Question about Dewalt 38 Electric VSR Drills
My DWD110 drill runs (slowly) when plugged in. The trigger is not depressed yet.
  • Anonymous Mar 25, 2014
    how to change bits
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Clean switch with air pressure
if it does not settle your problem you will have to change the switch
Posted on Nov 21, 2012
Low output on 110 when using power tools
Take and plug in a variable speed drill now when your generator is powered up slowly hit the trigger on the drill start it at low speeds run it for 30 seconds then give it half speed for 30 then full speed fo 30 seconds then try your chop saw
Nov 25, 2012 | 5.5 HP GX160 Engine
The switch is stuck on my Nikota electric drill. What do I do?
You will have to take it apart to get to the trigger. Most likely the switch broke but it could be the spring is out of place. Very fixable. You should have no problem getting a replacement trigger if it is broken.
Jun 17, 2012 | Drills
How do I unlock the chuck to get the bit out
Finally got it the normal way. Put the drill in reverse. Hold the outside ring very firmly and slowly run the drill (in reverse direction). It was stuck. After about 5 bursts on the trigger, it finally came unstuck.
Sep 01, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Model DWD110 While using to drive 2 1/2 inch deck screws the drill was operating normal. After loading another screw to drive, the drill would not energise. It was as if the cord had come unplugged,...
It's possible that you fried it somehow, or you tripped a fuse on the line you are using to power it. Try plugging it into another outlet.
May 18, 2011 | Dewalt Drills
Motor fails to run when trigger depressed
sounds like your armature and field is burnt. once they have both got hot you need to replace the armature and field as well as the brushes and holders.
Jan 24, 2010 | Drills
Y generator starts but not putting out any power
plug in a electric drill into the generator. start the generator and let it idle. depress the trigger on the drill with the drill set in the forward position and by hand turn the drill in the opposite direction. it should excite the generator and start the drill
May 15, 2009 | Coleman Powermate 5000W Home Backup...
Makita chuckless drill stuck full open
If you haven't fixed it yet here is the way that I have used to solve this problem. Spray some WD-40 on the inside of the chuck. Place a shop rag around the chuck and CAREFULLY grip with a pair of channel lock pliers set the drill rotation so that it will extend the jaws and SLOWLY depress the trigger. It should move. Let me know if I can help more. When trying this DO NOT SQUEEZE TRIGGER to full RPM.
Sep 11, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt 38 Electric VSR Drills Logo
102 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
