Question about RTO 110cc Basic Manual ATV # ATD-125C
Does anyone know how to set the idle on the 110 atv
The atv will crank but it will not stay running when idleing
Not sure about that particular one however if it has been sitting for a while or has a bad fuel filter the low speed jet in the carb is probably clogged. Your local lawn mower shop should be able to fix for much less than the motorcycle shop.
Posted on Oct 29, 2012
I am working on a older commando 250 atv for a freind, he was riding it and stopped running, After i found & fixed a broken ground wire it will only run on high idle then shut rate off, it will only run...
sure sounds like something in the carb. just for fun crank it with your hand sealing the carb intake and see if you get gas on your hand. sometimes that'll clear up things. if your hand stays dry its got a fuel problem. older machine prob needs the valves adjusted too.
Oct 23, 2017 | ATVs
My suzuki ATV quad runner cranks & idles but when you give it gas-spits and sputters/YOU MASH THE STARTER BUTTON asgiving it gas/runs fine.starter stays engaged whole time
Hi, Todd and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
Good luck and have a nice day.
Jan 13, 2017 | Suzuki Motorcycles
Switch quad to awd and it starts to idle rough, and wont drive. Put it back to 2wd and it rides perfect, what could be the issue?
ATV Answerman on ATV amp UTV Tech Questions: Off ...
www.off-road.com/atv/atv-answerman-on-atv-utv-tech-questions-53357....
Nov 30, 2011 - I have got a 2005 arctic cat 650v twin starts very good at idle good but when ... Each year varies and although some machines never change it would be ... A flooded ATV will be rough at idle and have a telltale smokey exhaust. .... with and without the 4x4 engaged it seems to be stuck in awd but the front left ..
ATV won't stay running - ATVs & Snowmobiles ' In-Depth Outdoors
www.in-depthoutdoors.com > ... > ATVs & Snowmobiles
Jan 19, 2011 - 27 posts - ‎18 authors
I know, this isn't the ATV forum, but I'm hoping maybe one of the mechanical ... it is a bear , but when she starts I have to keep the throttle pressed.If I turn up the idle so she Idle's about 20 seconds later the Idle Is at about 2000 ...Missing: awd
Dec 25, 2015 | Cars & Trucks
I have a 660 Grizzly 03 Atv im having a idle problem i have not did any repairs on this bike the idle will set its self down to low and quit running i set the idle up to normal and in a few moments of...
1. Check the INTAKE valve clearance!!!!
2. Check for an air leak
3. Install a new spark plug and air filter!!
4. Check the compression..
5. Have the carb professionally cleaned and set!!
>> Once you have sone all these steps.. repost to me if this did not fix it!!
Sep 07, 2017 | Yamaha 2004 Grizzly 660 Auto 4x4
My DRZ 110 finally starts after cleaning the carb. Now it wont stay running unless its throttled up and down. The Exhaust coming out of the engine starting glowin red and it keeps backfiring. What can i...
You are running really lean. gas is not getting to the idle ports. try removing the idle mixture screw and shooting some carb cleaner in there. make sure you get all of the mixture screw parts out first. Reinstall screw and set to previous adjustment. you may have to back out the idle mixture screw a bit to allow it to idle properly. There is a very small idle mixture jet that may be clogged as well.
Jun 04, 2011 | 2005 Suzuki DRZ 110
2001 polaris scrambler 90 will crank and idle all day long, but when you try to throttle up, it bogs down and dies. carb has been cleaned, new plug, exaust is clear of blockage, still has same problem
I dont have a solution but mine is doing the same as the posted ones--runs at idle but bogs down with fast fuel feed!! does anyone know the solution?
Sep 05, 2010 | Polaris ATV
Wont idle
Not knowing if you know anything about idle speed settings, idle mixture, etc., first check to see if all carburetor components are fully in place and are in good shape. A vacuum leak will cause the symptom you are describing. After doing that, adjust the idle stop screw. If it just won't idle even after doing that, take out the idle mixture screw, blow out the screw hole with compressed air, and gently screw in this screw all the way in. (DO NOT FORCE it.) Then open it 2.5 turns. Adjust this screw for a good strong idle while adjusting the idle SPEED with the idle stop screw. Get assistance if you don't know how to do this stuff. Good luck.
Jan 04, 2010 | RTO 110cc Basic Manual ATV # ATD-125C
RTO 110cc Basic Manual ATV  # ATD-125C Logo
317 people viewed this question
Top RTO Cycling Experts
Michial Gueffroy
Lloyd Carter
Gregg Mahin
Gregg Mahin
Are you a RTO Cycling Expert? Answer questions, earn points and help others
