Question about Elna Quilter's Dream 6003Q
Elna sewing machine 7000 geting bobin won't go through the feed dog
  • Elna Master
  • 1,125 Answers
Sorry, not sure I understand your problem. can you elaborate?
Have you got the correct Elna bobbin for your machine? check your manual, it should have an image of the bobbin, the 7000 was one of the last Swiss made Elnas and although a computerised machine, it still tool the Elna metal bobbin with 7 holes on one side only. If you are using another bobbin in the shuttle, it may not function correctly.
if you can add some more info I will try to help you further.
Posted on Nov 03, 2012
Tally Girl
  • 1125 Answers
SOURCE: How do I raise the feed dog in my Elna 5000, a
I have a 7000 manual and from memory the 7000 was released a year after the 5000 and very similar. Look at top middle image below, for feed dog release at back of the sewing free arm.
tally_girl_19.jpg At the back of the sewing free arm (remove the accessories tray) is a slide to lower the feed dogs, there is a little stub that you need to push to release it. Manual says "Drop the feed by pushing the slide (a), which is at the rear of the elevated sewing surface, to the left. To raise the feed dog again, press down the stud (b) and the feed dog will rise when you start sewing." You might need to wind the flywheel towards you half a turn to visually check they have come up.
Posted on Apr 12, 2011
Testimonial: "That's it! Thank you so very much!"
SOURCE: service manual elna 722010 sewing machine
www.whitesewingcenter.com has the manual for an Elna 722010.
Posted on Mar 27, 2010
SOURCE: free manual for Elna 7000 sewing machine
hello, I don't know if you have found a manual yet, but I have the elna 7000 and it's manual.I could copy mages and send as an attachment as a last resort for you. I am giving the machine and all its many books to my daughter in law,
Posted on Sep 18, 2010
Tally Girl
  • 1125 Answers
SOURCE: i have for gotten how
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Posted on Apr 30, 2011
Tally Girl
  • 1125 Answers
SOURCE: My "new" elna type 722010 only sews in reverse.
What is the stitch length lever set to (4 in the diagram below)? these models have a lever that slides from positive to negative (ie) reverse, so you need to set it to the positive area, between 2 and 3 above zero. If you move it below zero then it sews that stitch length backwards.
If this machine is new to you, you might want to join the yahoo group called "Elna Heirlooms" there is lots of helpful members who share info on these old machines there.
Posted on Jul 21, 2011
How Do I lower the feed teeth on my Elna 3003 machine for free sewing. Thank you.
This may help:
How to Drop the Feed Dogs on Elna Sewing Machines eHow
However, some machines do not have the ability to drop the feed dogs but instead has a plate that attaches to the machine to cover the feed dogs. Your manual is probably the best source for information.
Apr 11, 2017 | Elna Sewing Machines
Hi, My Elna 7000 doesn't easily feed medium or thin fabrics. Presser Foot tension lever is position 2 and the Feed Dog is rising normally. Any thoughts please? Does the F Dog wear out in any way?
Generally, the lighter the fabric weight, the heavier the presser foot pressure. Yes, feed dogs do wear with use. Do not run the machine without fabric between the presser foot and the feed dogs--the feed dogs constantly rubbing against the presser foot will quickly wear the feed dog points. Store the machine with the presser foot down with a pad between the presser foot and feed dogs (even a scrap piece of fabric will do). Also, be sure to clean the feed dogs of any gunky build-up. If the feed dog points are worn, it may be worthwhile to have them replaced.
Jan 23, 2017 | Elna Sewing Machines
Why do the feeds dogs not move the fabric when you begin to sew. The feed dogs are up.
the feed dogs need to be check, it's possible that they are broken.
Jul 14, 2014 | Elna Sewing Machines
Dressmaker sewing machine 7000 thread won't move
something could be wrong with the feed dogs, it's would be a
good idea to have them checked.
Jan 08, 2013 | Sewing Machines
What does feed dog lever do on my Elna 6005 Heirloom sewing machine? Do I need to alter it for sewing very thick fabrics/seams?
Feed dog lever should lower the feed dogs, these are the teeth that grip and move the fabric foward and backwards as the needle goes up and down, they are under the needle plate.
Only time you would lower the feed dogs is if you want to do free motion embroidery or darning perhaps.
So no, don't touch for normal seam stitching. If you are sewing very heavy fabric you may want to lessen the pressure on the presser foot a little (if your machine has this adjustment it will be a knob on top of the head above the pressure foot area).
You may find that your machine doesn't really like very thick fabrics. Sewing something like upholstery weight with a domestic machine is pretty ambitious; an industrial strength machine is best bet.
Nov 09, 2011 | Elna Heirloom Edition 6005
O.comI'm having a couple of problems: it seems like the feed dogs need to be adjusted because I need to gently pull the fabric through, from the back, otherwise the fabric won't advance & I...
if you have a manual check where your feed dog knob is, push the knob in the opposite direction,,if that doesn't help then something may be wrong with the feed dogs,,you should be able to see the feed dogs in the needle plate area & to feel them with your fingers.
you may need to have the machine serviced at a sewing shop
Sep 21, 2011 | White Sewing 1730 Mechanical Sewing...
How do I raise the feed dog in my Elna 5000, a machine I recently inherited.
Apr 12, 2011 | Elna Sewing Machines
ELNA 7000 SEWING MACHINE
If the darn setting is selected the feed dogs will not rise, someone has probably inadvertantly selected darn.
Mar 18, 2008 | Sewing Machines
Sewing Machines Logo
384 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
