Question about Sanyo DRW-1000 DVD Recorder/VCR
Dvd disk cannot be used to write
I have tried dvd-r disk 16x and 4x. Except Memorex dvd-r 4x is the only brand that work. I have tried other brands 4x and does not work. Memorex 4X is not available or difficult to find. Why is Memorex Dvd-r 4x the only one that work? and if is another brand or type of disk that i can use?
  • 76 Answers
You should ring Sanyo helpdesk direct for fault like this as you shouldnt be having problem of this nature also would be good idea to go back to where you bought it to see if they have heard of problem,.
Posted on May 15, 2007
I have a LG GE20 DVD Rewriter Is a DVD+RW disc a format that is editable and suitable for this unit?
The LG G20 DVD Rewriter is an advanced external burner that supports 'editable' Rewritable DVD+RW disk.
As a generic comment, not all writable/rewritable media are made equal and problem with branded & unbranded disks are not uncommon, so stick to brands that work for you for your specific unit!
The following is the advertised support for your unit, hope it helps:
Reading Rate DVD-R/-RW/-ROM 16x/13x/16x/16xSL/12xDL max. DVD-RAM 2x, 3x-5x, 6x-12x DVD-Video (CSS) 4,8x max. (Single/Dual Layer) DVD+R/+RW 16x/13x max./ 12xDL max. CD-R/RW/ROM 48x/40x/48x max. CD-DA (DAE) 40x max. Burning Speed DVD-R 2x, 4x CLV, 8xZCLV, 16x PCAV, 20X CAV DVD-RW 1x, 2x, 4x, 6x CLV DVD-RAM 2x, 3x ZCLV, 3x - 5x PCAV, 12x PCAV DVD+R 2.4x, 4x, 8x, 12x, 16x PCAV, 20X CAV DVD+R Double Layer 2.4x, 4x, 10x, 12x ZCLV DVD-R Dual Layer 2x, 4x, 6x CLV, 10x, 12x ZCLV DVD+RW 2.4x, 4x, 6x, 8x ZCLV CD-R 4x, 8x CLV, 16x, 24x, 32x, 40x, 48x ZCLV CD-RW 4x, 8x, 10x CLV, 16x CLV, 24x, 32x ZCLV
Dec 28, 2009 | Computers & Internet
WHY DON'T SONY RECORDABLE DVDS PLAY IN SONY DVD PLAYERS? I USE THE SAME PROGRAM TO BURN MEMOREX AND SONY DISCS, THE SAME DVD+R 120 MIN/4.7GB(OTHER THAN THE BRAND BEING DIFFERENT), AND i HAVE HAD NO PROBLEM...
all dvd recorders are very very sensitive when comes to which disc is fed to them......you say sony is the same as memorex is the speed the same 4x-16x, may i also suggest maxell, dynex and vertabram
Oct 23, 2009 | Sony SLV-D300P DVD Player/VCR
Will not recognize disk
try using DVD-R 4X or 8X or 16X any brand with this rating should work, since i had similar problems and these work for me now.
Sep 11, 2009 | JVC Everio Share Station DVD Burner Burner
Cant find the correct disk to use says not compatible model #cu-vd10u s# 151y6000
Shortwater....
Try using DVD-R 4X or 8X or 16X ....seems any brand works. It did for me.
"Wrong Disk" error
I would assume that you finalized the disk after you burned them. THat being the case try the disk on another DVD player. If that does not work try burning another disk. Its possible that its either a failed burn, a picky DVD player or plain defective disc. So the only option left is to isolate the probelm.
Oct 04, 2008 | Memorex (3202-5639) (50 Pack) (32025639)...
DVD not recording
You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x.
Walmart carries the correct ones!
Sep 03, 2008 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Can't get past LOAD
it might need to be cleand u take the sheild off and take a q tip and lightly clean the laser
pls rank ps keep off the carpit
Jan 23, 2008 | Samsung DVD-VR357
Can't record
hi all, spanky new, ok here my problem!! i got the panasonicdmr-e55 for xmas, 3 or 4 years ago. since then and even wheni started to use it the disc i recorded on were -R phillips 4x. since then i have tried every available manufacture of 4x's u could think of and yet to this day it will only record on a phillips 4x disc. its been in the shop a few times for cleaning and upgrades and yet they haven't beable to tell why it only accepts PHILLIPS BRAND 4X. the new upgrade i recieved fromthe manufacture was supposed allow higher in x's on disc. it accepted 16x phillips only ONE TIME AND REJECTED 50 OF THEM, SINCE THEN ABSOLUTELY NO MORE 16X OF ANY KIND. ANYONE GOT A SOLUTION????? ps even tried 8x its still a no go. i can't afford anything since i'm on social security. message: UNREADABLE DISC. SUGGEST REPLACED DISC. OK SO THIS MORNING I TRIED TDK, MEMOREX, H.P. CIRCUIT CITY, AND 6 OTHER BRANDS ALL 4X NEGATIVE R, STILL A NO GO HELP, THANKS GINA
Dec 23, 2007 | Panasonic DMR-E55 DVD Recorder
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Sanyo DRW-1000 DVD Recorder/VCR Logo
57 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
