Question about HP Computers & Internet
Fan is not working correctly - HP Computers & Internet
  • HP Master
  • 32,281 Answers
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on Oct 30, 2012
Error e00840
E00840 is a fan error code, the fan is not working correctly. I would check all the fans for operation. I have a bad feeling that the fan that is not working correctly is the power supply fan, you will need to replace the DC power supply on the left side of the copier.... Good Luck
Jan 11, 2014 | Canon imageRUNNER 5570 Copier
Cooling fan keeps blowing a fuse on my 2000 maxima #1 fan. #2 fan works when a/c is turned on
It's is very possible. You may be correct however don't dismiss the wiring. The wiring may intermittently short with movement/vibration and cause fuse to blow but most likely you are correct in thinking that your fan needs replacement.
Jul 05, 2012 | 2000 Nissan Maxima
How can i fix system error 11do on hp designjet 9000s
System Error 11D0: Cooling Fan Error
Description:
When the Printhead temperature reaches above 43oC, the Printer will check
whether the temperature drops below 43oC during printing. This error will
appear if the temperature does not drop below 43oC after 10 minutes.
Corrective Action: Try the following:
Make sure that the Printhead Cooling Fans are working correctly. If the
Printhead Cooling Fans are not working correctly, replace them.
Make sure that the Printer Cooling Fans are connected and working
correctly.
Oct 06, 2011 | HP DesignJet 9000 InkJet Printer
System error 11do
Problem
Description:
correctly.
Remote control will not turn on fan
Do you have the correct type of fan connected to the motherboard ?
For fan control to work you must be using the type of fan that has at least three wires in the connector plug (if it has four wires that is ok too) but if it only has two wires then it will not works since the third wire is the control wire that the motherboard uses to detect fan speed and so on...
Fans that connect through a connector on the power supply will not work either must be conected to motherboard plug on the motherboard itself with at least three wires
hope this info helps
NOTE: if you are sure you are using the correct type of fan then check BIOS power/hardware monitor settings to see if the fan is connected to the correct plug on the motherboard and to verify it is being detected properly and fan speed setting is correct.
May 15, 2011 | Computers & Internet
Hi, im using a motherboard asus m4a88td-m and i cant control my fan speed(cpu fan and chassis fan) in any way.... i tried the asus motherbord software it doesnt work, i try settings in the bios(cool and...
You may not have the correct type of fan for this to work. Typically, you need a three or four pin fan (you will see three or four wires on the plug) for fan speed control to work correctly. If you only have two wires, your fans do not have speed control functionality.
You can also have another issue. If you do have a three or four ping fan, you may not have it connected to the correct fan headers on the motherboard for it to work correctly, or you may have it connected to an external fan controller.
May 05, 2011 | Computers & Internet
Ceiling fan light works with wall switch, but comes on dim when I pull the chain for the fan
is the fan working correctly, if it is not it could be a bad armature or field
Jan 20, 2008 | Dryers
Fan not working
This suggests the bulb is not correctly fitted. remove and refit- if required consult manual or bulb packaging to make sure this correctly carried out. come back
Jul 19, 2007 | ViewSonic PJ458D DLP Projector Multimedia...
Computers & Internet Logo
15 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
