Question about Mitsubishi WD62527 62 in. LCD HDTV
How to fix the ballast on my tv - Mitsubishi WD62527 62 in. LCD HDTV
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Presuming the ballast is bad it is only available as a complete unit---Google the model number with "ballast" to locate a part number and or the part.
Posted on Oct 30, 2012
My vizio 47 in. tv lost picture while i was watching news. I tried the flashlight test i was told about on here and can see the picture. how do i fix this problem?
I am pleased you found my flash light test useful. You have a ballast or back light problem. Probably just the ballast unit, so well worth repairing as the expensive bit is OK.
Check the ballast unit before seeking lamps.
Jan 18, 2011 | Vizio VT470M 47 in. TV
My 50in LCD has had a green tint to it for several months, was told by Best Buy that it was likely that a mirror got misaligned when we moved. Friend had the exact same tv...thought that the bulb went...
Good luck with that.... But if you really want to try,... look at where the bulb makes electrical connection when it is plugged into the set. You should see two thick wires leaving a connector and going to a circuit board. this board is the ballast. You'll have to disassemble until you can get the board along with the wires and connector.
Aug 14, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I changed the bulb of my Samsung tv and it is still blinking lamp. How do I fix it?
U here a alot of clikcking,turn power on to tv?Yes,than the Ballast board also dead,need it be replacing.The Ballast board,help to ignite the bulb.
Jun 20, 2010 | Samsung HCM4215W 42" Rear Projection...
Insignia IS-LCDTV32 LCD TV with no image and buzzing sound.
Before you throw it in the trash, check the supply voltage to the panel ballast. You should see 24v coming off the power board... this is what you want to check. Second, check to see is the ballast is being given an "ON" signal.. you will find this signal on the same connector or one of the others going to the ballast (some models have 2 connectors from power supply to ballast. The "ON" signal will come on shortly after you press the power button. If you have both, you either have a bad ballast or a bad lamp inside the panel assembly. The lamp.. no fix, junk the TV; the ballast.. you could search high and low for one or try to fix it yourself; no 24v, check with MCM Electronics for a power supply; no, "ON" signal, your main PCB is suspect. I hope this was helpful, best wishes.
Apr 22, 2010 | Insignia IS-LCDTV32 32 in. Television
Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Jan 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Buzzing sound, resets 8 times, and then turns off. Bulb replaced
Actually ballasts run between 60-80 dlls. It does sound like you doi have a ballast issue, everytime a TV resets the ballast is the issue. Go to discountdashmerchantdotcom you'll see the ballast prices. Plus they also have free troublehsoot.
Aug 25, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Fixing a ballast
no our problem was not fixed.
Jul 12, 2008 | Televison & Video
Mitsubishi WD62527 62 in. LCD HDTV Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
