Question about Polaris 380 In Ground Pool Cleaner
Y Polaris 380 is running on its back wheels only?
The Polaris only runs on back wheels , the front wheel is up in the air!
  • Thomas Oct 31, 2012
    Obviously there is no front wheel, my mistake! Basically it is running with it's nose up in the air!
    Top Expert:
  • Polaris Master
  • 7,897 Answers
Adjust thruster to 11:00
Posted on May 22, 2016
  • 3 Answers
SOURCE: Polaris 380 wheels not moving
Here are some things to check: 1.  There are belts inside the unit that drive the wheels.  These belts often fail (shred) and must be replaced. 2.  There is a paddlewheel that drives the turbine that turns the wheels.  If the jet that drives the turbine is clogged, then the paddlewheel will not move and the wheels will not turn. 3.  There is a water management system inside the bottom of the unit.  It looks like a bunch of little hoses.  If one of these hoses comes loose, then the water pressure will escape inside the unit and will not be sufficient to drive the wheels.
Hope this helps
Posted on Jan 12, 2009
SOURCE: Polaris 380 not running
check the filters
Posted on May 28, 2009
  • 128 Answers
SOURCE: Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Posted on Aug 23, 2009
  • 990 Answers
SOURCE: My polaris 380 wheels won't turn. the belt is
If the wheels don't turn there may be sand in the notches on the wheels, the notches may be worn off, if their is sand or dirt in the paddel wheel jet that will keep the unit from turning and again no wheel movement. All of these problems they can check in your local pool store. Stores will generely check your unit out and fix what is needed for just the price of parts to fix it when you bring it into the store.
If you have no water flow to the unit this will also stop things from working so be sure to check your finger screen before you do anything.
Posted on Aug 25, 2009
  • 8404 Answers
SOURCE: What to do when the Polaris 380 wheels do not
Check for hair on the vertical axel.
Posted on Jun 05, 2010
Change belts on polaris 380
open case then remove vertical tube then then remove paddle wheel assy then you have to remove wheel screws to change belts take pictures as you take it apart
Jul 29, 2012 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels won't back up
open up unit check hoses on inside if they are off put on and zip tie
Jul 21, 2012 | Polaris 380 In Ground Pool Cleaner
Polaris 380 wheels not turning
see if filter at wall fitting ok then see if water coming out of jet on back
Aug 02, 2017 | Polaris 380 In Ground Pool Cleaner
My pool sweep platinum legend will not move
if pressure from wall take off top see if wheels touching gears if not move out you can swap front to back also check hoses inside
Apr 07, 2012 | Polaris 380: Polaris Booster Pump
Machine keeps going around in circles jet at back is going straight back?
Few different things can cause this. Wheel bearings can be bad, tires worn, teeth on gears inside wheels stripped or broken, or the teeth on drive shaft worn or broken. Low pressure or clogged line can also cause to run sparatic, but not necessarily in circles. Most likely problem is with bearings, or wheels. Check these closely for problems. Most pool stores with check it and replace parts (that you purchase) for free.
Sep 21, 2010 | Polaris 380 In Ground Pool Cleaner
Aug 24, 2009 | Polaris 380 In Ground Pool Cleaner
Jul 23, 2009 | Polaris 380 In Ground Pool Cleaner
Unit floats does not run on all wheels
Sounds like it might be missing the head weight. Check for number 25 in this Polaris 380 Parts Diagram
Jun 28, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 380 In Ground Pool Cleaner Logo
69 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
