Question about Emerson EWC1304 13 in. TV/VCR Combo
Emerson VT1320 TV/VCR
VCR wont insert, tape in light on, make noise when turn on while tape heads turning, than stop.
  • Bernice Mendoza May 15, 2007
    Tape wont insert all the way in, what mode should it be on; it does't have an antena or remote control whould that be the problem
  • Anonymous Jul 09, 2008
    Tape went in but will not play or eject. When I hit play it tries to go but then stops. Nothing happens when I hit evect. Tape is stuck in machine.
  • 76 Answers
Hard to say what is wrong but have seen a lot of problems with the mode switch in these models.the mode switch tells the mechanisim what mode it should be in and the contacts can tarnish and mech cannot figure out which state it is in.
Posted on May 15, 2007
SOURCE:
How to program a VT1320 Emerson remote when it does not have a tv button, only power button and does not show up on screen to do the programming?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Jan 07, 2016 | Emerson Televison & Video
VCR making noise and won't take tapes
THE VCR SECTION WILL NEED LUBICATING INSIDE THE TV WOULD OF DRIED THIS OUT DUE TO THE HEAT FROM THE TV OVER TIME.THERE IS A LOT OF MOVING PARTS IN A VCR A MUST ALL WORK TOGETHER.
Apr 24, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
My emerson EWV603 vcr. When I turn it on or when I insert a videocasette, the screen is blue. How do I get to the menu stuff so that I can program my vcr?
Sounds like your VCR & TV are on different channels.
The VCR's ouput is channel 3 or 4. Try turning your TV to either channel and see if you get a picture. OR try playing the tape and after 2 or 3 seconds, push the play button again for a few seconds to change the VCR's ouput channel.
Oct 08, 2009 | Emerson EWV603 VHS VCR
Keeps going to "err" and shuts down when I insert tape
Hi. your VCR is experiencing a major mechanism fault within the head assembly. the head is unable to read the tape. in this case, you will need to replace the main head assembly in this unit.
May 18, 2009 | Emerson Televison & Video
VCR runs a few seconds when I insert a tape then shuts off power.
You have to change the two VCR rubber bands
Jc
co6bg@yahoo.com
Feb 02, 2009 | Emerson EWD2202 DVD Player/VCR
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Tape won't load.
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but one of the reel The takeup reel is turning properly but one of the reel rotation sensors or its electronics is defective. As a test, check to see if the tape counter is changing at any time during the loading and
Dec 12, 2005 | Emerson EWV603 VHS VCR
Emerson EWC1304 13 in. TV/VCR Combo Logo
248 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
