Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
What kind of motor oil use the husky 3750 generator
Sae 30
Posted on Oct 29, 2012
What kind of oil?
It actually depends on the environment but you will be okay with 10W30
Mar 27, 2016 | Husky 3650 Watt Generator with Subaru...
Husky generator won't start
did you try cleaning the conductor that goes to the spark plug if not try to clean it with a real fine sand paper it should do the job.
Oct 27, 2012 | Husky Portable generator
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
I have a husky 3750 generator about 2 yrs old. It is ony running on choke. As soon as you remove choke, it stops. I have changed oil and gas, clean the spark plug and check the air filter. Any ideas?
The fuel filter is probably partially clogged or the adjustment screw for the fuel mixture on the carb has backed off due to vibration. Try turning in the screw in 1/8 th of a turn at a time every time you start it.
Screws always loosen due to vibration so you only have to adjust in to fix it.
Regards
TickMagnet
Aug 15, 2011 | Briggs 3500W Port Generator
I have a Husky 3750 generator for HD. The breaker trips when anything but the smallest load is placed on it. Is this anything other than a bad breaker?
You should be able to run an electric kettle and a toaster from that generator without problem. I would say to have a look at the breaker first. This seems to be the obvious source of this fault.
May 15, 2011 | Briggs & Stratton Power Products 5,550...
How much oil is required for 6.75 hp briggs and stratton engine on a 3750 generator?
Probably about 750cc / near 3/4 of a quart. Make sure generator is on level surface, add oil in small amounts and check using dipstick until shows full.
Jun 09, 2010 | Briggs & Stratton Power Products 5,550...
What kind of oil do I use in my pressure sprayer gemric brands to
Check with your local hardware store and your owners manual. Usually the oil to be used in a motor like that is SAE 20 3-in-1 oil that can be picked up at any hardware store. It comes in a red white and light blue bottle. (Note: Do not mistake it for the 2-in-1 oil that comes in the black and white bottle).
May 15, 2010 | Dewalt Garden
I recently purchased a Husky 3750 watt generator to ''hook-up'' to my house. The wiring already exists so I figured I would just plug and be good. NOPE! I get it started with ease but when I try to...
Is the house dead??? Did you turn off the main breaker in the house?? It sounds like you are sending voltage to the generator.Do you have a switch that stops the power from going down the street from your generator?? 3700 watts is not a whole house genny, you need more like 6500. 5000 min, unless you are just running the fridge and the lights. Is your "plug" wired into the fusebox through a breaker or straight to the bars? You gotta check these things out.
Feb 26, 2010 | Briggs & Stratton Power Products 5,550...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
231 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
