Question about Maytag Dryers
Clothes catching in dryer - Maytag Dryers
  • Maytag Master
  • 7,482 Answers
Hi jqueen39532
You did not state what model Maytag dryer your using, so I can only help you so much.
Your problem is the seals front/rear is worn out causing your clothes to catch in the dryer causing tears and holes in your clothes.
Check with the company on the following webpage for parts and pictures of how your machine looks in parts.
Please take time to rate me
Bud
http://www.appliancepartspros.com/
Posted on Oct 30, 2012
Not drying clothes or catching lint
Hi Diane, You have 1 of 3 Problems. Either your 1. Heating element is bad 2. Thermal fuse is bad or 3 Your timer is out of wack.
Oct 12, 2013 | Dryers
Tumble dyer catches the clothes
hi have good look for splits in drum had couple gone at back were heat enters
Mar 29, 2013 | Hotpoint Dryers
Kenmore stack dryer burns clothes
HI CAROMIA.unusual but check basics first1-dont overfill 2-no sintetics and nylons.if still burns its obviously overheating.3-check vents.hope this helps.ali
Jun 20, 2012 | Kenmore Dryers
Neptune electric dryer catching clothes making holes in socks etc.
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Nov 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer twisting and catching clothes
there is a front felt piece that if it is warren out will catch your cloths and rip them. you need to replace that front felt.
this part might be the cause of the felt getting damaged. http://www.partselect.com/PartDetail.aspx?Inventory=419088&SourceCode=5&ModelNum=gleq2152es
this is your felt http://www.partselect.com/PartDetail.aspx?Inventory=975866&SourceCode=5&ModelNum=gleq2152es
Oct 19, 2010 | Frigidaire GLEQ2152ES Electric Dryer
It catches clothes by light/
Fill the holes with silicon bathtub caulk and let dry well.
Jun 20, 2010 | Hotpoint Dryers
Frigidaire electric dryer catches clothes at the edge of the drum
If the clothes catch on the drum edge the felt seal is worn out , and the squeak could be the bearing the drum rest on or the belt tentioner , it may need oiled , you can buy the felt seal replacement kits online and they are not hard to install.
Hope this helps.
Phil
Apr 10, 2009 | Frigidaire FDE436RE Dryer
My clothes are catching between the drum and casing(?), the drum seems to be loose. My dryer is a GE profile/prodigy
suspect front tub support/bearing ring worn remove top by removing screws under front edge of top lift top 1 screw each side of front on inside front ring attaches to front panel look for worn plastic ring and pads
May 31, 2008 | Dryers
Dryer door clip
try replacing both the catch and strike , call local part wharehouse or order online, real easy to install just pop them in
131658800 - CATCH-DOOR
5303207102 - STRIKE
Mar 11, 2008 | Dryers
Dryers Logo
75 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
