Question about Kolpak KOL-SK71213CI Indoor Walk In Cooler 11ft 7in Wide 12ft 6 and a halfin Long 7ft 6in High
Hussman Floral walkin display cooler, has 3 fans but 2 stopped
Walkin Display cooler, compressor still working but only 1 out of the 3 cooling fans are working on inside colling unit. Seems that it only goes into 1st stage and does not kick into next stage in which other 2 fans kick on.
Thanks for any help
    Director Badge:
    Uploaded 100 video answers.
  • Kolpak Master
  • 488 Answers
how hard to work on Walkin refrigerator, and why there is not many people work on those things!
Posted on Sep 10, 2015
  • 37 Answers
All three fan should run at the same time all the time. It seems unlikely that two fans went bad at the same time, so run out the wire that goes from fan to fan it sounds like the wire has come unhooked between the working fan and the non working two.
Posted on Jan 03, 2009
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
1999 kolpak walkin freezer not staying cold
Is the compressor cycling on and off? Is there any oil around fittings at components? Gas is the last thing you put in a refrigeration system. You need to find the leak before you put any more gas in the system. Hope this helps good luck.
Apr 08, 2014 | Kolpak Freezers
Where can I find a replacement cov er for tMy Walkin Pup?
HI Jimmy, Try ebay. But as this is a common problem contact the manufacturer. You may have to pay a small fee but will be worth it.
Sep 15, 2013 | Hasbro FurReal Friends GoGo My Walkin Pup
Commercial walkin condenser freezing up
Defrost Timer on walk in cooler
Sep 15, 2013 | Heating & Cooling
I need a Master Bilt Cam Wrench to disassemble a Walk-in freezer. What can I use and where can I find it?
All the walkin coolers that I have installed use a allen wrench and I beleive it is 3/8 inch. Try allen wrenches first. Rus
Dec 03, 2009 | Master Bilt Indoor Walk In Cooler or...
Wine cooler does not get cool - fans do not run the light and temperature display do work
if you hear the compressor tun on but not the fan, replace the fan and you may have to defrost the evaporator coils. if the compressor does not turn on either, it's the thermostat, the defrost timer, or a relay on the main board.
Nov 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Walkin cooler
Most Likely Low on Freon. Low Pressure switch shuts That Compressor Off.
Dec 29, 2007 | Refrigerators
Kolpak KOL-SK71213CI Indoor Walk In Cooler 11ft 7in Wide 12ft 6 and a halfin Long 7ft 6in High Logo
433 people viewed this question
Top Kolpak Refrigerators Experts
jasbo
jasbo
Marat Brikov
Are you a Kolpak Refrigerator Expert? Answer questions, earn points and help others
