced. After a period of time, the belt stretches to the point where it is still strong enough to spin the brush when you have the machine upside down to look at it, but when you put the machine down on the carpet the belt is too weak to turn the brush against the resistance of the carpet.
Most Eureka belt changes are simple to do and the belts are inexpensive.
Oct 24, 2008 | Eureka Vacuums
Vacuums Logo
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
