Question about LG LBC22520ST Bottom-Freezer Refrigerator with Swing Freezer Door, Bottom-mount Freezer, ENERGY STAR rated, Swing-door Freezer Design, Ice Plus Accelerated Freezing Function, LoDecibel Quiet Operation, Multi-Air Flow Cooling, Temperature ControLBC22520S
My LG multi air flow GR-359SQ fridge has stopped working
Stopped working
SOURCE: lg multi air flow gr-349sqf
Could be a wire short,bad defrost heater, or comp. pulling too many amps which is between 2 and 6 or higher being bad. I would say the main problem is you purchased a LG fridge which is a poorly made fridge,sorry.
Posted on Apr 01, 2008
SOURCE: lower portion of the lg fridge is not working /freezer
bnbgdflcdg nd;klh djope'j;e m;jbdb.vkigm; sgups gbdvbxcvx
Posted on Nov 14, 2008
stradeteox
  • 88 Answers
SOURCE: freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Posted on Jan 08, 2009
ginko
  • 19396 Answers
SOURCE: lg gr l207tlq fridge does not stop running water
That means that either the inlet valve located at the back of the fridge is broken (most common) or there is a bad wiring to inlet valve, and valve does not close.
Posted on May 01, 2009
SOURCE: LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Posted on Dec 18, 2009
Lg gr-432sf refigerator not getting cool air flow to fridge compartment
It's not clogged full of ice behind the cover plate? That happens often - the defrost timer dies, and the evaporator packs solid with ice.
If that's not the case, then... does the fan rotate when the power is turned on? If not, suspect the (defrost timer) controller board. If it does, look for obstructions to airflow.
Jul 26, 2014 | LG Refrigerators
Hello, we have a three year old LG GR-359SQ Fridge freezer. Firstly, everything works fine with the unit but at the bottom of the freezer compartment is a 30cm x 30cm by 10mm deep trough that in a space of...
Try adjusting the levelers on the bottom I like to see 1/4 bubble on a level if you don't have a level no problem just so it slopes to the back. good luck Tom
Jul 02, 2009 | Freezers
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
Freezer working fine but fridge isn't
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Aug 27, 2008 | Freezers
Mar 30, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
LG LBC22520ST Bottom-Freezer Refrigerator with Swing Freezer Door, Bottom-mount Freezer, ENERGY STAR rated, Swing-door Freezer Design, Ice Plus Accelerated Freezing Function, LoDecibel Quiet Operation, Multi-Air Flow Cooling, Temperature ControLBC22520S Logo
62 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
