Question about Breville BKC600XL Coffee Maker
My BKC600XL Breville Keurig coffeemaker, shorts out the outlet when I flip the switch to turn on the screen display
When I plug in the coffeemaker and flip the "on-off" switch to get the screen display to light up, it trips the GFC circuit.
  • 44 Answers
Before I start is there water in unit? If that inter tank is empty you willshort the heating element out.this is something like a elect hot water tank. you must have water in that tank. Also some time water leaksdown off a solenoid on to a transformer that also can short out.This is something that should be done by a pro. Hope this sheds some light on the problem. tvharry
Posted on Mar 20, 2013
REMOVE WATER FROM INNER CHAMBER
I had the same problem. Called the company and they told me it cannot be done. They recommended that I purchase a commercial version of the Keurig brand that does have a drain.
Mar 17, 2013 | Breville BKC600XL Coffee Maker
Can I use vinegar to descale my Breville single cup coffeemaker?
White wine vinegar is a great descaler as it can dissolve the white deposits. For kettles, fill them up and leave them overnight. Don't boil it, though - the vinegar will froth up and go everywhere. Afterwards, rinse the kettle thoroughly, fill with water and boil before using it again. Malt vineger can also be used as the malt only adds flavor
May 05, 2011 | Breville BKC600XL Coffee Maker
It doesnt shut off automatically anymore
Sound like a problem with the programming.
Your Instruction Booklet can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/Breville_BKC700XL.ashx
Make sure you review the setting and programming instructions.
Mar 19, 2011 | Breville BKC600XL Coffee Maker
Water not coming out. How do I clean the machine?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer for the BKC600XL / BKC700XL can be found here:
The booklet has an extensive section on cleaning.
Mar 12, 2011 | Breville BKC700XL Stainless Steel
I used the filter with my own coffee and now it is clogged. How do I fix it?
The Instruction Booklet for the Breville Gourmet Single Cup Brewer BKC600XL / BKC700XL can be found here:
See Page 32 for Troubleshooting. You may need to unclog the Exit Needle and run a cleansing brew.
Mar 06, 2011 | Breville BKC700XL Stainless Steel
Coffee brewer works to the point wher you push the flashing brew button no water pumps through.
Hi
If your coffeemaker appears to be clogged. Create a vinegar and water solution and flush the concoction through your coffeemaker pump. This will help dissolve build up in your coffeemaker. If you do this once a month, your coffeemaker pump won't clog.Unplug the coffeemaker and inspect the pump valve. Water won't rise through the fill tube if the pump valve is stuck or broken. If your pump is sealed, replace the pump. If the pump valve is accessible, make sure there are no coffee grounds or mineral deposits around it.
Also check the brewing switch is in good working order. Remove the base plate on your coffeemaker and test the switch with a volt-ohm meter. Set your volt-ohm meter on the RX1 scale. If your switch reads zero ohms, your switch works fine. If it reads anything other than zero, replace the switch. Also take a look at the tube connectors, if your coffeemaker is sputtering, leaking or steaming. Leaks in pump coffeemakers are often due to faulty tube connectors. Unplug the coffeemaker and fill the reservoir with water. If water leaks from an elbow, clean the mating surfaces before replacing it. If your water leaks from a tube connector, replace the tube and mating elbow to ensure a good fit.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 07, 2011 | Breville BKC600XL Coffee Maker
The lights are not on when plugged in.
Make sure you have power at the outlet being used.
Secondly make sure you have switched on the power switch at the rear of the right side of the machine.
For additonal Troubleshooting tips your Instruction Booklet can be found here:
Mar 01, 2011 | Breville BKC700XL Stainless Steel
My Breville Keurig coffee maker turns itself off after heating water...why?
mcdevito75 here, It may need to be cleaned, if the brewing holes are clogged it"ll signal coffeee maker to shut off. Refer to owner manual for cleaning.
Jun 22, 2010 | Breville BKC600XL Coffee Maker
My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
May 31, 2010 | Breville BKC600XL Coffee Maker
Breville BKC600XL Coffee Maker Logo
371 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Tally Girl
Tally Girl
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
